Cisco 877 pure bridge mode
I need to configure my Cisco877 just in bridge mode between ATM interface and interface VLAN1 so my PC would get public ISP IP address. I think this is done just setting my windows xp network interface for DHCP client. Could anyone send me or post this configuration file?
Thanks a lot!!!
1 ACCEPTED SOLUTION
Hall of Fame Super Silver
Re: Cisco 877 pure bridge mode
Hello Adis,
it should take an ip address by DHCP to give your PC a chance to telnet successfully.
You have ip routing disabled so the router can behave just as a PC.
Hope to help
Giuseppe
Hello Adis,
use the following
this mode of operation is called RFC 1483 bridged mode
http://www.cisco.com/en/US/tech/tk175/tk15/technologies_configuration_example09186a008071a816.shtml
adapt the configuration to your needs use the document as a template
Hope to help
Giuseppe
I tried this last night, buy it did not work. I was waiting for my windows xp network interface card to get the ISP IP address but nothing happened.
May be I was too tired to see the solution.
I will try your configuration one more time this evening.
Thanks a lot again!
Seba
Hello Seba,
check what the ISP is giving you: if it is PPPoE you need a PPPoE client on your PC instead of DHCP
note: I've linked a document in the cisco web site
Hope to help
Giuseppe
No, it is not PPPoE o PPPoA.
It is just Ethernet.
Is it OK???
Seba
Hello Seba,
then you need DHCP on the PC indeed
the configuration is fine because bridging doesn't care of upper layer protocols
Hope to help
Giuseppe
OK. I will try it this afternoon.
Thanks!
It works!
I tried this configuration this afternoon and it worked. I also defined DHCP client on my PC network card.
You can have a look at it:
Router#sh running-config
Building configuration...
Current configuration : 903 bytes
version 12.4
no service pad
hostname Router
boot-start-marker
boot-end-marker
logging message-counter syslog
no aaa new-model
dot11 syslog
ip source-route
no ip routing
no ip cef
archive
log config
hidekeys
interface ATM0
no ip address
no ip route-cache
no atm ilmi-keepalive
pvc x/x
encapsulation x
dsl operating-mode x
bridge-group 1
interface FastEthernet0
interface FastEthernet1
interface FastEthernet2
interface FastEthernet3
interface Vlan1
no ip address
no ip route-cache
bridge-group 1
ip forward-protocol nd
no ip http server
no ip http secure-server
control-plane
bridge 1 protocol ieee
line con 0
no modem enable
line aux 0
line vty 0 4
login
scheduler max-task-time 5000
end
Router#
Thanks a lot for your help!
Adis
Hello Adis,
nice news it worked
be aware that in this way you have configured the router as a bridge and you can access it only via console.
Hope to help
Giuseppe
Yes, I know that.
In that case, is it enough to add an IP address to VLAN1?
Thanks!
Hello Adis,
Hope to help
Giuseppe
2540
