Cisco 876 pppoe with bridged modem
Hello sirs,
Im new to this so please forgive my ignorance,i have a cisco 876 router running advipservicesk9-mz.124-15.T17 ios,my adsl2+ line is Pstn so i figured i could use this router with a zyxel modem in bridged mode,after much frustration and search over the web i finaly got it to work,i also used Cisco CCP to apply a zone firewall in low mode since i know very little about firewalls,im posting my configuration below and i would appreciate any feedback as to whether is correct or not and also is there a way to create a second Vlan so that the zyxel modem would be accessed through a different network that of my primary vlan?
Thanks in advance
Building configuration...
Current configuration : 9546 bytes
version 12.4
no service pad
service tcp-keepalives-in
service tcp-keepalives-out
service timestamps debug datetime msec localtime show-timezone
service timestamps log datetime msec localtime show-timezone
service password-encryption
service sequence-numbers
hostname Kerberos
boot-start-marker
boot system flash:c870-advipservicesk9-mz.124-15.T17.bin
boot-end-marker
security authentication failure rate 3 log
security passwords min-length 6
no logging buffered
logging console critical
enable secret 5 $1$26AC$XdfeeI/jEufq7z71fGib..
aaa new-model
aaa authentication login default local enable
aaa authentication login clientauth local
aaa authentication login local_authen local
aaa authorization exec local_author local
aaa authorization network groupauthor local
aaa session-id common
clock timezone Athens 2
crypto pki trustpoint TP-self-signed-2038751039
enrollment selfsigned
subject-name cn=IOS-Self-Signed-Certificate-2038751039
revocation-check none
rsakeypair TP-self-signed-2038751039
crypto pki certificate chain TP-self-signed-2038751039
certificate self-signed 01
  3082024A 308201B3 A0030201 02020101 300D0609 2A864886 F70D0101 04050030
  31312F30 2D060355 04031326 494F532D 53656C66 2D536967 6E65642D 43657274
  69666963 6174652D 32303338 37353130 3339301E 170D3134 30323033 31373433
  31385A17 0D323030 31303130 30303030 305A3031 312F302D 06035504 03132649
  4F532D53 656C662D 5369676E 65642D43 65727469 66696361 74652D32 30333837
  35313033 3930819F 300D0609 2A864886 F70D0101 01050003 818D0030 81890281
  8100D75B 9761DA15 E795851C 4019BE5D B9A3EB77 DB917493 CAECE885 EB7DD2E7
  77C7ADBE 644319A3 8A4D87D5 D3AFA9A1 9CF9D7C6 0EE25F06 349FDB95 D05D999F
  1860CA4E 0B0E9188 ADD87800 603CFDF4 44B91064 CD0E3FA9 81EF1A8F C852B781
  E083ED39 58D91081 639A8067 8E692FDC 6E09F420 837B33DD CF564DBA 54B1CDF2
  97F90203 010001A3 72307030 0F060355 1D130101 FF040530 030101FF 301D0603
  551D1104 16301482 124B6572 6265726F 732E6368 616F732E 636F6D30 1F060355
  1D230418 30168014 816950C6 34F3AFC1 6F4C7A32 3F77A6AD CBBD521E 301D0603
  551D0E04 16041481 6950C634 F3AFC16F 4C7A323F 77A6ADCB BD521E30 0D06092A
  864886F7 0D010104 05000381 81007F04 AADCCD51 E5A40D72 5AE6C04C 20ED53C6
  3546F182 6DA245E5 7C1198E2 FEB4F95D 7440C752 56236EB3 C0A3AD94 667499A5
  BBEC2C5F ABADA946 F5F609B7 9FC9EBF3 CEEC63F2 E1449E14 B75D898B D61CCC29
  42F60E54 0E81A601 FE4AFF81 256AF987 A68477E0 0372714F 00769659 94E7AFEA
  ED3C42A3 8DF1862C 9B7FDEBF BAB0
      quit
dot11 syslog
no ip source-route
ip cef
no ip bootp server
ip domain name chaos.com
username babz privilege 15 password 7 110D000B16011F15
archive
log config
  hidekeys
ip tcp synwait-time 10
ip ssh time-out 60
ip ssh authentication-retries 2
class-map type inspect match-any ccp-skinny-inspect
match protocol skinny
class-map type inspect match-any ccp-cls-insp-traffic
match protocol cuseeme
match protocol dns
match protocol ftp
match protocol https
match protocol icmp
match protocol imap
match protocol pop3
match protocol netshow
match protocol shell
match protocol realmedia
match protocol rtsp
match protocol smtp extended
match protocol sql-net
match protocol streamworks
match protocol tftp
match protocol vdolive
match protocol tcp
match protocol udp
class-map type inspect match-all ccp-insp-traffic
match class-map ccp-cls-insp-traffic
class-map type inspect match-any ccp-cls-icmp-access
match protocol icmp
match protocol tcp
match protocol udp
class-map type inspect match-any ccp-h225ras-inspect
match protocol h225ras
class-map type inspect match-any ccp-h323-inspect
match protocol h323
class-map type inspect match-all ccp-invalid-src
match access-group 100
class-map type inspect match-all ccp-icmp-access
match class-map ccp-cls-icmp-access
class-map type inspect match-any ccp-sip-inspect
match protocol sip
class-map type inspect match-all ccp-protocol-http
match protocol http
policy-map type inspect ccp-permit-icmpreply
class type inspect ccp-icmp-access
  inspect
class class-default
  pass
policy-map type inspect ccp-inspect
class type inspect ccp-invalid-src
  drop log
class type inspect ccp-protocol-http
  inspect
class type inspect ccp-insp-traffic
  inspect
class type inspect ccp-h323-inspect
  inspect
class type inspect ccp-h225ras-inspect
  inspect
class class-default
class class-default
zone security in-zone
zone security out-zone
zone-pair security ccp-zp-out-self source out-zone destination self
service-policy type inspect ccp-permit
zone-pair security ccp-zp-in-out source in-zone destination out-zone
service-policy type inspect ccp-inspect
zone-pair security ccp-zp-self-out source self destination out-zone
service-policy type inspect ccp-permit-icmpreply
interface Null0
no ip unreachables
interface BRI0
no ip address
no ip redirects
no ip unreachables
no ip proxy-arp
encapsulation hdlc
ip route-cache flow
shutdown
interface ATM0
no ip address
no ip redirects
no ip unreachables
no ip proxy-arp
ip route-cache flow
shutdown
no atm ilmi-keepalive
dsl operating-mode auto
interface FastEthernet0
description ADSL WAN Interface
pppoe enable group global
pppoe-client dial-pool-number 1
no cdp enable
interface FastEthernet1
no cdp enable
interface FastEthernet2
no cdp enable
interface FastEthernet3
no cdp enable
interface Vlan1
description $ETH-SW-LAUNCH$$INTF-INFO-HWIC 4ESW$$FW_INSIDE$
ip address 192.168.1.200 255.255.255.0
ip access-group 101 in
no ip redirects
no ip unreachables
no ip proxy-arp
ip nat inside
ip virtual-reassembly
zone-member security in-zone
ip route-cache flow
interface Dialer1
description ADSL WAN Dialer$FW_OUTSIDE$
ip address negotiated
no ip redirects
no ip unreachables
no ip proxy-arp
ip mtu 1452
ip nat outside
zone-member security out-zone
encapsulation ppp
ip route-cache flow
no ip mroute-cache
dialer pool 1
dialer-group 1
no cdp enable
ppp chap hostname *****************************
ppp chap password 7 *********************
ppp ipcp dns request
ppp ipcp route default
ip forward-protocol nd
ip http server
ip http access-class 7
ip http authentication local
ip http secure-server
ip http timeout-policy idle 60 life 86400 requests 10000
ip nat translation finrst-timeout 120
ip nat inside source list 1 interface Dialer1 overload
no logging trap
access-list 1 remark CCP_ACL Category=2
access-list 1 permit 192.168.1.0 0.0.0.255
access-list 7 remark HTTP Access-class list
access-list 7 remark CCP_ACL Category=1
access-list 7 permit 192.168.1.230
access-list 7 permit 192.168.1.0 0.0.0.255
access-list 7 deny   any
access-list 8 remark CCP_ACL Category=2
access-list 8 permit 192.168.1.0 0.0.0.255
access-list 9 remark CCP_ACL Category=2
access-list 9 permit 192.168.1.0 0.0.0.255
access-list 100 remark CCP_ACL Category=128
access-list 100 permit ip host 255.255.255.255 any
access-list 100 permit ip 127.0.0.0 0.255.255.255 any
access-list 101 remark Auto generated by SDM Management Access feature
access-list 101 remark CCP_ACL Category=1
access-list 101 permit tcp host 192.168.1.230 host 192.168.1.200 eq telnet
access-list 101 permit tcp host 192.168.1.230 host 192.168.1.200 eq 22
access-list 101 permit tcp host 192.168.1.230 host 192.168.1.200 eq www
access-list 101 permit tcp host 192.168.1.230 host 192.168.1.200 eq 443
access-list 101 permit tcp host 192.168.1.230 host 192.168.1.200 eq cmd
access-list 101 deny   tcp any host 192.168.1.200 eq telnet
access-list 101 deny   tcp any host 192.168.1.200 eq 22
access-list 101 deny   tcp any host 192.168.1.200 eq www
access-list 101 deny   tcp any host 192.168.1.200 eq 443
access-list 101 deny   tcp any host 192.168.1.200 eq cmd
access-list 101 deny   udp any host 192.168.1.200 eq snmp
access-list 101 permit ip any any
access-list 102 remark Auto generated by SDM Management Access feature
access-list 102 remark CCP_ACL Category=1
access-list 102 permit ip host 192.168.1.230 any
no cdp run
control-plane
banner login ^CC
|                     CHAOS                             |
| UNAUTHORIZED ACCESS TO THIS NETWORK DEVICE AND        |
| ATTACHED NETWORKS IS STRICTLY PROHIBITED.             |
| You must have explicit permission to access or        |
| configure this device. All activities performed on    |
| this device may be logged or monitored without further|
| notice, and the resulting logs may be used as evidence|
| in court.                                             |
| Any unauthorized use of the system is unlawful, and   |
| may be subject to civil and/or criminal penalties.    |
^C
line con 0
login authentication local_authen
no modem enable
transport output telnet
line aux 0
line vty 0 4
access-class 102 in
transport input telnet ssh
scheduler max-task-time 5000
scheduler allocate 4000 1000
scheduler interval 500
end
27 Replies 27
yes offcourse im sure,its on bridge mode and i have internet, heres the output..
Kerberos#sh ip int
Kerberos#sh ip interface brie
Interface                  IP-Address      OK? Method Status                Prot               ocol
ATM0                       unassigned      YES NVRAM  administratively down down
BRI0                       unassigned      YES NVRAM  administratively down down
BRI0:1                     unassigned      YES unset  administratively down down
BRI0:2                     unassigned      YES unset  administratively down down
Dialer1                    62.1.59.176     YES IPCP   up                    up
FastEthernet0              unassigned      YES unset  up                    up
FastEthernet1              unassigned      YES unset  administratively down down
FastEthernet2              unassigned      YES unset  administratively down down
FastEthernet3              unassigned      YES unset  up                    up
NVI0                       unassigned      YES unset  administratively down down
Virtual-Access1            unassigned      YES unset  up                    up
Vlan1                      192.168.1.200   YES NVRAM  up                    up
Kerberos#sh ip route
Codes: C - connected, S - static, R - RIP, M - mobile, B - BGP
       D - EIGRP, EX - EIGRP external, O - OSPF, IA - OSPF inter area
       N1 - OSPF NSSA external type 1, N2 - OSPF NSSA external type 2
       E1 - OSPF external type 1, E2 - OSPF external type 2
       i - IS-IS, su - IS-IS summary, L1 - IS-IS level-1, L2 - IS-IS level-2
       ia - IS-IS inter area, * - candidate default, U - per-user static route
       o - ODR, P - periodic downloaded static route
Gateway of last resort is 213.16.246.30 to network 0.0.0.0
     213.16.246.0/32 is subnetted, 1 subnets
C       213.16.246.30 is directly connected, Dialer1
C    192.168.1.0/24 is directly connected, Vlan1
     62.0.0.0/32 is subnetted, 1 subnets
C       62.1.59.176 is directly connected, Dialer1
S*   0.0.0.0/0 [1/0] via 213.16.246.30
My pc is connected to ethernet3 oon c876 eth2 and eth1 are shutdown and eth0 is connected to the zyxel,and i can access the zyxel(192.168.1.100)
ok so it seems correct but you said that you could  communicate with the zyxel from the 876 ?
Can you show me that by pinging it after doing this:
enable
conf t
access-list 199 permit icmp any any
service timestamp debug uptime
logging buffer 7
do clear log
do debug ip pack deta 199
Then do your ping to zyxel and issue following command: do sh log
hit enter to get all and post output
Alain
Kerberos#sh log
Syslog logging: enabled (1 messages dropped, 0 messages rate-limited,
                0 flushes, 0 overruns, xml disabled, filtering disabled)
No Active Message Discriminator.
No Inactive Message Discriminator.
    Console logging: level critical, 0 messages logged, xml disabled,
                     filtering disabled
    Monitor logging: level debugging, 0 messages logged, xml disabled,
                     filtering disabled
    Buffer logging:  level debugging, 99 messages logged, xml disabled,
                     filtering disabled
    Logging Exception size (4096 bytes)
    Count and timestamp logging messages: disabled
    Persistent logging: disabled
No active filter modules.
ESM: 0 messages dropped
    Trap logging: disabled
Log Buffer (4096 bytes):
.92.36.124 (Dialer1), d=192.168.1.250 (Vlan1), routed via FIB
000364: 14:45:08: IP: s=84.92.36.124 (Dialer1), d=192.168.1.250 (Vlan1), len 123                                , dropped by inspect
000365: 14:45:08:     ICMP type=3, code=3
000366: 14:45:12: IP: tableid=0, s=79.160.77.241 (Dialer1), d=192.168.1.250 (Vla                                n1), routed via FIB
000367: 14:45:12: IP: s=79.160.77.241 (Dialer1), d=192.168.1.250 (Vlan1), len 12                                3, dropped by inspect
000368: 14:45:12:     ICMP type=3, code=3
000420: 14:45:54:     ICMP type=11, code=0
000421: 14:45:56: IP: tableid=0, s=112.198.111.142 (Dialer1), d=192.168.1.250 (Vlan1), routed via FIB
000422: 14:45:56: IP: s=112.198.111.142 (Dialer1), d=192.168.1.250 (Vlan1), len 123, dropped by inspect
000423: 14:45:56:     ICMP type=3, code=0
000424: 14:46:00: IP: tableid=0, s=79.161.66.79 (Dialer1), d=192.168.1.250 (Vlan1), routed via FIB
000425: 14:46:00: IP: s=79.161.66.79 (Dialer1), d=192.168.1.250 (Vlan1), len 56, dropped by inspect
000426: 14:46:00:     ICMP type=3, code=13
000427: 14:46:01: IP: tableid=0, s=180.234.250.77 (Dialer1), d=192.168.1.250 (Vlan1), routed via FIB
000428: 14:46:01: IP: s=180.234.250.77 (Dialer1), d=192.168.1.250 (Vlan1), len 123, dropped by inspect
000429: 14:46:01:     ICMP type=3, code=3
000430: 14:46:01: IP: tableid=0, s=68.43.230.66 (Dialer1), d=62.1.59.176 (Dialer1), routed via RIB
000431: 14:46:01: IP: s=68.43.230.66 (Dialer1), d=62.1.59.176 (Dialer1), len 123, rcvd 3
000432: 14:46:01:     ICMP type=3, code=1
000433: 14:46:01: IP: s=68.43.230.66 (Dialer1), d=62.1.59.176, len 123, dropped by local inspect
000434: 14:46:01:     ICMP type=3, code=1
000435: 14:46:02: IP: tableid=0, s=60.50.113.139 (Dialer1), d=192.168.1.250 (Vlan1), routed via FIB
000436: 14:46:02: IP: s=60.50.113.139 (Dialer1), d=192.168.1.250 (Vlan1), len 123, dropped by inspect
000437: 14:46:02:     ICMP type=3, code=3
000438: 14:46:03: IP: tableid=0, s=41.87.108.2 (Dialer1), d=192.168.1.250 (Vlan1), routed via FIB
000439: 14:46:03: IP: s=41.87.108.2 (Dialer1), d=192.168.1.250 (Vlan1), len 123, dropped by inspect
000440: 14:46:03:     ICMP type=3, code=1
000441: 14:46:06: IP: tableid=0, s=95.150.180.104 (Dialer1), d=192.168.1.250 (Vlan1), routed via FIB
000442: 14:46:06: IP: s=95.150.180.104 (Dialer1), d=192.168.1.250 (Vlan1), len 123, dropped by inspect
000443: 14:46:06:     ICMP type=3, code=1
000444: *Feb 12 22:55:24.016 Athens: %IP_VFR-4-FRAG_TABLE_OVERFLOW: Virtual-Access1: the fragment table has reached its maximum threshold 1695: 14:45:21:     ICMP type=8, code=0
.248.160.35 (Dialer1), d=192.168.1.250 (Vlan1), routed via FIB
000446: 14:46:10: IP: s=66.248.160.35 (Dialer1), d=192.168.1.250 (Vlan1), len 56, dropped by inspect
000447: 14:46:10:     ICMP type=3, code=3   ICMP type=0, code=0
000399: 14:45:22: IP: tableid=0, s=60.241.169.192 (Dialer1), d=192.168.1.250 (Vlan1), routed via FIB
000400: 14:45:22: IP: s=60.241.169.192 (Dialer1), d=192.168.1.250 (Vlan1), len 123, dropped by inspect
000401: 14:45:22:     ICMP type=3, code=1
000402: 14:45:23: IP: tableid=0, s=109.228.87.167 (Dialer1), d=192.168.1.250 (Vlan1), routed via FIB
000403: 14:45:23: IP: s=109.228.87.167 (Dialer1), d=192.168.1.250 (Vlan1), len 123, dropped by inspect
000404: 14:45:23:     ICMP type=3, code=3
000405: 14:45:23: IP: tableid=0, s=91.119.71.28 (Dialer1), d=192.168.1.250 (Vlan1), routed via FIB
000406: 14:45:23: IP: s=91.119.71.28 (Dialer1), d=192.168.1.250 (Vlan1), len 56, dropped by inspect
000407: 14:45:23:     ICMP type=3, code=13
000408: *Feb 12 22:54:47.256 Athens: %IP_VFR-4-FRAG_TABLE_OVERFLOW: Virtual-Access1: the fragment table has reached its maximum threshold 16
000409: 14:45:45: IP: tableid=0, s=86.163.47.171 (Dialer1), d=192.168.1.250 (Vlan1), routed via FIB
000410: 14:45:45: IP: s=86.163.47.171 (Dialer1), d=192.168.1.250 (Vlan1), len 123, dropped by inspect
000411: 14:45:45:     ICMP type=3, code=1
000412: 14:45:49: IP: tableid=0, s=94.113.247.45 (Dialer1), d=192.168.1.250 (Vlan1), routed via FIB
000413: 14:45:49: IP: s=94.113.247.45 (Dialer1), d=192.168.1.250 (Vlan1), len 123, dropped by inspect
000414: 14:45:49:     ICMP type=3, code=3
is that correct?
im sorry here it is again....
Kerberos#ping 192.168.1.100
Sending 5, 100-byte ICMP Echos to 192.168.1.100, timeout is 2 seconds:
Success rate is 100 percent (5/5), round-trip min/avg/max = 4/12/24 ms
Kerberos#sh log
                     filtering disabled
                     filtering disabled
    Buffer logging:  level debugging, 376 messages logged, xml disabled,
                     filtering disabled
0, s=71.29.83.191 (Dialer1), d=192.168.1.250 (Vlan1), routed via FIB
000528: 14:47:47: IP: s=71.29.83.191 (Dialer1), d=192.168.1.250 (Vlan1), len 80, dropped by inspect
000529: 14:47:47:     ICMP type=3, code=1
000530: 14:47:50: IP: tableid=0, s=71.29.83.191 (Dialer1), d=192.168.1.250 (Vlan1), routed via FIB
000531: 14:47:50: IP: s=71.29.83.191 (Dialer1), d=192.168.1.250 (Vlan1), len 80, dropped by inspect
000532: 14:47:50:     ICMP type=3, code=1
000533: *Feb 12 22:57:08.852 Athens: %IP_VFR-4-FRAG_TABLE_OVERFLOW: Virtual-Access1: the fragment table has reached its maximum threshold 16
000534: 14:47:53: IP: tableid=0, s=192.168.1.250 (Vlan1), d=194.219.227.2 (Dialer1), routed via FIB
000535: 14:47:53: IP: s=62.1.59.176 (Vlan1), d=194.219.227.2 (Dialer1), g=213.16.246.30, len 201, forward
000536: 14:47:53:     ICMP type=3, code=3
000537: 14:47:54: IP: tableid=0, s=46.33.213.218 (Dialer1), d=192.168.1.250 (Vlan1), routed via FIB
000538: 14:47:54: IP: s=46.33.213.218 (Dialer1), d=192.168.1.250 (Vlan1), len 123, dropped by inspect
000539: 14:47:54:     ICMP type=3, code=3
000540: 14:47:55: IP: tableid=0, s=24.199.188.2 (Dialer1), d=192.168.1.250 (Vlan1), routed via FIB
000541: 14:47:55: IP: s=24.199.188.2 (Dialer1), d=192.168.1.250 (Vlan1), len 123, dropped by inspect
000542: 14:47:55:     ICMP type=3, code=3
000543: 14:47:55: IP: tableid=0, s=192.168.1.200 (local), d=192.168.1.100 (Vlan1), routed via FIB
000544: 14:47:55: IP: s=192.168.1.200 (local), d=192.168.1.100 (Vlan1), len 100, sending
000545: 14:47:55:     ICMP type=8, code=0
000546: 14:47:55: IP: tableid=0, s=192.168.1.100 (Vlan1), d=192.168.1.200 (Vlan1), routed via RIB
000547: 14:47:55: IP: s=192.168.1.100 (Vlan1), d=192.168.1.200 (Vlan1), len 100, rcvd 3
000548: 14:47:55:     ICMP type=0, code=0
000549: 14:47:55: IP: tableid=0, s=192.168.1.200 (local), d=192.168.1.100 (Vlan1), routed via FIB
000550: 14:47:55: IP: s=192.168.1.200 (local), d=192.168.1.100 (Vlan1), len 100, sending
000551: 14:47:55:     ICMP type=8, code=0
000552: 14:47:55: IP: tableid=0, s=192.168.1.100 (Vlan1), d=192.168.1.200 (Vlan1), routed via RIB
000553: 14:47:55: IP: s=192.168.1.100 (Vlan1), d=192.168.1.200 (Vlan1), len 100, rcvd 3
000554: 14:47:55:     ICMP type=0, code=0
000555: 14:47:55: IP: tableid=0, s=192.168.1.200 (local), d=192.168.1.100 (Vlan1), routed via FIB
000556: 14:47:55: IP: s=192.168.1.200 (local), d=192.168.1.100 (Vlan1), len 100, sending
000557: 14:47:55:     ICMP type=8, code=0
000558: 14:47:55: IP: tableid=0, s=192.168.1.100 (Vlan1), d=192.168.1.200 (Vlan1), routed via RIB
000559: 14:47:55: IP: s=192.168.1.100 (Vlan1), d=192.168.1.200 (Vlan1), len 100, rcvd 3
000560: 14:47:55:     ICMP type=0, code=0
000561: 14:47:55: IP: tableid=0, s=192.168.1.200 (local), d=192.168.1.100 (Vlan1), routed via FIB
000562: 14:47:55: IP: s=192.168.1.200 (local), d=192.168.1.100 (Vlan1), len 100, sending
000563: 14:47:55:     ICMP type=8, code=0
000564: 14:47:55: IP: tableid=0, s=192.168.1.100 (Vlan1), d=192.168.1.200 (Vlan1), routed via RIB
000565: 14:47:55: IP: s=192.168.1.100 (Vlan1), d=192.168.1.200 (Vlan1), len 100, rcvd 3
000566: 14:47:55:     ICMP type=0, code=0
000567: 14:47:55: IP: tableid=0, s=192.168.1.200 (local), d=192.168.1.100 (Vlan1), routed via FIB
000568: 14:47:55: IP: s=192.168.1.200 (local), d=192.168.1.100 (Vlan1), len 100, sending
000569: 14:47:55:     ICMP type=8, code=0
000570: 14:47:55: IP: tableid=0, s=192.168.1.100 (Vlan1), d=192.168.1.200 (Vlan1), routed via RIB
000571: 14:47:55: IP: s=192.168.1.100 (Vlan1), d=192.168.1.200 (Vlan1), len 100, rcvd 3
000572: 14:47:55:     ICMP type=0, code=0
000573: 14:47:56: IP: tableid=0, s=71.29.83.191 (Dialer1), d=192.168.1.250 (Vlan1), routed via FIB
000574: 14:47:56: IP: s=71.29.83.191 (Dialer1), d=192.168.1.250 (Vlan1), len 76, dropped by inspect
000575: 14:47:56:     ICMP type=3, code=1
000576: 14:47:58: IP: tableid=0, s=71.20.125.203 (Dialer1), d=192.168.1.250 (Vlan1), routed via FIB
000577: 14:47:58: IP: s=71.20.125.203 (Dialer1), d=192.168.1.250 (Vlan1), len 123, dropped by inspect
000578: 14:47:58:     ICMP type=3, code=3
the firewall is dropping it now let's do another test
enable
clear log
ping x.x.x.x so Vlan1  where x.x.x.x is the zyxel IP
sh log
Alain
Kerberos#clear log
Kerberos#clear logging
Clear logging buffer [confirm]
Kerberos#ping 192.168.1.100 so
Kerberos#ping 192.168.1.100 source vla
Kerberos#ping 192.168.1.100 source vlan 1
Packet sent with a source address of 192.168.1.200
Success rate is 100 percent (5/5), round-trip min/avg/max = 4/8/12 ms
Kerberos#sh log
                     filtering disabled
                     filtering disabled
    Buffer logging:  level debugging, 7537 messages logged, xml disabled,
                     filtering disabled
n1), routed via FIB
004861: 15:09:14: IP: s=192.168.1.200 (local), d=192.168.1.100 (Vlan1), len 100, sending
004862: 15:09:14:     ICMP type=8, code=0
004863: 15:09:14: IP: tableid=0, s=192.168.1.100 (Vlan1), d=192.168.1.200 (Vlan1), routed via RIB
004864: 15:09:14: IP: s=192.168.1.100 (Vlan1), d=192.168.1.200 (Vlan1), len 100, rcvd 3
004865: 15:09:14:     ICMP type=0, code=0
004866: 15:09:14: IP: tableid=0, s=114.229.202.185 (Dialer1), d=192.168.1.250 (Vlan1), routed via FIB
004867: 15:09:14: IP: s=114.229.202.185 (Dialer1), d=192.168.1.250 (Vlan1), len 159, dropped by inspect
004868: 15:09:14:     ICMP type=3, code=3
004869: 15:09:15: IP: tableid=0, s=188.51.127.15 (Dialer1), d=192.168.1.250 (Vlan1), routed via FIB
004870: 15:09:15: IP: s=188.51.127.15 (Dialer1), d=192.168.1.250 (Vlan1), len 68, dropped by inspect
004871: 15:09:15:     ICMP type=3, code=1
004872: 15:09:15: IP: tableid=0, s=1.196.229.203 (Dialer1), d=192.168.1.250 (Vlan1), routed via FIB
004873: 15:09:15: IP: s=1.196.229.203 (Dialer1), d=192.168.1.250 (Vlan1), len 56, dropped by inspect
004874: 15:09:15:     ICMP type=3, code=3
004875: 15:09:16: IP: tableid=0, s=83.180.172.220 (Dialer1), d=192.168.1.250 (Vlan1), routed via FIB
004876: 15:09:16: IP: s=83.180.172.220 (Dialer1), d=192.168.1.250 (Vlan1), len 159, dropped by inspect
004877: 15:09:16:     ICMP type=3, code=3
004878: 15:09:16: IP: tableid=0, s=41.57.98.223 (Dialer1), d=192.168.1.250 (Vlan1), routed via FIB
004879: 15:09:16: IP: s=41.57.98.223 (Dialer1), d=192.168.1.250 (Vlan1), len 86, dropped by inspect
004880: 15:09:16:     ICMP type=3, code=3
004881: 15:09:17: IP: tableid=0, s=62.233.182.240 (Dialer1), d=192.168.1.250 (Vlan1), routed via FIB
004882: 15:09:17: IP: s=62.233.182.240 (Dialer1), d=192.168.1.250 (Vlan1), len 123, dropped by inspect
004883: 15:09:17:     ICMP type=3, code=3
004884: 15:09:17: IP: tableid=0, s=66.176.201.210 (Dialer1), d=192.168.1.250 (Vlan1), routed via FIB
004885: 15:09:17: IP: s=66.176.201.210 (Dialer1), d=192.168.1.250 (Vlan1), len 68, dropped by inspect
004886: 15:09:17:     ICMP type=3, code=1
004887: *Feb 12 23:18:35.383 Athens: %IP_VFR-4-FRAG_TABLE_OVERFLOW: Virtual-Access1: the fragment table has reached its maximum threshold 16
004888: 15:09:19: IP: tableid=0, s=147.30.16.8 (Dialer1), d=192.168.1.250 (Vlan1), routed via FIB
004889: 15:09:19: IP: s=147.30.16.8 (Dialer1), d=192.168.1.250 (Vlan1), len 123, dropped by inspect
004890: 15:09:19:     ICMP type=3, code=3
004891: 15:09:20: IP: tableid=0, s=69.157.103.90 (Dialer1), d=192.168.1.250 (Vlan1), routed via FIB
004892: 15:09:20: IP: s=69.157.103.90 (Dialer1), d=192.168.1.250 (Vlan1), len 159, dropped by inspect
004893: 15:09:20:     ICMP type=3, code=1
004894: 15:09:20: IP: tableid=0, s=83.53.230.8 (Dialer1), d=192.168.1.250 (Vlan1), routed via FIB
004895: 15:09:20: IP: s=83.53.230.8 (Dialer1), d=192.168.1.250 (Vlan1), len 123, dropped by inspect
004896: 15:09:20:     ICMP type=3, code=3
004897: 15:09:20: IP: tableid=0, s=38.107.218.2 (Dialer1), d=192.168.1.250 (Vlan1), routed via FIB
004898: 15:09:20: IP: s=38.107.218.2 (Dialer1), d=192.168.1.250 (Vlan1), len 123, dropped by inspect
004899: 15:09:20:     ICMP type=3, code=3
004900: 15:09:20: IP: tableid=0, s=122.2.135.105 (Dialer1), d=192.168.1.250 (Vlan1), routed via FIB
004901: 15:09:20: IP: s=122.2.135.105 (Dialer1), d=192.168.1.250 (Vlan1), len 96, dropped by inspect
004902: 15:09:20:     ICMP type=11, code=0
004903: 15:09:21: IP: tableid=0, s=2.71.126.85 (Dialer1), d=192.168.1.250 (Vlan1), routed via FIB
004904: 15:09:21: IP: s=2.71.126.85 (Dialer1), d=192.168.1.250 (Vlan1), len 123, dropped by inspect
004905: 15:09:21:     ICMP type=3, code=3
004906: 15:09:21: IP: tableid=0, s=118.160.44.163 (Dialer1), d=192.168.1.250 (Vlan1), routed via FIB
004907: 15:09:21: IP: s=118.160.44.163 (Dialer1), d=192.168.1.250 (Vlan1), len 159, dropped by inspect
004908: 15:09:21:     ICMP type=3, code=3
004909: 15:09:21: IP: tableid=0, s=89.132.6.46 (Dialer1), d=192.168.1.250 (Vlan1), routed via FIB
004910: 15:09:21: IP: s=89.132.6.46 (Dialer1), d=192.168.1.250 (Vlan1)
can  you connect a laptop to f3 for example and give it 192.168.1.199 mask 255.255.255.0 df gw= 192.168.1.100(vlan 1) and try to ping the zyxel from it.
As they are in same subnet the pc shouldn't use the vlan interface and  the packets will be just L2 switched.
we shouldn't see any debug if we do this now:
enable
conf t
ip access-list extended 199
no 10
10 permit icmp 192.168.1.0 0.0.0.255 host 192.168.1.200 echo
do clear log
Do the test and issue the command: do sh log
Then if it works it means that indeed we can have a dialer linked to L2 interface but that is not good practice for me.
Can you try to change this port to L3 like this
int f0
no switchport
I'm not sure it can be done on this platform though
Alain
Yes indeed i can ping the zyxel from a laptop like you described,i dont like it either to be honest ,it confuses me alot
im trying giving the command on Fast ethernet0 ... and it asks for
Kerberos(config-if)#no switchport acc
Kerberos(config-if)#no switchport access ?
  vlan  Set VLAN when interface is in access mode
i issued
#no switchport access vlan 1 on interface fae0 but had no effect i still can access the zyxel
Can't you do simply no switchport, what does "no switchport ?"  tells you ?
Alain
Kerberos#conf t
Enter configuration commands, one per line.  End with CNTL/Z.
Kerberos(config)#int
Kerberos(config)#interface fa
Kerberos(config)#interface fastEthernet 0
% Incomplete command.
if i put ?  its asks
Kerberos(config-if)#no switchport ?
  access    Set access mode characteristics of the interface
  mode      Set trunking mode of the interface
  priority  Set 802.1p priorities
  trunk     Set trunking characteristics of the interface
  voice     Voice appliance attributes
Well it works its ok ,i just wanted to see it there was a way to isolate port Eth0 from rest of the Lan interfaces,
you can't make it a L3 routed port so  if you have ios 15 you can do an intra zone policy with ZBF  or you can maybe put a L2 access-list if it is possible on this platform but I'm not sure it is.
Alain
Well i will try the above you mentioned and will post any results in the future
Thanks alot for spending your time to help
cheers!!
