07-23-2013 03:35 PM - edited 03-04-2019 08:32 PM
I have a new C887VAM-W-E-K9 to replace my existing 837 ISR.
I have been looking through the forums to try to fin the correct setup for the ADSL part and it's a little confusing on whether to use VDSL, ATM Ethernet0 etc.. Having read through as many articles as I can digest I came to conculsion that;
For ADSL2+ I need to configure the ATM0 / ATM0.1 to work with the Dialer0 interface and not VDSL/Ethernet0.
Is that correct? I dont understand why some threads talk about "show controller vdsl 0" for testing whether the ADSL line is working correctly?
I have tried to get the router to talk to the ISP and cannot get it working; the current config for the interfaces is below but this doesn't even get the PPP light on nor can I ping 4.2.2.2 from the CCP tool. Any help appreciated?
controller VDSL 0
no ip ftp passive
interface ATM0
no ip address
no atm ilmi-keepalive
interface ATM0.1 point-to-point
pvc 0/38
encapsulation aal5mux ppp dialer
dialer pool-member 1
interface Ethernet0
no ip address
shutdown
interface FastEthernet0
no ip address
interface FastEthernet1
no ip address
shutdown
interface FastEthernet2
no ip address
shutdown
interface FastEthernet3
no ip address
shutdown
interface Wlan-GigabitEthernet0
description Internal switch interface connecting to the embedded AP
no ip address
interface wlan-ap0
description Embedded Service module interface to manage the embedded AP
no ip address
interface Vlan1
description $FW_INSIDE$
ip address 192.168.2.1 255.255.255.0
ip nat inside
ip virtual-reassembly in
interface Dialer0
ip address negotiated
ip mtu 1452
ip nat outside
encapsulation ppp
dialer pool 1
ppp authentication chap callin
ppp chap hostname bthomehub@btbroadband.com
ppp chap password 0 BT
no cdp enable
ip forward-protocol nd
ip http server
ip http authentication local
ip http secure-server
ip http timeout-policy idle 60 life 86400 requests 10000
ip nat inside source list 101 interface Dialer0 overload
ip route 0.0.0.0 0.0.0.0 Dialer0
access-list 101 permit ip 192.168.2.0 0.0.0.255 any
Solved! Go to Solution.
07-26-2013 10:19 PM
Your router has a Broadcom 'multimode' chipset that supports both ADSL2+ and VDSL2. Athough you are correct that ADSL is configured under ATM and VDSL under Ethernet0, the command show controller vdsl 0 is used for both modes, and replaces the command show dsl interface atm 0 used in older models with a different chipset.
In order to troubleshoot, please post the output of show controller vdsl 0 and your full config.
07-26-2013 10:19 PM
07-27-2013 05:00 AM
I have managed to get it working now, I reset back to factory and started again. This time I configured the ATM and a Dialer interface, then set the vdsl to auto mode, I think the issue was that I had configured a vdsl connection using CCP and even removing it didn't make any difference.
