Cisco 876 pppoe with bridged modem
Hello sirs,
Im new to this so please forgive my ignorance,i have a cisco 876 router running advipservicesk9-mz.124-15.T17 ios,my adsl2+ line is Pstn so i figured i could use this router with a zyxel modem in bridged mode,after much frustration and search over the web i finaly got it to work,i also used Cisco CCP to apply a zone firewall in low mode since i know very little about firewalls,im posting my configuration below and i would appreciate any feedback as to whether is correct or not and also is there a way to create a second Vlan so that the zyxel modem would be accessed through a different network that of my primary vlan?
Thanks in advance
Building configuration...
Current configuration : 9546 bytes
version 12.4
no service pad
service tcp-keepalives-in
service tcp-keepalives-out
service timestamps debug datetime msec localtime show-timezone
service timestamps log datetime msec localtime show-timezone
service password-encryption
service sequence-numbers
hostname Kerberos
boot-start-marker
boot system flash:c870-advipservicesk9-mz.124-15.T17.bin
boot-end-marker
security authentication failure rate 3 log
security passwords min-length 6
no logging buffered
logging console critical
enable secret 5 $1$26AC$XdfeeI/jEufq7z71fGib..
aaa new-model
aaa authentication login default local enable
aaa authentication login clientauth local
aaa authentication login local_authen local
aaa authorization exec local_author local
aaa authorization network groupauthor local
aaa session-id common
clock timezone Athens 2
crypto pki trustpoint TP-self-signed-2038751039
enrollment selfsigned
subject-name cn=IOS-Self-Signed-Certificate-2038751039
revocation-check none
rsakeypair TP-self-signed-2038751039
crypto pki certificate chain TP-self-signed-2038751039
certificate self-signed 01
  3082024A 308201B3 A0030201 02020101 300D0609 2A864886 F70D0101 04050030
  31312F30 2D060355 04031326 494F532D 53656C66 2D536967 6E65642D 43657274
  69666963 6174652D 32303338 37353130 3339301E 170D3134 30323033 31373433
  31385A17 0D323030 31303130 30303030 305A3031 312F302D 06035504 03132649
  4F532D53 656C662D 5369676E 65642D43 65727469 66696361 74652D32 30333837
  35313033 3930819F 300D0609 2A864886 F70D0101 01050003 818D0030 81890281
  8100D75B 9761DA15 E795851C 4019BE5D B9A3EB77 DB917493 CAECE885 EB7DD2E7
  77C7ADBE 644319A3 8A4D87D5 D3AFA9A1 9CF9D7C6 0EE25F06 349FDB95 D05D999F
  1860CA4E 0B0E9188 ADD87800 603CFDF4 44B91064 CD0E3FA9 81EF1A8F C852B781
  E083ED39 58D91081 639A8067 8E692FDC 6E09F420 837B33DD CF564DBA 54B1CDF2
  97F90203 010001A3 72307030 0F060355 1D130101 FF040530 030101FF 301D0603
  551D1104 16301482 124B6572 6265726F 732E6368 616F732E 636F6D30 1F060355
  1D230418 30168014 816950C6 34F3AFC1 6F4C7A32 3F77A6AD CBBD521E 301D0603
  551D0E04 16041481 6950C634 F3AFC16F 4C7A323F 77A6ADCB BD521E30 0D06092A
  864886F7 0D010104 05000381 81007F04 AADCCD51 E5A40D72 5AE6C04C 20ED53C6
  3546F182 6DA245E5 7C1198E2 FEB4F95D 7440C752 56236EB3 C0A3AD94 667499A5
  BBEC2C5F ABADA946 F5F609B7 9FC9EBF3 CEEC63F2 E1449E14 B75D898B D61CCC29
  42F60E54 0E81A601 FE4AFF81 256AF987 A68477E0 0372714F 00769659 94E7AFEA
  ED3C42A3 8DF1862C 9B7FDEBF BAB0
      quit
dot11 syslog
no ip source-route
ip cef
no ip bootp server
ip domain name chaos.com
username babz privilege 15 password 7 110D000B16011F15
archive
log config
  hidekeys
ip tcp synwait-time 10
ip ssh time-out 60
ip ssh authentication-retries 2
class-map type inspect match-any ccp-skinny-inspect
match protocol skinny
class-map type inspect match-any ccp-cls-insp-traffic
match protocol cuseeme
match protocol dns
match protocol ftp
match protocol https
match protocol icmp
match protocol imap
match protocol pop3
match protocol netshow
match protocol shell
match protocol realmedia
match protocol rtsp
match protocol smtp extended
match protocol sql-net
match protocol streamworks
match protocol tftp
match protocol vdolive
match protocol tcp
match protocol udp
class-map type inspect match-all ccp-insp-traffic
match class-map ccp-cls-insp-traffic
class-map type inspect match-any ccp-cls-icmp-access
match protocol icmp
match protocol tcp
match protocol udp
class-map type inspect match-any ccp-h225ras-inspect
match protocol h225ras
class-map type inspect match-any ccp-h323-inspect
match protocol h323
class-map type inspect match-all ccp-invalid-src
match access-group 100
class-map type inspect match-all ccp-icmp-access
match class-map ccp-cls-icmp-access
class-map type inspect match-any ccp-sip-inspect
match protocol sip
class-map type inspect match-all ccp-protocol-http
match protocol http
policy-map type inspect ccp-permit-icmpreply
class type inspect ccp-icmp-access
  inspect
class class-default
  pass
policy-map type inspect ccp-inspect
class type inspect ccp-invalid-src
  drop log
class type inspect ccp-protocol-http
  inspect
class type inspect ccp-insp-traffic
  inspect
class type inspect ccp-h323-inspect
  inspect
class type inspect ccp-h225ras-inspect
  inspect
class class-default
class class-default
zone security in-zone
zone security out-zone
zone-pair security ccp-zp-out-self source out-zone destination self
service-policy type inspect ccp-permit
zone-pair security ccp-zp-in-out source in-zone destination out-zone
service-policy type inspect ccp-inspect
zone-pair security ccp-zp-self-out source self destination out-zone
service-policy type inspect ccp-permit-icmpreply
interface Null0
no ip unreachables
interface BRI0
no ip address
no ip redirects
no ip unreachables
no ip proxy-arp
encapsulation hdlc
ip route-cache flow
shutdown
interface ATM0
no ip address
no ip redirects
no ip unreachables
no ip proxy-arp
ip route-cache flow
shutdown
no atm ilmi-keepalive
dsl operating-mode auto
interface FastEthernet0
description ADSL WAN Interface
pppoe enable group global
pppoe-client dial-pool-number 1
no cdp enable
interface FastEthernet1
no cdp enable
interface FastEthernet2
no cdp enable
interface FastEthernet3
no cdp enable
interface Vlan1
description $ETH-SW-LAUNCH$$INTF-INFO-HWIC 4ESW$$FW_INSIDE$
ip address 192.168.1.200 255.255.255.0
ip access-group 101 in
no ip redirects
no ip unreachables
no ip proxy-arp
ip nat inside
ip virtual-reassembly
zone-member security in-zone
ip route-cache flow
interface Dialer1
description ADSL WAN Dialer$FW_OUTSIDE$
ip address negotiated
no ip redirects
no ip unreachables
no ip proxy-arp
ip mtu 1452
ip nat outside
zone-member security out-zone
encapsulation ppp
ip route-cache flow
no ip mroute-cache
dialer pool 1
dialer-group 1
no cdp enable
ppp chap hostname *****************************
ppp chap password 7 *********************
ppp ipcp dns request
ppp ipcp route default
ip forward-protocol nd
ip http server
ip http access-class 7
ip http authentication local
ip http secure-server
ip http timeout-policy idle 60 life 86400 requests 10000
ip nat translation finrst-timeout 120
ip nat inside source list 1 interface Dialer1 overload
no logging trap
access-list 1 remark CCP_ACL Category=2
access-list 1 permit 192.168.1.0 0.0.0.255
access-list 7 remark HTTP Access-class list
access-list 7 remark CCP_ACL Category=1
access-list 7 permit 192.168.1.230
access-list 7 permit 192.168.1.0 0.0.0.255
access-list 7 deny   any
access-list 8 remark CCP_ACL Category=2
access-list 8 permit 192.168.1.0 0.0.0.255
access-list 9 remark CCP_ACL Category=2
access-list 9 permit 192.168.1.0 0.0.0.255
access-list 100 remark CCP_ACL Category=128
access-list 100 permit ip host 255.255.255.255 any
access-list 100 permit ip 127.0.0.0 0.255.255.255 any
access-list 101 remark Auto generated by SDM Management Access feature
access-list 101 remark CCP_ACL Category=1
access-list 101 permit tcp host 192.168.1.230 host 192.168.1.200 eq telnet
access-list 101 permit tcp host 192.168.1.230 host 192.168.1.200 eq 22
access-list 101 permit tcp host 192.168.1.230 host 192.168.1.200 eq www
access-list 101 permit tcp host 192.168.1.230 host 192.168.1.200 eq 443
access-list 101 permit tcp host 192.168.1.230 host 192.168.1.200 eq cmd
access-list 101 deny   tcp any host 192.168.1.200 eq telnet
access-list 101 deny   tcp any host 192.168.1.200 eq 22
access-list 101 deny   tcp any host 192.168.1.200 eq www
access-list 101 deny   tcp any host 192.168.1.200 eq 443
access-list 101 deny   tcp any host 192.168.1.200 eq cmd
access-list 101 deny   udp any host 192.168.1.200 eq snmp
access-list 101 permit ip any any
access-list 102 remark Auto generated by SDM Management Access feature
access-list 102 remark CCP_ACL Category=1
access-list 102 permit ip host 192.168.1.230 any
no cdp run
control-plane
banner login ^CC
|                     CHAOS                             |
| UNAUTHORIZED ACCESS TO THIS NETWORK DEVICE AND        |
| ATTACHED NETWORKS IS STRICTLY PROHIBITED.             |
| You must have explicit permission to access or        |
| configure this device. All activities performed on    |
| this device may be logged or monitored without further|
| notice, and the resulting logs may be used as evidence|
| in court.                                             |
| Any unauthorized use of the system is unlawful, and   |
| may be subject to civil and/or criminal penalties.    |
^C
line con 0
login authentication local_authen
no modem enable
transport output telnet
line aux 0
line vty 0 4
access-class 102 in
transport input telnet ssh
scheduler max-task-time 5000
scheduler allocate 4000 1000
scheduler interval 500
end
you can't make it a L3 routed port so  if you have ios 15 you can do an intra zone policy with ZBF  or you can maybe put a L2 access-list if it is possible on this platform but I'm not sure it is.
Alain
27 Replies 27
Anyone??
for second vlan:
-on interface where a device in this vlan is connected:
int f1/x
switchport access vlan x
-create the SVI:
int vlan 2
ip address 192.168.2.254 255.255.255.0
-make this interface part of inside zone
int vlan 2
Alain
Hello Akain,i tried your example
int vlan 2
ip address 10.10.10.2 255.255.255.0
interface fae0
switchport access vlan 2
but then pppoe drops ,i tried restarting the dialer interface but it gets no ip from ISP
I forgot to edit ACL for NAT:
access-list 1 permit 10.10.10.0 0.0.0.255
This should have no impact on dialer interface getting an IP as you only changed the LAN.
Alain
Hi again,
Yet the same thing happens as soon a i enter switchport access vlan2 on ethernet0(thats the interface that the dialer uses to pppoe) the connection drops :S
of course this is on another interface not the one connected to the bridged modem
I hadn't remarked you had done this before.
Alain
So what you are saying is that this interface Fae0 thats on the bridged modem cannot change vlan? it must be always on 192.168.1.200?
Ive done this because my modem(zyxel) is a single port and im trying to maintain access on it but have it on a different network than my lan
You're running PPPoE on this interface and so this is the dialer interface which gets an IP from PPP and this is your outside interface.
your vlan interface is for L3 access for clients  connected to L2 ports in the corresponding VLAN, these are the inside Interfaces
Oh and I realize I forgot still one thing, you have to enable nat with ip nat inside on the corresponding interface vlan
otherwise traffic won't get natted, I forgot lots of basic stuffs when replying for this thread(I'm a little bit tired  these days and I reply too fast without making my brain work  )
Alain
Thank you very much for your input,what you mention makes absolute sense,what i cannot understand is why if i leave the config as it is ,i have access to the bridged modem through Fae0(dialer interface)
which config, the one you had before?
What don't you understand ?
Alain
Yes the one i posted above,with that configuration im able to access the zyxel,through fae0,the same port that dialer1 uses,is the port thats connected to the zyxel,im sorry if my questions seem stupid but im trying to learn and have no previous experience on cisco routers
I don't understand exactly what you want to know ?
Could you clarify please.
Alain
Hello and thnanks again for spending time to help out,
look
c876(192.168.1.200)ethernet0---------->zyxel(192.168.100) in bridged mode thats how its connected,what i dont understand is why i  can still access the zyxel web interface, ethernet0 on the 876 is supposed to be dialers interface and it works that way just fine ,but it also works as a lan interface..
µok so all 4 ethernet ports on the 876 are switch ports so are you sure your zyxel is indeed bridging because the dialer interface should be linked to a L3 port as far as I know.
Can you provide following output:
-sh ip int br
-sh ip route
Alain
