IT
Cisco 871, VLAN down ?
Hi all!
We have a problem with a cisco 871.
If all ports of the integrated switch have no link, the vlan gones down and it is not longer possible to access the lan-IP from the WAN. How can we force the VLAN up ?
Hall of Fame Super Blue
Re: Cisco 871, VLAN down ?
Under the vlan interface try entering
"no autostate"
Jon
Silver
That's true..
Here is the few commands for VLAN
Go into VLAN Interface - > No shut
no autostate
Dharmesh Purohit
IT
Sorry, we are just new to this business ...
>config term
>int vlan1
>no autostate
gives:% Invalid input detected at '^' maker. (pointing to state)
Seams that the command "autostate" is not known.
You may have an old version of IOS firmware that doesn't support it.
I just tried it on an 871 I had lying around and it works fine for me running IOS v12.4(11)
Router(config)#int vlan 1
Router(config-if)#no autostate
Router(config-if)#exit
Router(config)#
*Jan 13 01:42:16.403: %LINEPROTO-5-UPDOWN: Line protocol on Interface Vlan1, changed state to up
Router(config)#exit
IT
Current Version is 12.4(4)T7.
We are just waiting for our PICA-Access, then we'll donwload a newer version ...
Thanks !
626
