Cisco 877W and DSL
I am new to the 877 routers and I am having a really hard time getting an IP address from SBC ("Sticky IP"). I have tried changing the DSL operating-mode but to no avail. I have uploaded a copy of my current config, as I have it set up. I can bring my ATM interfaces up but am unable to "grab" my IP. Any thoughts greatly appreciated. --Josh--
1 REPLY
VIP Purple
Re: Cisco 877W and DSL
try to add the changes marked with an arrow (-->), try the 'dialer-group 1' on the dialer interface first, if that doesn't help, try the ' ip address dhcp' command. By the way, did you get that PVC from your provider ? Usually, PVC 0/38, or 0/35, are being used, you might want to try those as well if the above doesn't work:
Using 3465 out of 131072 bytes
version 12.3
no service pad
hostname #######################3
boot-start-marker
boot-end-marker
enable secret 5 #################################
enable password #################################
clock timezone PCTime -8
no aaa new-model
ip subnet-zero
no ip source-route
ip cef
ip dhcp excluded-address ###########################
ip dhcp pool pool1
import all
network ###########################
dns-server ###########################
default-router ###########################
domain-name ###########################
netbios-name-server ###########################
lease 1 1
no ftp-server write-enable
password encryption aes
crypto isakmp policy 1
encr aes
hash md5
authentication pre-share
crypto isakmp key ########################### address ###########################
crypto ipsec transform-set aes128 esp-aes esp-md5-hmac
crypto map acl_110 1 ipsec-isakmp
description mymap
set peer ###########################
set transform-set aes128
match address acl_111
interface ATM0
no ip address
no atm ilmi-keepalive
dsl operating-mode ansi-dmt
interface ATM0.1 point-to-point
pvc 19/59
pppoe-client dial-pool-number 1
interface FastEthernet0
no ip address
no cdp enable
interface FastEthernet1
no ip address
no cdp enable
interface FastEthernet2
no ip address
no cdp enable
interface FastEthernet3
no ip address
no cdp enable
interface Dot11Radio0
no ip address
shutdown
speed basic-1.0 basic-2.0 basic-5.5 6.0 9.0 basic-11.0 12.0 18.0 24.0 36.0 48.0
54.0
no cdp enable
interface Vlan1
description ###########################
ip address ###########################
no ip redirects
no ip unreachables
no ip proxy-arp
ip virtual-reassembly
ip route-cache flow
ip tcp adjust-mss 1452
interface Dialer0
ip address negotiated
no cdp enable
interface Dialer1
--> ip address DHCP (2)
ip mtu 1492
ip nat outside
encapsulation ppp
dialer pool 1
--> dialer-group 1 (1)
no cdp enable
ppp pap sent-username ########################### password 0 ###########################
ip classless
ip route 0.0.0.0 0.0.0.0 Dialer1
ip http server
ip http authentication local
ip http secure-server
ip http timeout-policy idle 600 life 86400 requests 10000
ip nat inside source list 1 interface Dialer1 overload
ip access-list extended acl_111
permit ip ###########################
deny ip any any
access-list 1 remark INSIDE_IF=VLAN1
access-list 1 permit ###########################
access-list 103 deny ###########################
access-list 103 permit ###########################
dialer-list 1 protocol ip permit
no cdp run
control-plane
banner login ###########################
line con 0
login local
no modem enable
transport preferred all
transport output telnet
line aux 0
login local
line vty 0 4
privilege level 15
login local
transport input telnet ssh
transport output all
scheduler max-task-time 5000
scheduler allocate 4000 1000
scheduler interval 500
end
99
