Cisco 877w Router Wireless Issue
Hi Guys,
Currently i am having issues with my Cisco 877w Router, everything is working fine except the wireless. I am unable to connect to the device and i am getting the error below: Kindly assist?
*Mar 2 02:38:55.627: %DOT11-6-DISASSOC: Interface Dot11Radio0, Deauthenticating Station ec9b.f3ad.7d4b Reason: Disassociated because sending station is leaving (or has left) BSS
*Mar 2 02:38:57.327: %DOT11-6-ASSOC: Interface Dot11Radio0, Station ec9b.f3ad.7d4b Associated KEY_MGMT[WPA PSK]
*Mar  2 02:42:12.399: %DOT11-6-DISASSOC: Interface Dot11Radio0, Deauthenticating Station ec9b.f3ad.7d4b Reason: Disassociated because sending station is leaving (or has left) BSS
Running config below:
BIRDSISLE#show run
Building configuration...
Current configuration : 3361 bytes
version 12.4
no service pad
hostname BIRDSISLE
boot-start-marker
boot-end-marker
enable secret 5 $1$ZxfU$l3Ug6XuJVXudkBSMge2bs1
no aaa new-model
resource policy
ip subnet-zero
ip cef
no ip dhcp use vrf connected
ip dhcp excluded-address 10.10.10.1 10.10.10.254
ip dhcp excluded-address 192.168.100.1 192.168.100.254
ip dhcp pool BIRDSISLE
network 10.10.10.0 255.255.255.0
default-router 10.10.10.1
dns-server xxx.xxx.xxx.xxx
domain-name mydomain.com
ip dhcp pool ***CISCO_877w_LAN***
network 192.168.100.0 255.255.255.0
default-router 192.168.100.1
no ip ips deny-action ips-interface
username cisco password 0 ciscoadsl
bridge irb
interface ATM0
description **** WAN INT****
no ip address
no ip route-cache cef
no ip route-cache
shutdown
no atm ilmi-keepalive
dsl operating-mode auto
interface ATM0.1 point-to-point
description ***WAN SUB_INT***
no ip route-cache
pvc 0/35
pppoe-client dial-pool-number 1
interface FastEthernet0
interface FastEthernet1
interface FastEthernet2
switchport access vlan 10
interface FastEthernet3
interface Dot11Radio0
no ip address
encryption vlan 1 mode ciphers tkip
ssid BIRDSISLE
vlan 1
authentication open
authentication key-management wpa
guest-mode
wpa-psk ascii 0 xxxxxxxxx
speed basic-1.0 basic-2.0 basic-5.5 6.0 9.0 basic-11.0 12.0 18.0 24.0 36.0 48.0 54.0
station-role root
interface Dot11Radio0.1
encapsulation dot1Q 1 native
no snmp trap link-status
bridge-group 1
bridge-group 1 subscriber-loop-control
bridge-group 1 spanning-disabled
bridge-group 1 block-unknown-source
no bridge-group 1 source-learning
no bridge-group 1 unicast-flooding
interface Vlan1
no ip address
ip directed-broadcast
ip flow ingress
ip nat inside
ip virtual-reassembly
ip tcp adjust-mss 1452
bridge-group 1
interface Vlan10
description ***CISCO_877w_LAN***
ip address 192.168.100.1 255.255.255.0
ip flow ingress
ip nat inside
interface Dialer0
ip address negotiated
ip mtu 1452
ip nat outside
encapsulation ppp
dialer pool 1
dialer-group 1
ppp authentication chap callin
ppp pap sent-username xxxxx password 0 xxxxxxx
interface BVI1
description LAN & WLAN Bridge
ip address 10.10.10.1 255.255.255.0
ip nat inside
ip classless
ip route 0.0.0.0 0.0.0.0 Dialer0
no ip http server
no ip http secure-server
ip nat inside source list 1 interface Dialer0 overload
access-list 1 permit 10.10.10.0 0.0.0.255
access-list 1 permit 192.168.1.0 0.0.0.255
access-list 1 permit 192.168.100.0 0.0.0.255
access-list 23 permit 10.0.0.0 0.0.0.255
dialer-list 1 protocol ip permit
control-plane
bridge 1 protocol ieee
bridge 1 route ip
banner motd #######UNAUTHORIZED ACCESS IS STRICTLY PROHIBITED!!!!!#####
line con 0
login local
no modem enable
line aux 0
line vty 0 4
login
transport input all
scheduler max-task-time 5000
end
