Community Member
Cisco 877 and Austria Eunet/Tiscali no Carrier Detection
We have the problem that our Cisco 877 with IOS 12.4.6T2 does not detect the carrier signal. The LED is just blinking.
Our provider is EUNET ex. Tiscali in Austria. Does someone has technical information about the setting with this provider? We are tried following: PVC:8/48, PPPoA, AAL5MUX, ANSI-DMT.
Does someone has any idea? Thank you.
Best Regards
Ludwig
1 REPLY
Community Member
Re: Cisco 877 and Austria Eunet/Tiscali no Carrier Detection
As Eunet basically resells products of TA and Tele2UTA, the ATM settings can be quite different depending on the exact product. Have a look at www.zarathustra.at or www.xdsl.at for details (at the latter forum you can also contact me per pm).
HTH,
jutta
147
