06-06-2012 06:44 AM - edited 03-04-2019 04:35 PM
I have a HQ site able to bring up a Dialer connection to a remote site (Site-BB). It also works in reverse i.e. Site-BB can make the connection into HQ. Now I have a requirement to get a 3rd site connecting into Site-BB. But when I create a new Dialer interface the original connection won't come up.
Here are the details:
hostname Site-BB
ip cef
no ip bootp server
ip name-server 192.168.1.105
isdn switch-type basic-net3
username SIte-HQ password xxxxxxxxxx
interface BRI0
no ip address
no ip redirects
no ip unreachables
no ip proxy-arp
ip flow ingress
encapsulation ppp
dialer pool-member 2
isdn point-to-point-setup
interface ATM0
no ip address
no ip redirects
no ip unreachables
no ip proxy-arp
ip flow ingress
no atm ilmi-keepalive
interface FastEthernet0
interface FastEthernet1
interface Vlan1
description $ETH-SW-LAUNCH$$INTF-INFO-HWIC 4ESW$$ES_LAN$$FW_INSIDE$
ip address 192.168.4.250 255.255.255.0
no ip redirects
no ip unreachables
no ip proxy-arp
ip flow ingress
ip nat inside
ip virtual-reassembly
ip tcp adjust-mss 1452
interface Dialer0
no ip address
interface Dialer1
no ip address
encapsulation ppp
dialer pool 1
dialer idle-timeout 20
dialer string 0191730044
dialer string 0191730066
dialer-group 1
no cdp enable
ppp authentication chap pap callin
ppp chap hostname Site-BB
ppp chap password xxxxxxxxx
ppp pap sent-username Site-BB password xxxxxxx
interface Dialer3
ip address 10.0.4.1 255.255.255.0
encapsulation ppp
dialer pool 2
dialer-group 2
no cdp enable
ppp pap sent-username Site-BB password xxxxxxxxxx
ip forward-protocol nd
ip route 0.0.0.0 0.0.0.0 Dialer3
ip route 192.168.1.1 255.255.255.255 192.168.4.254
ip route 192.168.1.4 255.255.255.255 192.168.4.254
ip route 192.168.1.5 255.255.255.255 192.168.4.254
ip route 192.168.1.6 255.255.255.255 192.168.4.254
ip route 192.168.1.105 255.255.255.255 Dialer3
ip route 192.168.1.151 255.255.255.255 192.168.4.254
ip route 192.168.1.153 255.255.255.255 192.168.4.254
ip http server
ip http authentication local
ip http secure-server
ip http timeout-policy idle 60 life 86400 requests 10000
ip nat inside source list 1 interface Dialer0 overload
ip nat outside source static network 192.168.1.105 192.168.4.250 /32
ip access-list extended OutSIte-HQ
remark out to SIte-HQ
remark SDM_ACL Category=1
remark out to HQ
permit ip 192.168.4.0 0.0.0.255 10.0.4.0 0.0.0.255
ip access-list extended inboundSIte-HQ
remark inboundSIte-HQ
permit ip 10.0.4.0 0.0.0.255 192.168.4.0 0.0.0.255
logging trap debugging
access-list 1 remark INSIDE_IF=Vlan1
access-list 1 remark SDM_ACL Category=3
access-list 1 permit 192.168.4.0 0.0.0.255
dialer-list 1 protocol ip permit
dialer-list 2 protocol ip permit
no cdp run
control-plane
banner login ^CCCCCCCCCCCCCCCCCAuthorized access only!
no inservice
end
______________
So above works fine both ways; when I add the new details below for the new site - it stops working
interface BRI0
dialer pool-member 3
! (now BRI0 has pool-member 2 and 3)
interface Dialer99
description ISDN_to_New-site
ip address 192.168.99.74 255.255.255.0
encapsulation ppp
dialer pool 3
dialer string 0167115500
dialer-group 2
pulse-time 0
ppp chap password 0 xxx
ppp pap sent-username Site-BB password 0xxx
ip route 192.168.200.0 255.255.255.0 dialer99
!___________________________________
Obviously I now need to be able to have ISDN access Site-BB from both HQ-Site and New-site. Any help appreciated. Thanks
_____________
June 7th...
I understand I will need to add the new subnet to the access list; however, the problem is that once the new Dialer99 is added to the config the HO router cannot access Site-BB (using Dialer3). I need to have this working as normal before testing access from the New-site (using Dialer99).
06-06-2012 06:58 AM
Hello T.connor,
I suspect that the BRI can be pool member of only one dialer pool at the same time.
No, actually it is supported see DIAL command reference
http://www.cisco.com/en/US/docs/ios/dial/command/reference/dia_d1.html#wp1033489
So the second dialer that you add dialer99 might use the same dialer pool 2 as the first dialer dialer3.
The dialer pool defines a set of resources that in your case are the two B channels of the BRI interface.
There is another aspect that needs to be addressed: if a call is in place it can take both B channels of the BRI leaving no chance to place the second call.
You could add to both dialer the command
dialer load-threshold 255
in order to reduce the chance that the second B channel is used in the call
There is a specific command to specify the max number of calls
in your case to indicate only one B channel to be used. Configure it only on this router not on the other ones.
Hope to help
Giuseppe
06-06-2012 07:07 AM
Thanks for the reply. From Cisco ...
http://www.cisco.com/en/US/docs/ios/12_0/dial/command/reference/drdiprof.html#wp4903
interface BRI1
encapsulation ppp
dialer pool-member 1 priority 50
dialer pool-member 2 priority 50
!BRI 1 has a reserved channel in dialer pool 3; the channel remains
inactive
!until BRI 1 uses it to place calls.
dialer pool-member 3 min-link 1
Terry O'Connor
giuslar
To:
Terry O'Connor1/Ireland/IBM@IBMIE
Date:
06/06/2012 14:58
Subject:
Home
Re: Cisco 870 ISDN problem
created by Giuseppe Larosa in WAN, Routing and Switching - View the full
discussion
Hello T.connor,
same time.
So the second dialer that you add dialer99 should use the same dialer pool
second call.
call
Hope to help
Giuseppe
Reply to this message by going to Home
Start a new discussion in WAN, Routing and Switching at Home
06-06-2012 07:11 AM
Hello T.conner
yes I have seen the command reference
however, the suggestion to limit to one B channel each dialer interface might be helpful
see
http://www.cisco.com/en/US/docs/ios/dial/command/reference/dia_d1.html#wp1013853
to be put in each dialer interface configuration to allow space for the second call
Hope to help
Giuseppe
06-07-2012 01:44 AM
OK - I will change both Dialers to be in the same dialer pool (pool 2).
Also, do you think I need to configure the original Dialer3 and new
Dialer99 with both these commands?
dialer max-call 1
Terry O'Connor
giuslar
To:
Date:
06/06/2012 15:12
Subject:
Home
discussion
Hello T.conner
might be helpful
see
dialer max-call 1
second call
Hope to help
Giuseppe
06-07-2012 02:58 AM
OK - still no joy - dialer load threshold & dialer max-calls entered ...
would the access list be an issue here ?
Terry O'Connor
dialer max-call 1
Terry O'Connor
giuslar
To:
Date:
06/06/2012 15:12
Subject:
Home
discussion
Hello T.conner
might be helpful
see
dialer max-call 1
second call
Hope to help
Giuseppe
06-07-2012 03:54 AM
Here is the ISDN debug after I add the new Dialer interface. The HQ site
attempts connection on the original Dialer3 but fails;
06-07-2012 09:29 AM
Hello t.oconnor,
I don't see the debug output use the attach file option to attach a txt file with the debug output.
In any case the dialer list have to be more specific now, as you want to dial to new remote site only when traffic to remote site IP subnet 192.168.200.0 is present.
access-list 102 permit ip any 192.168.200.0 0.0.0.255
dialer-list 2 protocol ip 102
There is a way to invoke an IP extended access-list like in the example above (check the syntax I have written on the fly)
For the other site you can invoke an ACL that is made in the following manner
access-list 101 deny ip any 192.168.200.0 0.0.0.255
access-lit 101 permit ip any any
Notice that in this way whatever packet your router has to send it will dial. So you may need to tune this.
Hope to help
Giuseppe
06-07-2012 11:06 AM
I have attached the ISDn debug. I understand I will need to add the new subnet to the access list; however, the problem is that once the new Dialer99 is added to the config the HO router cannot access Site-BB (using Dialer3). I need to have this working as normal before testing access from the New-site (using Dialer99).
06-07-2012 11:42 AM
Hello t.connor,
from ISDN debug output when both dialer interfaces are configured the router rejects the incoming call with error
>> Cause i = 0x8095 - Call rejected
the following document describes the ISDN error codes that appear in the output of debug isdn q931
http://www.cisco.com/en/US/tech/tk801/tk379/technologies_tech_note09186a008012e95f.shtml
The first byte (most significant) after 0x indicates the point in the circuit path where the disconnect cause code appears
80—the router
The next byte (9F in the sample output) that follows the cause code origination point byte is the Disconnect Cause Code
85
Misdialled trunk prefix.
The remote number you dialed is not reachable.
Check the number you dial. Verify if you need any prefixes to access the network. For example, you need to dial 9 for outbound calls through a PBX. Contact your telco/PBX administrator for details.
The problem is that the router is not able to bind a BRI channel when both dialer interfaces are configured and enabled.
Edit:
your configuration looks like incomplete it is good for calling out not for receiving.
i think you would need some
dialer map
command in order to discriminate incoming calls on the two dialer interfaces
I remember I have used dialer map commands on receiving side in interface dialer.
The command is also useful when you want to call different destinations with a single dialer interface.
see
http://www.cisco.com/en/US/docs/ios/dial/command/reference/dia_d1.html#wp1013440
Hope to help
Giuseppe
06-08-2012 02:55 AM
yes dialer map ip commands on ISDN Hub router should be the way to go
Router(config-if)# dialer map protocol next-hop-address name hostname
For any host calling in to the local router or access server, maps its host name (case-sensitive) to the next hop address used to reach it.
Repeat this step for each host calling in to this interface.
see
The problem you face is that the router is not able to understand what dialer interface to use when answering the call when two dialer interfaces are configured and running. This should be the reason for the ISDN error seen in the debug isdn q931 not bindable.
Hope to help
Giuseppe
06-08-2012 04:39 AM
Hi, Dialer Maps are for "legacy" DDR. I am using Dialer Profiles and cannot configure dialer maps on the Dialer interface.
06-08-2012 05:36 AM
Hello T.oconnor,
I have used dialer-maps with dialer interfaces in the past it is a way to provide a resolve mechanism to allow the router to decide which dialer should answer the incoming call when multiple interface dialer are defined.
What can tell the router in your configuration what dialer to use when answering an incoming call? This is why you have troubles with two dialer interfaces
In my configuration I needed to map incoming call to a different MPLS VPN based on dialer map VRF aware feature.
I was using C7200 as PE ISDN and these were backup links for MPLS VPN. The C7200 had ISDN E1 and calling CE nodes had BRI interface.
Hope to help
Giuseppe
06-08-2012 06:14 AM
The following points describe several design factors you should decide on before configuring a DDR link.
DDR Implementation: You can use dialer maps (legacy DDR) or dialer profiles. For more information on the differences between these two implementations, refer to "Configuring ISDN DDR with Dialer Profiles" In this configuration we use dialer maps.
When I am in config mode on interface dialer99 there are no commands available to configure dialer maps...can you provide an example?
Building configuration...
Current configuration : 279 bytes
interface Dialer99
ip address 10.0.73.99 255.255.255.0
encapsulation ppp
dialer pool 3
pulse-time 0
ppp chap hostname Site-bb
ppp pap sent-username Site-bb password 0 xxx
end
Site-bb#
Site-bb#conf t
Enter configuration commands, one per line. End with CNTL/Z.
Site-bb(config)#int d99
Site-bb(config-if)#?
Interface configuration commands:
access-expression Build a bridge boolean access expression
appletalk Appletalk interface subcommands
arp Set arp type (arpa, probe, snap) or timeout
autodetect Autodetect Encapsulations on Serial interface
bandwidth Set bandwidth informational parameter
bridge-group Transparent bridging interface parameters
carrier-delay Specify delay for interface transitions
cdp CDP interface subcommands
clock Configure serial interface clock
compress Set serial interface for compression
cpp Combinet Proprietary Protocol
custom-queue-list Assign a custom queue list to an interface
decnet Interface DECnet config commands
default Set a command to its defaults
delay Specify interface throughput delay
description Interface specific description
dialer Dial-on-demand routing (DDR) commands
dialer-group Assign interface to dialer-list
down-when-looped Force looped serial interface down
dxi ATM-DXI configuration commands
encapsulation Set encapsulation type for an interface
exit Exit from interface configuration mode
fair-queue Enable Fair Queuing on an Interface
full-duplex Configure full-duplex operational mode
half-duplex Configure half-duplex and related commands
help Description of the interactive help system
hold-queue Set hold queue depth
ip Interface Internet Protocol config commands
ipx Novell/IPX interface subcommands
keepalive Enable keepalive
lapb X.25 Level 2 parameters (Link Access Procedure,
Balanced)
line-power Provide power on the line.
llc2 LLC2 Interface Subcommands
load-interval Specify interval for load calculation for an
interface
logging Configure logging for interface
loopback Configure internal loopback on an interface
mac-address Manually set interface MAC address
max-reserved-bandwidth Maximum Reservable Bandwidth on an Interface
mop DEC MOP server commands
mtu Set the interface Maximum Transmission Unit (MTU)
multilink Configure multilink parameters
multilink-group Put interface in a multilink bundle
netbios Use a defined NETBIOS access list or enable
name-caching
network-clock-priority Configure clock source priority
no Negate a command or set its defaults
ntp Configure NTP
peer Peer parameters for point to point interfaces
ppp Point-to-Point Protocol
priority-group Assign a priority group to an interface
pulse-time Force DTR low during resets
random-detect Enable Weighted Random Early Detection (WRED) on an
Interface
rate-limit Rate Limit
serial serial interface commands
service-policy Configure QoS Service Policy
shutdown Shutdown the selected interface
smds Modify SMDS parameters
smrp Simple Multicast Routing Protocol interface
subcommands
snapshot Configure snapshot support on the interface
snmp Modify SNMP interface parameters
source Get config from another source
timeout Define timeout values for this interface
transmit-interface Assign a transmit interface to a receive-only
interface
trunk-group Configure interface to be in a trunk group
tx-ring-limit Configure PA level transmit ring limit
Site-bb(config-if)#dialer ?
callback-secure Enable callback security
called Specify called telephone number to be screened
caller Specify calling telephone number to be screened
enable-timeout Set length of time an interface stays down before it
is available for dialing
fast-idle Set idle time before disconnecting line with an
unusually high level of contention
hold-queue Configure output hold queue
idle-timeout Specify idle timeout before disconnecting line
in-band Set v.25bis dialing for interface
load-threshold Specify threshold for placing additional calls
max-call Specify maximum number of calls
pool Specify dialer pool to be used
redial Configure redial for this interface
remote-name Configure a remote name
rotor Set outbound rotor order
snapshot Enable snapshot address for dialer profile
string Specify telephone number to be passed to DCE device
vpdn Enable vpdn dial
wait-for-carrier-time How long the router will wait for carrier
watch-disable Time to wait before bringing down watched route link
watch-group Assign interface to dialer-watch-list
--More--
06-08-2012 06:22 AM
Hello T.oconnor,
try to enable
dialer in-band
first,
It is present in my configurations.
Hope to help
Giuseppe
