Cisco 887VA and BT ADSL
dataIP
I have a question that we don't seem to be able to resolve with BT... We experience random disconnects, in that the sync is present but the PPP session drops. Unplugging the DSL cables and re-inserting after the sync is lost always makes the router re-establish its PPP session. This can happen from once a week to a couple of times per day.
BT have suggested many things, but none are leading to a solution. We can rule out the obvious that BT always ask... master socket, different router (new 887VA of the same type). Power is clean, supplied from UPS.
I have the document Product_Bulletin_DSL.pdf, which is supposed to discuss correct operation with BT systems, but this morning ran in to BT stating that they don't support Cisco and wouldn't really go any further.
I did ask if they could access http://www.cisco-bt-portal.com/iusr/DSL/Product_Bulletin_DSL.pdf but we didn't seem to get very far.
As far as I can tell there is a BT specific version of firmware for this DSL connection, vdsl.bin-35d_d23j, it is referenced in the document but I don't seem to be able to access it from the link.
Also, I have what I belive o be the latest ios ready to apply, but CCP won't let me load it.. we get a message something to the effect of "wrong image for this router". As far as I can tell, it is correct... I obtained it from the Cisco downlaod area.
I am unsure of what DSL firmware in contained within, so maybe best to also load the vdsl.bin-35d_d23j (if I can get hold of it).
Any sugesstions on this problem?
31 Replies 31
mavespig
Level 3
Level 3
Hi, If I recall correctly, that firmware is optimized to work with BT DSLAMs.
Perhaps you may ask BT directly for a copy of the firmware.
However, from what you wrote it seems that the DSL layer remains up, and only PPP flaps.
You should collect a "show dsl interface atm" to see what are your noise and attenuation levels, and if there are CRC and drops reported at ATM level.
It is possible that the ATM layer stays up, but with several CRC's, causing PPP layer to come down.
BTW, did you try to restart PPP without disconnecting the cable?
for example, shut/no shut the dialer, or configure the dialer with 'dialer persistent'
Marco
Hi Marco, thanks for the reply.
I tried asking BT for this firmware, even giving them the reference to it on the cisco/bt portal site. They were not too helpful, and I am not too sure they understood the request.
BT tell me that "they don't support Cisco".... I think they are confused... we are not asking them for config support (e.g. ios commands)... it is ridiculous for them to say they don't 'support' industry standard hardware. They want us to use their 'hub'... great but no IPv6 support. I am happy to use and sell Cisco thanks BT!
The command show dsl interface atm doesn't work for me on this router...
but show controller vdsl 0 gives me the following...
Controller VDSL 0 is UP
Daemon Status:           Up
                        XTU-R (DS)              XTU-C (US)
Chip Vendor ID:         'BDCM'                   'TSTC'
Chip Vendor Specific:   0x0000                   0x0510
Chip Vendor Country:    0xB500                   0xB500
Modem Vendor ID:        'CSCO'                   'TSTC'
Modem Vendor Specific:  0x4602                   0x0510
Modem Vendor Country:   0xB500                   0xB500
Serial Number Near:    FCZ15269023 887VA-K9 15.1(2)T
Serial Number Far:     00000000000000000000000000000000
Modem Version Near:    15.1(2)T
Modem Version Far:     0x0510
Modem Status:            TC Sync (Showtime!)
DSL Config Mode:         AUTO
Trained Mode:            G.992.5 (ADSL2+) Annex A
TC Mode:                 ATM
Selftest Result:         0x00
DELT configuration:      disabled
DELT state:              not running
Trellis:                 ON                       ON
Line Attenuation:        40.5 dB                 23.3 dB
Signal Attenuation:      40.5 dB                  0.0 dB
Noise Margin:             9.3 dB                  5.8 dB
Attainable Rate:        8940 kbits/s             18815 kbits/s
Actual Power:            20.4 dBm                11.9 dBm
Total FECS:             0                        0
Total ES:               1071                     2959
Total SES:              32                       10
Total LOSS:             0                        0
Total UAS:              0                        0
Total LPRS:             0                        0
Total LOFS:             0                        0
Total LOLS:             0                        0
Bit swap:               18781                    4058
Full inits:             2
Failed full inits:      0
Short inits:            0
Failed short inits:     0
Firmware        Source          File Name (version)
VDSL            embedded        VDSL_LINUX_DEV_01212008 (1)
Modem FW  Version:      100608_1515-4.02L.03.A2pv6C030h.d22k
Modem PHY Version:      A2pv6C030h.d22k
                  DS Channel1     DS Channel0   US Channel1       US Channel0
Speed (kbps):             0             8107             0               912
Previous Speed:           0             8219             0               896
Total Cells:              0       1030153251             0         115862778
User Cells:               0         12933173             0           2285416
Reed-Solomon EC:          0                0             0                 0
CRC Errors:               0             3116             0                 0
Header Errors:            0             6450             0              2273
Interleave (ms):       0.00             0.24          0.00              1.00
Actual INP:            0.00             0.00          0.00              0.00
Training Log :  Stopped
Training Log Filename : flash:vdsllog.bin
router#
I didn't do the shut/no shut on the dialer0.... next time it plays up, if I am here I will do that and see if that brings the link back up.
My dialer0 config is as below... should I be adding dialer persistent?
interface Dialer0
ip address negotiated
no ip redirects
ip mtu 1452
ip flow ingress
encapsulation ppp
dialer pool 1
dialer-group 1
ppp authentication chap pap callin
ppp chap hostname **********.btclick.com
ppp chap password 7 ************************
ppp pap sent-username**********.btclick.com password 7 ****************
no cdp enable
Noise margin and attenuation are acceptable but far from being good (just for reference, noise margin, the higher the better, under 8 dB the line will start to flap. Attenuation, the lower the better, 40 dB means you are pretty far from the DSLAM).
You can see that there are a few CRC and header errors. Try to monitor for a couple of days this output, to see if margin and attenuation are fluctuating during the day.
If PPP goes down again, check if there has been a significant increase in the error fields.
If that's the case, then the firmware upgrade can definitely help.
'Dialer persistent' is telling the dialer to try to be always up, no matter if there is interesting traffic.
If PPP goes somehow down, the dialer should try to restart immediately, starting a new PPP negotiation.
Hope this helps
Marco
Okay, will monitor the error fields and see how we go.
I have also added the dialer persistent command... as it happens, I guess there is almost always traffic on this link so it should stay up (primary link with our VoIP traffic plus some backup name and mail servers hang off it). Might explain why it seems to go down more when we are all out of the office though.
Just for reference, I have also (previously) added the BT specific settings...
service internal
controller vdsl 0
operating mode auto
modem ukfeature
I am not 100% sure they are active/applicable if the BT firmware isn't loaded.
How do I go about getting the specific BT firmware? I can't get to the link in the Cisco/BT portal site document.... I think it is for BT employees only.
Not great progress so far, PPP session dropped again leaving sync.
At least I was able to poke around and try some debug.... but didn't get what I hoped.
I have a callback booked with BT today, but am not hopefull that I can get the DSL firmware out of them.
NOTE: In that which follows, it shows the VDSL controller is up... but there is no PPP session.
router#show controller vdsl 0
Daemon Status:           Up
TC Mode:                 ATM
Trellis:                 ON                       ON
Line Attenuation:        40.5 dB                 23.4 dB
Noise Margin:             7.0 dB                  5.6 dB
Attainable Rate:        8076 kbits/s             18528 kbits/s
Actual Power:            20.6 dBm                12.0 dBm
Total FECS:             0                        0
Total ES:               3107                     7744
Total SES:              111                      29
Total LOSS:             0                        0
Total UAS:              0                        0
Total LPRS:             0                        0
Total LOFS:             0                        0
Total LOLS:             0                        0
Bit swap:               58673                    13103
Full inits:             4
Short inits:            0
Speed (kbps):             0             8143             0               896
Previous Speed:           0             8199             0               912
Total Cells:              0       3252959075             0         357873423
User Cells:               0         61027756             0           8876813
CRC Errors:               0            10315             0                 0
Header Errors:            0            27179             0              8745
router#
Let us try shutting dialer0...
router#conf t
router(config)#inter dialer0
router(config-if)#shut
Wait a while....
router(config-if)#no shut
router(config-if)#end
CD remains solid, PPP not restored.
Try atm0...
router#conf t
Enter configuration commands, one per line.  End with CNTL/Z.
router(config)#interface atm0
Wait a while....
Cable out for 6 seconds... CD flashing
Controller VDSL 0 is DOWN
Daemon Status:           Establishing Link
TC Mode:                 ATM
Trellis:                 ON                       ON
Noise Margin:             8.9 dB                  4.3 dB
Attainable Rate:        8164 kbits/s             18305 kbits/s
Actual Power:            20.5 dBm                12.1 dBm
Total FECS:             0                        0
Total ES:               1                        2
Total SES:              0                        0
Total LOSS:             0                        0
Total UAS:              0                        0
Total LPRS:             0                        0
Total LOFS:             0                        0
Total LOLS:             0                        0
Bit swap:               7                        0
Full inits:             5
Short inits:            0
Speed (kbps):             0             7471             0               888
Previous Speed:           0             8143             0               896
Total Cells:              0           813045             0             79591
User Cells:               0              500             0               505
CRC Errors:               0                1             0                 0
Header Errors:            0                1             0                 2
router#
Wait a while...
Daemon Status:           Up
TC Mode:                 ATM
Trellis:                 ON                       ON
Noise Margin:             9.0 dB                  4.4 dB
Attainable Rate:        8208 kbits/s             18290 kbits/s
Total FECS:             0                        0
Total ES:               2                        2
Total SES:              0                        0
Total LOSS:             0                        0
Total UAS:              0                        0
Total LPRS:             0                        0
Total LOFS:             0                        0
Total LOLS:             0                        0
Bit swap:               23                       0
Full inits:             5
Short inits:            0
Total Cells:              0          1820840             0            205243
User Cells:               0              680             0               660
CRC Errors:               0                2             0                 0
Header Errors:            0                4             0                 2
router#
You should have 'mtu 1492', not 'ip mtu xxx'.
Take and post debug PPP auth, debug PPP neg with 'term mon'.
dataIP
Not had any further failures with which to do more testing (actually, probably not noticed any failures... if it comes back up over night it will go unreported).
Spoke to BT again, who really don't get the issue. Waiting for another callback.
I need to obtain the vdsl.bin-35d_d23j firmware and/or confirm if this is contained in an IOS release (don't think it is).
I  can't access the file directly as it says we are not authorised for  that download. It seems a bit random as to what our Partner stauus lets  us access.
The link in the BT/Cisco document does't seem to go anywhere either. I get a not found on
http://www.cisco-bt-portal.com/iusr/DSL/vdsl.bin-35d_d23j
Since two years or so, you need a support contract specific to the software or file one needs to download.
Partner status doesn't apply anymore. The only people that can download without restrictions are Cisco employees.
Thanks Paolo,
At least that explains why can't get to things that we used to... we can get to some software that isn't public... we still need to login, but it isn't a consistent set. Some Unified Comms, some switches, some APs and most of the router tools appear okay.
So, still need to source the firmware file vdsl.bin-35d_d23j
Does this count as warranty support? We opened another new 887VA last week to put in as a replacement, this had the same originally shipping versions of the firmware as our first one.
Mark
The switches have free software updates for life, and that is why anybody can download it.
I believe that if you open a TAC case as "new device not working", an engineer can facilitate the firmware file to you.
Anyway chances are that customer will need the support contract anyway, for further updated, and hardware warranty.
Resurrecting an old thread as we still don't have a resolution.
Update on this is that we put the 887VA on SmartNet maintenance and got the latest firmware,
vdsl.bin-35d_d23j. It is loaded correctly as confirmed by the router#show controller vdsl 0 command.
VDSL            user config     flash:vdsl.bin-A2pv6C035d_d23j (10)
Modem FW  Version:      110802_1752-4.02L.03.A2pv6C035d.d23j
Modem PHY Version:      A2pv6C035d.d23j
No change to the situation.
ios is as original... again when trying to do an upgrade with CCP it tells me the image (from the Cisco site) isn't compatible.
Feeding back to BT, they made changes in the exchange and effectively cut our connection for 8 days as they were unable to reverse the change (looks like an incorrect tie pair modification).
Having resolved that, we are now back in the situation with periodic disconnects.
Odd thing here is we have another site with identical 887VA kit (but not on a BT connection) that seems to work fine.
Since we now have this unit on SmartNet, I suppose we could open a TAC case... but I am not so sure this is Cisco's problem.
I am also considering abandoning BT's offerings and moving this router over to FTTC (VDSL). I know that the green box kit is all BT's but we appear to get better connections when we don't use BT Retail.
Any additional thoughts?
Mark
CCP is not good at all, do the IOS update manually, and check agan.
If you can have another modem stable on the line, then it is Cisco problem.
Hi Paolo,
Thanks for the quick reply... will do a manual upgrade of the IOS image.
Just to clarify, what I meant was we have an identical Cisco 887VA located at a customer site, that one is on a non-BT line and doesn't have any issues. So, it appears that the issue is the service provider's end rather than the Cisco router.
Mark
I understand that, but a non-BT line can use a different DSLAM, now the point is that Cisco should work with any DSLAM, even if it requires different firmware. And the best way to prove that the circuit is stable, is using ISP-supplied modem.
