Cisco 887 change Annex A/M mode
m.kern
can I change the Annex mode from A to M on an CISCO887W-GN-E-K9?
kind regards
manuel
paolo bevilacqua
No, it's not possible to do that.
mavespig
Level 3
Level 3
Hi Manuel,
CISCO887W-GN-E-K9 supports only annex A.
800 routers that support Annex M can be identified by a "M" in the product name, for example CISCO887MW-GN-E-K9.
An Annex M router can work on both Annex A and M, but an Annex A router can work only on A.
If a router supports both annexes, you can use the interface command "dsl operating-mode" to force a specific annex (default is auto mode).
You can refer to this document for router specifications:
http://www.cisco.com/en/US/prod/collateral/routers/ps380/data_sheet_c78_459542.html
Hope this helps
Marco
