Cisco 877 - routing issue?
Hi all,
I've got a problem with a config on my 877 router, and I just can't find the solution.
issues:
1. Using the config below, I can connect to the internet fine, and ping internet IP addresses from the router (but I can't resolve names.. e.g. ping google.co.uk )
2. My laptop will connect to the router and get an IP address from the DHCP pool. I can telnet / ping the router without a problem, but I can't ping anything on the internet ( name or IP ) I'm, guessing its a routing issue between the Dialler10 and vlan1, but I can't seem to resolve it.
Any help would be most appreciated, as its driving me up the wall stairring at the config.
Many thanks in advance.
Dave
Cisco 877 configuration Document
Enter
User: cisco
Pass: password
config t
username cisco priv 15 password password
hostname ddhrouter
ena secret password
line vty 0 4
login
password password
line con 0
password password
int atm0
description ** adsl interface **
mtu 1452
no ip address
load-interval 30
no atm ilmi-keepalive
pvc 1/50
ubr 288
encapsulation aal5mux ppp dialer
dialer pool-member 1
dsl operating-mode auto
hold-que 224 in
no shut
int vlan 1
 description ** local lan **
 ip address 192.168.3.254 255.255.255.0
 routing dynamic
 ip nat inside
 hold-queue 100 out
 no shut
ip dhcp pool CISCODHCP
 network 192.168.3.0 255.255.255.0
 dns-server 212.50.160.100 213.249.130.100
 default-router 192.168.3.254
int dialer10
 description ** adsl dialer interface **
 ip address negotiated
 ip nat outside
 ip mtu 1482
 encapsulation ppp
 dialer pool 1
 ppp chap hostname myusername
 ppp chap password 0 mypassword
 no ip access-list standard 23
 no ip access-list extended 10
IP CLASSLESS
IP ROUTE 0.0.0.0 0.0.0.0 dialer10
ip http server
ip http access-class 23
ip http authentication local
no ip http secure-server
ip http max-connections 4
ip http timeout-policy idle 600 life 86400 requests 10000
Dialer-list 1 protocol ip permit
Access-list 110 permit icmp any any echo
Access-list 110 permit icmp any any echo-reply
End
Copy run start
Everyone's tags (1)
1 ACCEPTED SOLUTION
Hello
Hello ip dhcp excluded-address 192.168.3.254 Access-list 1 permit 192.168.3.0 0.0.0.255 Ip nat inside source list 1 interface dialer10 overload Res Paul
Please don't forget to rate any posts that have been helpful. Thanks.
Hello
Bronze
you need the NAT interface
you need the NAT interface overload statement....
Aplly the config:
Access-list 12 permit 192.168.3.0 0.0.0.255
Ip nat inside source list 12 interface dialer10 overload
29
