12-20-2011 12:59 AM - edited 03-04-2019 02:41 PM
I have a Cisco 877 router and I configured it with the CP Express, however it isn't allowing pass-through for SIP.
How can I fix this? SIP devices cannot register. However they can make oubound calls no problem.
This is the config of the router.
Current configuration : 7498 bytes ! ! Last configuration change at 21:01:27 PCTime Fri Dec 16 2011 by mark ! NVRAM config last updated at 21:01:28 PCTime Fri Dec 16 2011 by mark ! version 15.0 no service pad service tcp-keepalives-in service tcp-keepalives-out service timestamps debug datetime msec localtime show-timezone service timestamps log datetime msec localtime show-timezone service password-encryption service sequence-numbers ! hostname home ! boot-start-marker boot-end-marker ! security authentication failure rate 3 log security passwords min-length 6 logging buffered 51200 logging console critical enable secret 5 ! no aaa new-model memory-size iomem 10 clock timezone PCTime 10 clock summer-time PCTime date Mar 30 2003 3:00 Oct 26 2003 2:00 ! crypto pki trustpoint TP-self-signed-2300806995 enrollment selfsigned subject-name cn=IOS-Self-Signed-Certificate-2300806995 revocation-check none rsakeypair TP-self-signed-2300806995 ! ! crypto pki certificate chain TP-self-signed-2300806995 certificate self-signed 01 (removed) quit no ip source-route ! ! ip dhcp excluded-address 192.168.12.1 192.168.12.29 ip dhcp excluded-address 192.168.12.61 192.168.12.254 ! ! ip dhcp pool ccp-pool1 import all network 192.168.12.0 255.255.255.0 dns-server 203.12.160.35 203.12.160.36 default-router 192.168.12.1 ! ! ip cef no ip bootp server ip name-server 203.12.160.35 ip name-server 203.12.160.36 no ipv6 cef ! ! license udi pid CISCO887W-GN-A-K9 sn FGL154821B8 ! ! username mark privilege 15 secret ! ! ip tcp synwait-time 10 ip ssh time-out 60 ip ssh authentication-retries 2 ! class-map type inspect match-any ccp-cls-insp-traffic match protocol cuseeme match protocol dns match protocol ftp match protocol h323 match protocol https match protocol icmp match protocol imap match protocol pop3 match protocol netshow match protocol shell match protocol realmedia match protocol rtsp match protocol smtp match protocol sql-net match protocol streamworks match protocol tftp match protocol vdolive match protocol tcp match protocol udp match protocol sip class-map type inspect match-all ccp-insp-traffic match class-map ccp-cls-insp-traffic class-map type inspect match-any ccp-cls-icmp-access match protocol icmp match protocol tcp match protocol udp class-map type inspect match-all ccp-invalid-src match access-group 100 class-map type inspect match-all ccp-icmp-access match class-map ccp-cls-icmp-access class-map type inspect match-all ccp-protocol-http match protocol http ! ! policy-map type inspect ccp-permit-icmpreply class type inspect ccp-icmp-access inspect class class-default pass policy-map type inspect ccp-inspect class type inspect ccp-invalid-src drop log class type inspect ccp-protocol-http inspect class type inspect ccp-insp-traffic inspect class class-default drop policy-map type inspect ccp-permit class class-default drop ! zone security out-zone zone security in-zone zone-pair security ccp-zp-self-out source self destination out-zone service-policy type inspect ccp-permit-icmpreply zone-pair security ccp-zp-in-out source in-zone destination out-zone service-policy type inspect ccp-inspect zone-pair security ccp-zp-out-self source out-zone destination self service-policy type inspect ccp-permit ! ! ! ! ! ! ! interface BRI0 no ip address no ip redirects no ip unreachables no ip proxy-arp ip flow ingress encapsulation hdlc shutdown isdn termination multidrop ! interface ATM0 no ip address no ip redirects no ip unreachables no ip proxy-arp ip flow ingress no atm ilmi-keepalive ! interface ATM0.1 point-to-point description $ES_WAN$$FW_OUTSIDE$ ip flow ingress pvc 8/35 pppoe-client dial-pool-number 1 ! ! interface FastEthernet0 ! interface FastEthernet1 ! interface FastEthernet2 ! interface FastEthernet3 ! interface wlan-ap0 description Service module interface to manage the embedded AP ip unnumbered Vlan1 no ip redirects no ip unreachables no ip proxy-arp ip flow ingress arp timeout 0 ! interface Wlan-GigabitEthernet0 description Internal switch interface connecting to the embedded AP ! interface Vlan1 description $ETH-SW-LAUNCH$$INTF-INFO-HWIC 4ESW$$ES_LAN$$FW_INSIDE$ ip address 192.168.12.1 255.255.255.0 no ip redirects no ip unreachables no ip proxy-arp ip flow ingress ip nat inside ip virtual-reassembly zone-member security in-zone ip tcp adjust-mss 1412 ! interface Dialer0 description $FW_OUTSIDE$ ip address negotiated no ip redirects no ip unreachables no ip proxy-arp ip mtu 1452 ip flow ingress ip nat outside ip virtual-reassembly zone-member security out-zone encapsulation ppp dialer pool 1 dialer-group 1 ppp authentication chap pap callin ppp chap hostname ppp chap password ppp pap sent-username no cdp enable ! ip forward-protocol nd ip http server ip http authentication local ip http secure-server ip http timeout-policy idle 60 life 86400 requests 10000 ! ip nat inside source list 1 interface Dialer0 overload ip route 0.0.0.0 0.0.0.0 Dialer0 ! logging trap debugging access-list 1 remark INSIDE_IF=Vlan1 access-list 1 remark CCP_ACL Category=2 access-list 1 permit 192.168.12.0 0.0.0.255 access-list 100 remark CCP_ACL Category=128 access-list 100 permit ip host 255.255.255.255 any access-list 100 permit ip 127.0.0.0 0.255.255.255 any access-list 100 permit ip host 202.62.157.122 any dialer-list 1 protocol ip permit no cdp run ! ! ! ! ! control-plane ! banner login ^CAuthorized access only! Disconnect IMMEDIATELY if you are not an authorized user!^C ! line con 0 login local no modem enable transport output telnet line aux 0 login local transport output telnet line 2 no activation-character no exec transport preferred none transport input all line vty 0 4 privilege level 15 login local transport input telnet ssh ! scheduler max-task-time 5000 scheduler allocate 4000 1000 scheduler interval 500 end
