Cisco 881G Router
wasiimcisco
I have cisco 881G router with (C880DATA-UNIVERSALK9-M), Version 12.4(22)YB2. It has one 3G card (PCEX-3G-HSPA) with Modem Firmware Version = F1_2_3_15AP C:/WS/F.
I have configure the 3G card but I am not able to get the IP address from the Service Provider.
3G interface status is up and it is registered with the Service provider and Itself SP can see its Cell ID.
when I called SP they said until your router card will not initiate the IP request it will not able to get it.
Service provider support this card I have checked this.
NOw please help me out how to do this. Configuration sample and card output is attached.
Router #show cellular 0 all
Hardware Information
Modem Firmware built = 07/09/08
Hardware Version = 1.1
International Mobile Subscriber Identity (IMSI) = 424021430598220
International Mobile Equipment Identity (IMEI) = 356812011646401
Factory Serial Number (FSN) = D46155921341143
Modem Status = Online
Current Modem Temperature = 24 deg C, State = Normal
Profile Information
Profile 1 = INACTIVE*
PDP Type = IPv4
Access Point Name (APN) = abc.com
Authentication = CHAP
Username: SP-, Password: xxxxx
Network Information
Current Service Status = Normal, Service Error = None
Current Service = Combined
Packet Service = HSPA (Attached)
Packet Session Status = Inactive
Current Roaming Status = Home
Network Selection Mode = Automatic
Country = UAE, Network = ETISALAT
Mobile Country Code (MCC) = 424
Mobile Network Code (MNC) = 2
Location Area Code (LAC) = 40111
Routing Area Code (RAC) = 1
Cell ID = 30650
Primary Scrambling Code = 339
PLMN Selection = Automatic
Registered PLMN = , Abbreviated =
Service Provider = etisalat
Available PLMNs:
PLMN Name = du (du)
MCC = 424, MNC = 3
Status = , Network = GSM
PLMN Name = du (du)
MCC = 424, MNC = 3
Status = , Network = Unknown
PLMN Name = ETISALAT (ETISALAT)
MCC = 424, MNC = 2
Status = Home,, Network = Unknown
MCC = 424, MNC = 2
Status = Home,, Network = GSM
Radio Information
Current Band = WCDMA 2100, Channel Number = 10612
Current RSSI = -59 dBm
Band Selected = Auto
Number of nearby cells = 1
Cell 1
Primary Scrambling Code = 0x153
RSCP = -59 dBm, ECIO = -4 dBm
Modem Security Information
Card Holder Verification (CHV1) = Disabled
SIM Status = OK
SIM User Operation Required = None
Number of Retries remaining = 3
I have configure the 3G card but I am not able to get the IP address from the Service Provider. 3G interface status is up and it is registered with the Service provider and Itself SP can see its Cell ID.
paolo bevilacqua
Recommend you upgrade to YB4, if still problems, contact the TAC.
I upgraded to (C880DATA-UNIVERSALK9-M), Version 15.0(1)M. But stil it is not working and during my search over the Internet I found that doucment attached is screen shot which is showing that IOS version is pending. what does it mean. I have only standard support with my Vendor not the technical support (TAC).
Just means optional features are not enabled.
Buy an official support contract from your reseller and you will be able to access the TAC.
