Cisco 871 Help
wlewis2488
I have an issue with a Cisco 871. I have a dsl modem in Bridging mode connect to provide connectivity thru the WAN port to the 871, and then have a VPN tunnel back to my network. When the provider internet goes down, and comes back up, the public side to my router works fine, but it is as if the private side doesn't autonegoiate. If I plug my laptop in to the router, pull a webpage, the router then starts working. It is as if the router is going to sleep. Any suggestions?
My provider looses connectivity very often.
You should set the source interface to the LAN side-
icmp-echo 173.194.33.116 source-interface GigabitEthernet0/1
7 Replies 7
Collin Clark
You can try upgrading your IOS, could be a bug. You could also configure IPSLA to ping an internet host every minute or so and see if that alleivates you having to plug in your laptop each time.
I have a monitoring tool that pings every 60 seconds. The issue is the router is located in a remote location that is 45 minutes away. Two trips this week and 4 this month alone, not very efficient.
You can configure IPSLA on the remote router and have it source the pings from the LAN side interface. That should replicate you plugging in your laptop and going to a web page.
Thank you for the advice, I enabled the following.
ip sla 1
frequency 30
ip sla schedule 1 life forever start-time now
Please advise any needed changes.
The running config is now;
ip sla 1
icmp-echo 173.194.33.116 source-interface FastEthernet1
frequency 30
Looks good. Just as an FYI you can check the results with-
show ip sla statistics 1
There should be some successes.
