Webcast-Catalyst9k
Cisco 857W Wireless
Hi All,
Have an 857W for a client and having problems getting the wireless working. Config below with irrelevant details removed. IOS version 12.4(15)T15
Can connect a client (PC/iPhone) to the wireless network, but it's not getting assigned an IP address
Current configuration : 8007 bytes
version 12.4
no service pad
hostname #####
boot-start-marker
boot-end-marker
logging buffered 51200 warnings
aaa new-model
aaa authentication login userauthen local
aaa authorization network groupauthor local
aaa session-id common
dot11 syslog
dot11 ssid AdvSkinBeauty
   vlan 1
   authentication open
   authentication key-management wpa
   guest-mode
   wpa-psk ascii 0 password
no ip dhcp use vrf connected
ip dhcp excluded-address 192.168.1.1 192.168.1.3
ip dhcp pool ccp-pool
   import all
   network 192.168.1.0 255.255.255.0
   default-router 192.168.1.1
   lease 0 2
ip cef
ip name-server 139.130.4.4
ip name-server 203.50.2.71
archive
log config
  hidekeys
bridge irb
interface ATM0
no ip address
no atm ilmi-keepalive
dsl operating-mode auto
interface ATM0.1 point-to-point
description $ES_WAN$
pvc 8/35
  encapsulation aal5mux ppp dialer
  dialer pool-member 1
interface FastEthernet0
interface FastEthernet1
interface FastEthernet2
interface FastEthernet3
interface Dot11Radio0
no ip address
encryption vlan 1 mode ciphers tkip
broadcast-key vlan 1 change 30
ssid AdvSkinBeauty
speed basic-1.0 basic-2.0 basic-5.5 6.0 9.0 basic-11.0 12.0 18.0 24.0 36.0 48.0 54.0
station-role root
interface Dot11Radio0.1
description Advanced Skin and Beauty Wireless
encapsulation dot1Q 1 native
no cdp enable
bridge-group 1
bridge-group 1 subscriber-loop-control
bridge-group 1 spanning-disabled
bridge-group 1 block-unknown-source
no bridge-group 1 source-learning
no bridge-group 1 unicast-flooding
interface Vlan1
description $ETH-SW-LAUNCH$$INTF-INFO-HWIC 4ESW$
no ip address
ip nat inside
ip virtual-reassembly
ip tcp adjust-mss 1452
bridge-group 1
interface Dialer0
ip address negotiated
ip nat outside
encapsulation ppp
dialer pool 1
dialer-group 1
no cdp enable
ppp authentication chap callin
ppp chap hostname #############
ppp chap password 0 ######
crypto map clientmap
interface BVI1
description $ES_LAN$
ip nat inside
ip local pool vpnpool 192.168.99.1 192.168.99.20
ip forward-protocol nd
ip route 0.0.0.0 0.0.0.0 Dialer0
ip http server
ip http access-class 23
ip http authentication local
ip http secure-server
ip http timeout-policy idle 60 life 86400 requests 10000
ip dns server
ip nat inside source static tcp 192.168.1.129 8016 interface Dialer0 8016
ip nat inside source static tcp 192.168.1.129 8116 interface Dialer0 8116
ip nat inside source static tcp 192.168.1.129 8200 interface Dialer0 8200
ip nat inside source static tcp 192.168.1.129 8201 interface Dialer0 8201
ip nat inside source static tcp 192.168.1.129 10019 interface Dialer0 10019
ip nat inside source static tcp 192.168.1.2 3389 interface Dialer0 3389
ip nat inside source static tcp 192.168.1.129 12088 interface Dialer0 12088
ip nat inside source route-map NONAT interface Dialer0 overload
access-list 23 permit 192.168.1.0 0.0.0.255
access-list 100 deny   ip 192.168.1.0 0.0.0.255 192.168.99.0 0.0.0.255
access-list 100 permit ip 192.168.1.0 0.0.0.255 any
access-list 150 permit ip 192.168.1.0 0.0.0.255 192.168.99.0 0.0.0.255
dialer-list 1 protocol ip permit
no cdp run
route-map NONAT permit 10
match ip address 100
control-plane
bridge 1 protocol ieee
bridge 1 route ip
line con 0
no modem enable
line aux 0
line vty 0 4
privilege level 15
transport input ssh
scheduler max-task-time 5000
end
Everyone's tags (3)
1 REPLY
Hall of Fame Super Gold
Cisco 857W Wireless
Shart with show dsl interfafe.
After, debug ppp auth, debug ppp neg, with "term mon"
904
