Cisco 881 3g router
anil.sanap
have a Cisco C881GW+7-A-K9
configured this router cellualr interface
as well as ap in that but unable to connect internet
need help to configure if any steps for configuration
9 Replies 9
kcnajaf
Level 7
Level 7
Hi Anil,
Could you please share the router configuration with sensitive informations removed.
Najaf
Please rate when applicable or helpful !!!
thanks for the reply below is the router configuration
Building configuration...
Current configuration : 1868 bytes
! Last configuration change at 12:15:48 UTC Mon Jun 24 2013
version 15.2
hostname Router
boot-start-marker
boot-end-marker
no aaa new-model
service-module wlan-ap 0 bootimage autonomous
ip cef
no ipv6 cef
chat-script cdma "" "ATDT*777#" TIMEOUT 60 "CONNECT"
pid C881GW+7-A-K9
username vispladmin privilege 15 password 0 vispl
controller Cellular 0
interface Cellular0
ip address negotiated
encapsulation slip
dialer in-band
dialer string cdma
dialer-group 1
async mode interactive
interface FastEthernet0
switchport access vlan 40
no ip address
interface FastEthernet1
no ip address
interface FastEthernet2
no ip address
interface FastEthernet3
no ip address
interface FastEthernet4
no ip address
shutdown
duplex auto
speed auto
interface Wlan-GigabitEthernet0
description Internal switch interface connecting to the embedded AP
no ip address
interface wlan-ap0
description Embedded Service module interface to manage the embedded AP
no ip address
interface Vlan1
no ip address
interface Vlan40
ip address 192.168.40.100 255.255.255.0
ip forward-protocol nd
no ip http server
no ip http secure-server
ip route 0.0.0.0 0.0.0.0 Cellular0
access-list 2 permit any
dialer-list 1 protocol ip permit
dialer-list 2 protocol ip list 2
control-plane
line con 0
no modem enable
          line aux 0
line 2
exec-timeout 0 0
no activation-character
no exec
transport preferred none
transport input all
stopbits 1
line 3
exec-timeout 0 0
script dialer cdma
modem InOut
no exec
line vty 0 4
password vispl
login local
transport input all
scheduler allocate 20000 1000
end
HI Anil,
It looks like you are missing the NAT configuration here. Try applying below configuration in addition to your configuration.
interface Cellular0
ip nat outside
interface Vlan40
ip nat inside
access-list 10 permit 192.168.40.0 0.0.0.255
ip nat inside source list 10 interface Cellular0 overload
I'm assuming that your Cellular0 interface is up and running for the NAT configuration to work :-)
Hope that helps.
Najaf
will definately do the provided steps
still i do have one more concern
interface wlan-ap0 published ssid will get the intenet
is there anything need to configure in that interface also
Hi Anil,
I didnt see any wireless configuration here.
If your SSID is mapped to the same vlan (in here vlan 40) you should have internet connection from wireless clients as well.
Hope that helps.
Najaf
http://bogomip.net/blog/configuring-a-cisco-881w/
we found this article on internet
might this will helpful
waiting for reply
Hi Anil,
You have to tell if that link was usefull to you :-) Apparently that link was missing NAT cinfiguration :-(
Najaf
atleast got the way what need to configure on Ap side
publilshed ssid need to get the internet
once internet work on wireless it's ok for us
Hi Anil,
Check the wired side first and if you still have any trouble with wireless side let us know.
Najaf
