Cisco 877-k9 ADSL Router configuration and Upgrade of IOS to 15
Dear All,
Below is the configuration which connects (PPP light comes) but no browsing.
01.Please corret me if any mistake in configuration (pls reply with which command to remove or which to add)
also the ios version is old  ( version version 12.4 )
or some bugs or some hardware issue?
02. I beleive if the configuration below is correct then if i upgrade the ios to latest stable version then i hope things
will work fine? Which stable latest version is feasible? please advise.Also will cisco give it FREE of cost?
03.Is it true that if the router that we bought could be refurbished and then issue could be with hardware or software etc?
04.How should i Check that router is not refurbished?
05.The same below configuration is working fine on other router of same model/same ios , if  I not wrong.
Thanx to all in advance.Happy new year!
User Access Verification
Username: khan
Password:
shukry#show ip int br
Interface                  IP-Address      OK? Method Status                Protocol
ATM0                       unassigned      YES NVRAM  up                    up
ATM0.1                     unassigned      YES unset  up                    up
Dialer0                    2.88.225.150    YES IPCP   up                    up
FastEthernet0              unassigned      YES unset  up                    up
FastEthernet1              unassigned      YES unset  up                    up
FastEthernet2              unassigned      YES unset  up                    down
FastEthernet3              unassigned      YES unset  up                    up
NVI0                       unassigned      YES unset  administratively down down
Virtual-Access1            unassigned      YES unset  up                    up
Vlan1                      192.168.1.254   YES NVRAM  up                    up
shukry#show run
Building configuration...
Current configuration : 3770 bytes
version 12.4
no service pad
hostname shukry
boot-start-marker
boot-end-marker
logging buffered 51200 warnings
no aaa new-model
crypto pki trustpoint TP-self-signed-985750308
enrollment selfsigned
subject-name cn=IOS-Self-Signed-Certificate-985750308
revocation-check none
rsakeypair TP-self-signed-985750308
dot11 syslog
ip cef
no ip dhcp use vrf connected
ip dhcp excluded-address 10.10.10.1
ip dhcp excluded-address 192.168.1.1
ip dhcp excluded-address 192.168.1.254
ip dhcp pool khan
   import all
   network 192.168.1.0 255.255.255.0
   default-router 192.168.1.254
   dns-server 8.8.8.8 8.8.4.4
   domain-name wr
   lease 0 2
no ip domain lookup
ip domain name yourdomain.com
username khan privilege 15 secret xxxxxxxxxxxx
archive
log config
  hidekeys
interface ATM0
no ip address
no atm ilmi-keepalive
dsl operating-mode auto
interface ATM0.1 point-to-point
pvc 0/35
  pppoe-client dial-pool-number 1
interface FastEthernet0
interface FastEthernet1
interface FastEthernet2
interface FastEthernet3
interface Vlan1
description $ETH-SW-LAUNCH$$INTF-INFO-HWIC 4ESW$
ip address 192.168.1.254 255.255.255.0
ip nat inside
ip virtual-reassembly
ip tcp adjust-mss 1452
interface Dialer0
ip address negotiated
ip mtu 1492
ip nat outside
encapsulation ppp
dialer pool 1
dialer-group 1
no cdp enable
ppp authentication pap chap callin
ppp chap hostname user@16m.saudi.net.sa
ppp chap password 1234
ppp pap sent-username user@16m.saudi.net.sa password 1234
ip forward-protocol nd
ip route 0.0.0.0 0.0.0.0 Dialer0
ip http server
ip http access-class 23
ip http authentication local
ip http secure-server
ip http timeout-policy idle 60 life 86400 requests 10000
ip nat inside source list 1 interface Dialer0 overload
access-list 1 permit 192.168.1.0 0.0.0.255
no cdp run
control-plane
line con 0
privilege level 15
login local
no modem enable
line aux 0
line vty 0 4
access-class 23 in
privilege level 15
login local
transport input telnet ssh
scheduler max-task-time 5000
end
shukry#
  • WAN Routing and Switching
Hall of Fame Super Gold
I won't recommend what version you can use.   My 871 has 130 DRAM and 24 Flash and it's running 15.1(4)M1.
thnx alot regarding version information. What about configuration?Any mistake in it?
thanx again
hi,
your config looks fine.
are you able to ping 192.168.1.254 and 8.8.8.8 from a PC connected on your 877 FE port?
1421
