Webcast-Catalyst9k
Cisco 877W - bind IP's to VLAN or BVI interfaces?
I am currently working on a new Teleworker configuration and upgrading my field routers from 831/837 models to 871W/877W models.
I currently have setup three VLANs, the default / native (VLAN1) for Data, VLAN2 for Voice, and VLAN3 for Untrusted traffic (Only traffic to internet that bypasses DMVPN corporate resources).
I am currious if anyone can speak to a best practice or explain why it would be better to bind IP's to the BVI interfaces or VLAN interfaces.
Currently, I have a similar setup.
interface FastEthernet0
switchport mode trunk
switchport voice vlan 2
switchport priority extend trust
interface FastEthernet1
switchport access vlan 3
interface FastEthernet2
interface FastEthernet3
interface Vlan1
no ip address
bridge-group 1
interface Vlan2
ip address 10.50.25.129 255.255.255.128
ip nat inside
ip virtual-reassembly
interface Vlan3
no ip address
bridge-group 2
bridge-group 2 spanning-disabled
interface BVI1
ip address 10.50.25.1 255.255.255.128
ip access-group Inside_Inbound in
no ip redirects
no ip unreachables
no ip proxy-arp
ip nat inside
ip route-cache flow
ip tcp adjust-mss 1452
interface BVI2
ip address 192.168.100.1 255.255.255.0
ip access-group Untrusted_Inbound in
no ip redirects
no ip unreachables
no ip proxy-arp
ip nat inside
ip route-cache flow
bridge 1 protocol ieee
bridge 1 route ip
bridge 2 protocol ieee
bridge 2 route ip
Is it there any reason to bind all of the IP's to VLAN vs. BVI interfaces? I would like to stay consistant across the board.
-Matthew
1 ACCEPTED SOLUTION
Purple
Re: Cisco 877W - bind IP's to VLAN or BVI interfaces?
When using IRB-type configurations, it is more conventional to put the IP on the BVI. However, your situation is a bit different. Do you experience any problems at all with the IP on the VLAn interface. If not, then just go ahead and do that.... If both work, there is no real issue in using one over the other.
Hope that helps - pls rate the post if it does.
Paresh
Purple
Hi Matthew,
The only reason I would use BVIs instead of VLAN interfaces is when I was also bridging traffic on non-switched ports. For example, if you were bridging some of the traffic coming from your switch ports over to your ATM (DSL) port then you would need to configure a bridge-group. If you are not, you can just use VLAN interfaces.
Hope that helps - pls rate posts that help.
Paresh
I think what I am more trying to figure out is where it's best to place the IP addresses, and if it matters. In this case, I need to use bridging for the two wireless networks I have created and am briding them onto VLAN's. I am just going for consistancy and ease of configuration. I would rather put all the IP's on the VLAN's or on the BVI's, for consistancies sake, unless there was a specific issue on why to use one more then the other.
Does this make sense?
Matt
Purple
Paresh
2191
