10-10-2007 06:33 AM - edited 03-03-2019 07:06 PM
Apparently the Cisco 877 and 837 routers should have the IP nbar option an an interface. Mine don't. The readme for Netflow says:
Platforms & Cisco IOS Versions that currently support CISCO-NBAR-PROTOCOL-DISCOVERY-MIB are
Cisco 1700 Series Router since Release 12.2(2)T
Cisco 2600, 3600, 7100, 7200 Series Routers since Release 12.1(5)T
Cisco 3700 and 7500 Series Routers since Release 12.2(8)T
The following Platforms also support NBAR:
Cisco 800 Series Routers
Cisco 1800 Series Integrated Services Routers
Cisco 2600XM Series Router
Cisco 2800 Series Integrated Services Routers
Cisco 3700 Series Multiservice Access Routers
Cisco 3800 Series Integrated Services Routers
Cisco 7300 Series Routers
Cisco 7400 Series Routers
Catalyst 6500 Family Switch with a FlexWAN card.
10-10-2007 11:39 AM
Let's see a show version output from your router.
10-10-2007 11:47 AM
The 837 is 12.4(5b)
The 877 I can't get to at the moment, I know a 2006 IOS think Nov.
10-11-2007 10:29 AM
I need to know the feature set and show version would provide that.
10-11-2007 10:45 AM
Not near the router, but I can tell you it's c870-advsecurityk9-mz.124-15.T1
10-12-2007 10:05 AM
You need advanced ip services, you only have advanced security.
This is the image you need:
c870-advipservicesk9-mz.124-15.T1.bin
10-12-2007 10:13 AM
Great, will my current config be ok after I upgrade? As I have a VPN setup on the config.
10-12-2007 10:16 AM
According to Cisco Feature Navigator, the image I suggested supports IPSec.
However, I suggest researching a bit more by going to:
http://tools.cisco.com/ITDIT/CFN/jsp/index.jsp
and enter the image name.
10-12-2007 10:23 AM
Thanks, fman my blackberry can't use that link. The nbar option apparently let's me get better stats on NetFlow.
