Cisco 877 router - Cisco IP phone won't register with SIP provider
Hi all,
I'm having a problem with a Cisco SPA504G phone not registering with the SIP carrier over the Internet. We've recently rolled out a Cisco 877 router onto a new NBN business connection and can't get the pre-configured IP phone to register.
When we tested the phone with the NBN-provided Netgear router, it worked fine, as it did with the previous Cisco 1841 router we were using on a different link.
The way it's setup is using VLANs to define the internal subnets, which are then assigned to the physical interfaces (since the 887 doesn't allow IP assignments to the interfaces directly).
VLAN 100 is the internal network and has a SBS2011 server – assigned to F0 – IP range is 192.168.1.0
VLAN 200 is the guest network and has Internet access only – assigned to F1 – IP range is 10.1.1.0
VLAN 500 is the WAN network and connects to the NBN upstream box – assigned to F3 – external IP address assigned by DHCP
I've been playing around with access lists, nat rules, basically everything in my limited Cisco knowledge to try and figure this out, but to no avail. I have even configured what I believe is unrestricted access to IP, UDP and TCP outbound and inbound to all VLANs and still can't get it to register.
Tried isolating the issue by creating a new VLAN and assigning it to the spare interface and basically allowing everything in and out, but still no luck.
The problem has to be something on the router – probably some small line of config I haven’t removed or added.
I am going to pull my hair out soon, so would really appreciate some assistance from the Cisco gurus out there.
My client has just purchased about 10 of these handsets from their provider so I need to fix this ASAP. The guy who provided them wasn't very helpful, and basically said I'm on my own once we tested using the NBN-provided Netgear router.
Happy to post my config as well.
Please help!!!!
Everyone's tags (1)
Hall of Fame Super Gold
no ip nat service sip tcp
no ip nat service sip tcp port 5060
no ip nat service sip udp port 5060
Did you disable ALG?
Hi, thanks for the reply,I
I was playing with those commands yesterday after reading some forum posts.  I have applied them but no luck so far - the phone says "failed - no response".  The config only shows the UDP command though - not sure if that is how it's meant to be...
What do you mean by disable ALG - is that what those commands are doing?
I'll post my config as well in case this helps.
Thanks again.
Current configuration : 4912
Current configuration : 4912 bytes
version 15.1
no service pad
hostname Router1
boot-start-marker
boot-end-marker
no aaa new-model
memory-size iomem 10
no ip source-route
ip dhcp excluded-address 10.1.1.1
ip dhcp pool GUEST
 network 10.1.1.0 255.255.255.0
 dns-server 10.1.1.1 203.50.2.71 139.130.4.4
 default-router 10.1.1.1
ip cef
no ip domain lookup
ip domain name network.local
ip name-server 192.168.1.123
ip name-server 203.23.53.12
ip name-server 197.12.32.86
ip name-server 8.8.8.8
no ipv6 cef
license udi pid CISCO887VA-K9 sn FGL171220XY
username admin privilege 15 secret 5 $1$aNsm$N1BCQYkoi8gnURyvloYEX/
controller VDSL 0
interface Ethernet0
 no ip address
 shutdown
interface ATM0
 no ip address
 no atm ilmi-keepalive
 bridge-group 10
 pvc 8/35
interface FastEthernet0
 description NAC - Internal network
 switchport access vlan 100
 no ip address
interface FastEthernet1
 description NAC - Guest network
 switchport access vlan 200
 no ip address
interface FastEthernet2
 no ip address
 shutdown
interface FastEthernet3
 description **** WAN Port ****
 switchport access vlan 500
 no ip address
interface Vlan1
 no ip address
 bridge-group 10
 hold-queue 100 out
interface Vlan100
 description NAC - Internal Vlan
 ip access-group IN-100 in
 ip access-group OUT-100 out
 ip nat inside
 ip virtual-reassembly in
interface Vlan200
 description NAC - Guest Vlan
 ip address 10.1.1.1 255.255.255.0
 ip access-group IN-200 in
 ip access-group OUT-200 out
 ip nat inside
interface Vlan500
 description **** WAN Vlan ****
 ip address dhcp
 ip nat outside
 no ip virtual-reassembly in
no ip forward-protocol nd
ip http server
ip http access-class 23
ip http secure-server
ip dns server
ip nat inside source list NAT-100 interface Vlan500 overload
ip nat inside source list NAT-200 interface Vlan500 overload
ip nat inside source static tcp 192.168.1.123 25 interface Vlan500 25
ip nat inside source static tcp 192.168.1.123 443 interface Vlan500 443
ip nat inside source static tcp 192.168.1.123 3389 interface Vlan500 3399
ip nat inside source static tcp 192.168.1.123 80 interface Vlan500 80
ip nat inside source static tcp 192.168.1.123 4125 interface Vlan500 4125
ip nat inside source static tcp 192.168.1.124 3389 interface Vlan500 3390
ip nat inside source static tcp 192.168.1.123 987 interface Vlan500 987
ip nat inside source static tcp 192.168.1.123 1723 interface Vlan500 1723
ip route 0.0.0.0 0.0.0.0 55.234.52.43
ip access-list extended IN-100
 permit udp any any range bootps bootpc
 deny   ip 10.1.1.0 0.0.0.255 any
 permit ip 192.168.1.0 0.0.0.255 any
ip access-list extended IN-200
 permit ip 10.1.1.0 0.0.0.255 any
ip access-list extended NAT-100
 deny   ip 192.168.0.0 0.0.255.255 192.168.0.0 0.0.255.255
ip access-list extended NAT-200
 deny   ip 10.1.0.0 0.0.255.255 10.1.0.0 0.0.255.255
ip access-list extended OUT-100
 permit udp any range bootps bootpc any
 permit ip any 192.168.1.0 0.0.0.255
ip access-list extended OUT-200
 deny   ip 10.1.1.0 0.0.0.255 192.168.1.0 0.0.0.255
 permit ip any 10.1.1.0 0.0.0.255
access-list 23 permit 59.23.164.52
access-list 23 permit 192.168.1.0 0.0.0.255
access-list 23 permit 10.1.1.0 0.0.0.255
access-list 23 permit 120.146.0.0 0.0.255.255
access-list 23 permit 149.185.12.0 0.0.0.255
access-list 23 permit 110.44.28.0 0.0.0.255
access-list 23 permit 110.44.26.0 0.0.0.255
access-list 23 permit 103.25.212.0 0.0.0.255
access-list 23 permit any
bridge 10 protocol ieee
banner motd ^C
*      Authorized personnel only!       *
^C
line con 0
 login local
 no modem enable
line aux 0
line vty 0 4
 password password01
 login local
 transport input all
end
Depending on your VSP.  Mine
Depending on your VSP.  Mine is Internode and they encourage ALG to be disabled.  They also discourage NAT-ing the phones to them because they already do the NAT.  Once I turned ALG off the router and ensured my Asterisk has disabled NAT (from Asterisk to Internode), my phones started working.
In some cheap Netgear, Linksys, Belkin stuff, ALG is disabled by default, however, Cisco routers (IOS version 12.4 and above) have ALG turned on by default.
Yeah no idea - I've tried
Yeah no idea - I've tried with this on and off and still having no luck connecting.  I've gone over every line of config and tried different access list permissions without any success.
Any other suggestions before I rip my hair out?
Not so fast.   Talk to your
Not so fast.
Talk to your VSP.  They can run a debug on their end to see what your call server is doing.
Hmm, yeah they've been
Hmm, yeah they've been surprisingly unhelpful with this one - however I understand their senior techs are under the pump at the moment and their rep did try and help as much as possible, but just doesn't have the technical knowledge.
I spent another 5 hours there today and have worked around the problem now (finally).  I've got the NBN router acting as the gateway so it's really a waste having the Cisco router there, except that they have a guest network for Internet access only that's on a different IP range.  I'm doing a double NAT through both routers for this network as the NBN router doesn't support VLANs or multiple IP ranges.
Not really how I'd wanted this solution to look, but I've had enough of this issue.  Considering the time spent on this one, it would have probably been more cost effective for me to fly interstate for a holiday and just pay for their telephone calls for a year....
Interestingly though, I downloaded a SIP client for my laptop and put the details into that and it worked first time... I'm not sure what all the settings were, but that made me wonder - and I reset the IP phone to factory settings and started again - again with no luck and about 2 hours of frustration.
Anyway, enough whining about this.  I'm about a week behind on my work now.  Thanks for the suggestions anyway :)
Sounds like a firmware
Sounds like a firmware problem.
One of the easiest way to test is to download/install a softphone.  If you get the softphone working but your IPTel doesn't then there's possibly a firmware issue.
Same thing happened with me with a 7970 and 9971.
349
