Cisco 870 ISDN problem
I have a HQ site able to bring up a Dialer connection to a remote site (Site-BB). It also works in reverse i.e. Site-BB can make the connection into HQ. Now I have a requirement to get a 3rd site connecting into Site-BB. But when I create a new Dialer interface the original connection won't come up.
Here are the details:
hostname Site-BB
ip cef
no ip bootp server
ip name-server 192.168.1.105
isdn switch-type basic-net3
username SIte-HQ password xxxxxxxxxx
interface BRI0
no ip address
no ip redirects
no ip unreachables
no ip proxy-arp
ip flow ingress
encapsulation ppp
dialer pool-member 2
isdn point-to-point-setup
interface ATM0
no ip address
no ip redirects
no ip unreachables
no ip proxy-arp
ip flow ingress
no atm ilmi-keepalive
interface FastEthernet0
interface FastEthernet1
interface Vlan1
description $ETH-SW-LAUNCH$$INTF-INFO-HWIC 4ESW$$ES_LAN$$FW_INSIDE$
ip address 192.168.4.250 255.255.255.0
no ip redirects
no ip unreachables
no ip proxy-arp
ip flow ingress
ip nat inside
ip virtual-reassembly
ip tcp adjust-mss 1452
interface Dialer0
no ip address
interface Dialer1
no ip address
encapsulation ppp
dialer pool 1
dialer idle-timeout 20
dialer string 0191730044
dialer string 0191730066
dialer-group 1
no cdp enable
ppp authentication chap pap callin
ppp chap hostname Site-BB
ppp chap password xxxxxxxxx
ppp pap sent-username Site-BB password xxxxxxx
interface Dialer3
ip address 10.0.4.1 255.255.255.0
encapsulation ppp
dialer pool 2
dialer-group 2
no cdp enable
ppp pap sent-username Site-BB password xxxxxxxxxx
ip forward-protocol nd
ip route 0.0.0.0 0.0.0.0 Dialer3
ip route 192.168.1.1 255.255.255.255 192.168.4.254
ip route 192.168.1.4 255.255.255.255 192.168.4.254
ip route 192.168.1.5 255.255.255.255 192.168.4.254
ip route 192.168.1.6 255.255.255.255 192.168.4.254
ip route 192.168.1.105 255.255.255.255 Dialer3
ip route 192.168.1.151 255.255.255.255 192.168.4.254
ip route 192.168.1.153 255.255.255.255 192.168.4.254
ip http server
ip http authentication local
ip http secure-server
ip http timeout-policy idle 60 life 86400 requests 10000
ip nat inside source list 1 interface Dialer0 overload
ip nat outside source static network 192.168.1.105 192.168.4.250 /32
ip access-list extended OutSIte-HQ
remark out to SIte-HQ
remark SDM_ACL Category=1
remark out to HQ
permit ip 192.168.4.0 0.0.0.255 10.0.4.0 0.0.0.255
ip access-list extended inboundSIte-HQ
remark inboundSIte-HQ
permit ip 10.0.4.0 0.0.0.255 192.168.4.0 0.0.0.255
logging trap debugging
access-list 1 remark INSIDE_IF=Vlan1
access-list 1 remark SDM_ACL Category=3
access-list 1 permit 192.168.4.0 0.0.0.255
dialer-list 1 protocol ip permit
dialer-list 2 protocol ip permit
no cdp run
control-plane
banner login ^CCCCCCCCCCCCCCCCCAuthorized access only!
no inservice
end
______________
So above works fine both ways; when I add the new details below for the new site - it stops working
interface BRI0
dialer pool-member 3
! (now BRI0 has pool-member 2 and 3)
interface Dialer99
description ISDN_to_New-site
ip address 192.168.99.74 255.255.255.0
encapsulation ppp
dialer pool 3
dialer string 0167115500
dialer-group 2
pulse-time 0
ppp chap password 0 xxx
ppp pap sent-username Site-BB password 0xxx
ip route 192.168.200.0 255.255.255.0 dialer99
!___________________________________
Obviously I now need to be able to have ISDN access Site-BB from both HQ-Site and New-site. Any help appreciated. Thanks
_____________
June 7th...
I understand I will need to add the new subnet to the access list; however, the problem is that once the new Dialer99 is added to the config the HO router cannot access Site-BB (using Dialer3). I need to have this working as normal before testing access from the New-site (using Dialer99).
Hall of Fame Super Silver
Re: Cisco 870 ISDN problem
Hello T.connor,
I suspect that the BRI can be pool member of only one dialer pool at the same time.
No, actually it is supported see DIAL command reference
http://www.cisco.com/en/US/docs/ios/dial/command/reference/dia_d1.html#wp1033489
So the second dialer that you add dialer99 might use the same dialer pool 2 as the first dialer dialer3.
The dialer pool defines a set of resources that in your case are the two B channels of the BRI interface.
There is another aspect that needs to be addressed: if a call is in place it can take both B channels of the BRI leaving no chance to place the second call.
You could add to both dialer the command
dialer load-threshold 255
in order to reduce the chance that the second B channel is used in the call
There is a specific command to specify the max number of calls
dialer max-call 1
in your case to indicate only one B channel to be used. Configure it only on this router not on the other ones.
Hope to help
Giuseppe
Thanks for the reply. From Cisco ...
http://www.cisco.com/en/US/docs/ios/12_0/dial/command/reference/drdiprof.html#wp4903
interface BRI1
encapsulation ppp
dialer pool-member 1 priority 50
dialer pool-member 2 priority 50
!BRI 1 has a reserved channel in dialer pool 3; the channel remains
inactive
!until BRI 1 uses it to place calls.
dialer pool-member 3 min-link 1
Terry O'Connor
giuslar
To:
Terry O'Connor1/Ireland/IBM@IBMIE
Date:
06/06/2012 14:58
Subject:
- Re: Cisco 870 ISDN problem
Home
created by Giuseppe Larosa in WAN, Routing and Switching - View the full
discussion
Hello T.connor,
same time.
So the second dialer that you add dialer99 should use the same dialer pool
second call.
call
Hope to help
Giuseppe
Reply to this message by going to Home
Start a new discussion in WAN, Routing and Switching at Home
Hello T.conner
yes I have seen the command reference
however, the suggestion to limit to one B channel each dialer interface might be helpful
see
dialer max-call 1
http://www.cisco.com/en/US/docs/ios/dial/command/reference/dia_d1.html#wp1013853
to be put in each dialer interface configuration to allow space for the second call
Hope to help
Giuseppe
OK - I will change both Dialers to be in the same dialer pool (pool 2).
Also, do you think I need to configure the original Dialer3 and new
Dialer99 with both these commands?
dialer max-call 1
Terry O'Connor
giuslar
To:
Date:
06/06/2012 15:12
Subject:
Home
discussion
Hello T.conner
might be helpful
see
dialer max-call 1
second call
Hope to help
Giuseppe
OK - still no joy - dialer load threshold & dialer max-calls entered ...
would the access list be an issue here ?
Terry O'Connor
dialer max-call 1
Terry O'Connor
giuslar
To:
Date:
06/06/2012 15:12
Subject:
Home
discussion
Hello T.conner
might be helpful
see
dialer max-call 1
second call
Hope to help
Giuseppe
Here is the ISDN debug after I add the new Dialer interface. The HQ site
attempts connection on the original Dialer3 but fails;
Hello t.oconnor,
I don't see the debug output use the attach file option to attach a txt file with the debug output.
In any case the dialer list have to be more specific now, as you want to dial to new remote site only when traffic to remote site IP subnet 192.168.200.0 is present.
access-list 102 permit ip any 192.168.200.0 0.0.0.255
dialer-list 2 protocol ip 102
There is a way to invoke an IP extended access-list like in the example above (check the syntax I have written on the fly)
For the other site you can invoke an ACL that is made in the following manner
access-list 101 deny ip any 192.168.200.0 0.0.0.255
access-lit 101 permit ip any any
Notice that in this way whatever packet your router has to send it will dial. So you may need to tune this.
Hope to help
Giuseppe
I have attached the ISDn debug. I understand I will need to add the new subnet to the access list;  however, the problem is that once the new Dialer99 is added to the  config the HO router cannot access Site-BB (using Dialer3). I need to  have this working as normal before testing access from the New-site  (using Dialer99).
Hello t.connor,
from ISDN debug output when both dialer interfaces are configured the router rejects the incoming call with error
>> Cause i = 0x8095 - Call rejected
the following document describes the ISDN error codes that appear in the output of debug isdn q931
http://www.cisco.com/en/US/tech/tk801/tk379/technologies_tech_note09186a008012e95f.shtml
The first byte (most significant) after 0x indicates the point in the       circuit path where the disconnect cause code appears
80—the router
The next byte (9F in the sample output) that follows the cause code       origination point byte is the Disconnect Cause Code
85
Misdialled trunk prefix.
The remote number you dialed is not reachable.
Check the number you dial. Verify if you need any prefixes to                 access the network. For example, you need to dial 9 for outbound calls through                 a PBX. Contact your telco/PBX administrator for details.
The problem is that the router is not able to bind a BRI channel when both dialer interfaces are configured and enabled.
Edit:
your configuration looks like incomplete it is good for calling out not for receiving.
i think you would need some
dialer map
command in order to discriminate incoming calls on the two dialer interfaces
I remember I have used dialer map commands on receiving side in interface dialer.
The command is also useful when you want to call different destinations with a single dialer interface.
see
http://www.cisco.com/en/US/docs/ios/dial/command/reference/dia_d1.html#wp1013440
Hope to help
Giuseppe
yes dialer map ip commands on ISDN Hub router should be the way to go
Router(config-if)# dialer map protocol  next-hop-address name hostname
For any host calling in to the local router or access server, maps its  host name (case-sensitive) to the next hop address used to reach it.
Repeat this step for each host calling in to this interface.
see
http://www.cisco.com/en/US/docs/ios/dial/configuration/guide/dia_cfg_ddr_hubs_ps6441_TSD_Products_Configuration_Guide_Chapter.html#wp1001105
The problem you face is that the router is not able to understand what dialer interface to use when answering the call when two dialer interfaces are configured and running. This should be the reason for the ISDN error seen in the debug isdn q931 not bindable.
Hope to help
Giuseppe
Hi, Dialer Maps are for "legacy" DDR. I am using Dialer Profiles and cannot configure dialer maps on the Dialer interface.
Hello T.oconnor,
I have used dialer-maps with dialer interfaces in the past it is a way to provide a resolve mechanism to allow the router to decide which dialer should answer the incoming call when multiple interface dialer are defined.
What can tell the router in your configuration what dialer to use when answering an incoming call? This is why you have troubles with two dialer interfaces
In my configuration I needed to map incoming call to a different MPLS VPN based on dialer map VRF aware feature.
I was using C7200 as PE ISDN and these were backup links for MPLS VPN. The C7200 had ISDN E1 and calling CE nodes had BRI interface.
Hope to help
Giuseppe
The following points describe several design factors you should decide on before configuring a DDR link.
  • DDR Implementation: You can use dialer maps (legacy DDR) or dialer   profiles. For more information on the differences between these two   implementations, refer to "Configuring ISDN DDR with Dialer Profiles"  In this configuration we use dialer maps.
  • above fron Cisco
When I am in config mode on interface dialer99 there are no  commands available to configure dialer maps...can you provide an  example?
Building configuration...
Current configuration : 279 bytes
interface Dialer99
ip address 10.0.73.99 255.255.255.0
encapsulation ppp
dialer pool 3
pulse-time 0
ppp chap hostname Site-bb
ppp pap sent-username Site-bb password 0 xxx
end
Site-bb#
Site-bb#conf t
Enter configuration commands, one per line.  End with CNTL/Z.
Site-bb(config)#int d99
Site-bb(config-if)#?
Interface configuration commands:
  access-expression       Build a bridge boolean access expression
  appletalk               Appletalk interface subcommands
  arp                     Set arp type (arpa, probe, snap) or timeout
  autodetect              Autodetect Encapsulations on Serial interface
  bandwidth               Set bandwidth informational parameter
  bridge-group            Transparent bridging interface parameters
  carrier-delay           Specify delay for interface transitions
  cdp                     CDP interface subcommands
  clock                   Configure serial interface clock
  compress                Set serial interface for compression
  cpp                     Combinet Proprietary Protocol
  custom-queue-list       Assign a custom queue list to an interface
  decnet                  Interface DECnet config commands
  default                 Set a command to its defaults
  delay                   Specify interface throughput delay
  description             Interface specific description
  dialer                  Dial-on-demand routing (DDR) commands
  dialer-group            Assign interface to dialer-list
  down-when-looped        Force looped serial interface down
  dxi                     ATM-DXI configuration commands
  encapsulation           Set encapsulation type for an interface
  exit                    Exit from interface configuration mode
  fair-queue              Enable Fair Queuing on an Interface
  full-duplex             Configure full-duplex operational mode
  half-duplex             Configure half-duplex and related commands
  help                    Description of the interactive help system
  hold-queue              Set hold queue depth
  ip                      Interface Internet Protocol config commands
  ipx                     Novell/IPX interface subcommands
  keepalive               Enable keepalive
  lapb                    X.25 Level 2 parameters (Link Access Procedure,
                          Balanced)
  line-power              Provide power on the line.
  llc2                    LLC2 Interface Subcommands
  load-interval           Specify interval for load calculation for an
                          interface
  logging                 Configure logging for interface
  loopback                Configure internal loopback on an interface
  mac-address             Manually set interface MAC address
  max-reserved-bandwidth  Maximum Reservable Bandwidth on an Interface
  mop                     DEC MOP server commands
  mtu                     Set the interface Maximum Transmission Unit (MTU)
  multilink               Configure multilink parameters
  multilink-group         Put interface in a multilink bundle
  netbios                 Use a defined NETBIOS access list or enable
                          name-caching
  network-clock-priority  Configure clock source priority
  no                      Negate a command or set its defaults
  ntp                     Configure NTP
  peer                    Peer parameters for point to point interfaces
  ppp                     Point-to-Point Protocol
  priority-group          Assign a priority group to an interface
  pulse-time              Force DTR low during resets
  random-detect           Enable Weighted Random Early Detection (WRED) on an
                          Interface
  rate-limit              Rate Limit
  serial                  serial interface commands
  service-policy          Configure QoS Service Policy
  shutdown                Shutdown the selected interface
  smds                    Modify SMDS parameters
  smrp                    Simple Multicast Routing Protocol interface
                          subcommands
  snapshot                Configure snapshot support on the interface
  snmp                    Modify SNMP interface parameters
  source                  Get config from another source
  timeout                 Define timeout values for this interface
  transmit-interface      Assign a transmit interface to a receive-only
                          interface
  trunk-group             Configure interface to be in a trunk group
  tx-ring-limit           Configure PA level transmit ring limit
Site-bb(config-if)#dialer ?
  callback-secure        Enable callback security
  called                 Specify called telephone number to be screened
  caller                 Specify calling telephone number to be screened
  enable-timeout         Set length of time an interface stays down before it
                         is available for dialing
  fast-idle              Set idle time before disconnecting line with an
                         unusually high level of contention
  hold-queue             Configure output hold queue
  idle-timeout           Specify idle timeout before disconnecting line
  in-band                Set v.25bis dialing for interface
  load-threshold         Specify threshold for placing additional calls
  max-call               Specify maximum number of calls
  pool                   Specify dialer pool to be used
  redial                 Configure redial for this interface
  remote-name            Configure a remote name
  rotor                  Set outbound rotor order
  snapshot               Enable snapshot address for dialer profile
  string                 Specify telephone number to be passed to DCE device
  vpdn                   Enable vpdn dial
  wait-for-carrier-time  How long the router will wait for carrier
  watch-disable          Time to wait before bringing down watched route link
  watch-group            Assign interface to dialer-watch-list
--More--
Hello T.oconnor,
try to enable
dialer in-band
first,
It is present in my configurations.
Hope to help
Giuseppe
Hi Giuseppe,
http://www.cisco.com/en/US/docs/ios/12_0/dial/command/reference/drspoke.html
LEGACY DDR SPOKES COMMANDS
You must be using Legacy DDR - I cannot use Legacy as I have > 50 sites already configured with Dialer Profiles...
Site-bb(config)#int d1
Site-bb(config-if)#dialer in
Site-bb(config-if)#dialer in-band
%Remove dialer profile config first
Site-bb(config-if)#
I am attaching the latest debig from both sites - the "headoffice" and remote "site-bb"; the isdn is tryingf to connect from headoffice - I believe the authentication is failing...
801
