Community Member
cisco 877
i have cisco 877.i need to connected the WAN IP(83.x.x.x) to gain internet access and route it to LAN(192.x.x.x).pls exlain me how to do.
Rgds
kumar
Re: cisco 877
Dear,
Could you clarify more, do you mean static route? NAT? or what?
Best Regards,
Mounir Mohamed
Community Member
Re: cisco 877
i have staic IP for the internet(83.x.x.x).need to do NAting for the LAN users(192.168.x.x).
Bronze
Re: cisco 877
In order to do nat for the inside users, do the following:
//this is the access list that will permit the required subnets or hosts for natting
ip access-list extended NAT
permit ip 192.168.x.x 0.0.255.255
// this is the route map that match the access list mentioned above
route-map nat-map permit 1
match ip address NAT
//this is the natting command that contains the route map, source, and also the outside interface which is dialer 0 for Cisco877, overload means all the inside users(192.168.x.x) will have one IP address which is 83.x.x.x (since this is static IP)
ip nat inside source route-map nat-map interface Dialer0 overload
// this is will be applied at the inside interface "gateway" for the inside interface. "if the vlan & wireless interfaces are bridged, then this is applied at the BVI interface"
ip nat inside
//this is applied at the outside interface, dialer 0 interface
ip nat outside
I hope this is helpful
Please rate all helpful posts!
Abd Alqader
157
