Cisco 878 Urgent Help
The_guroo_2
Level 2
Level 2
Guys i have one 3350 switch and two routers cisco 878.....the routers are attached to the swicth via LAN (layer 2) ports of the router (which is builin) now i have created 2 vlans 10,11 on the 3350 swicth and assigned the port to it (which connects the routers) now i want to ping one router from other (different Vlans) can someone please tell m ehow it will be as the swicth port in the router is layer two i cant assignm IP address and my design required that the router shd connect to the swicth via layer 2 port which is builtin???? what shd i do can someone please help
Jon Marshall
Please see answer in Lan switching and routing forum.
Jon
Hello
If you configure the vlan interface on the 878 it should work.
Even on a 828 you can configure an IP address on the LAN interface.
Frederic
