Cisco 887VA can't connect to VDSL
Hello, I'm trying to get an internet connection through my cisco 877va but I can't get access. I can see DSL up, however, the dialer0 interface can't get access to internet. Here is my configuration:
Router#sh conf
Using 2140 out of 262136 bytes
! Last configuration change at 18:12:59 Israel Sat Nov 26 2011 by nitzan
! NVRAM config last updated at 18:13:04 Israel Sat Nov 26 2011 by nitzan
version 15.1
no service pad
hostname Sport77_Router
boot-start-marker
boot-end-marker
enable secret 5 *******
no aaa new-model
memory-size iomem 10
clock timezone Israel 2 0
ip source-route
ip cef
no ipv6 cef
license udi pid CISCO887VA-K9 sn *******
username ******* privilege 15 secret 5 ********
controller VDSL 0
bba-group pppoe global
interface Ethernet0
no ip address
no fair-queue
interface Ethernet0.32
encapsulation dot1Q 32
pppoe-client dial-pool-number 1
interface ATM0
no ip address
shutdown
no atm ilmi-keepalive
interface FastEthernet0
interface FastEthernet1
interface FastEthernet2
interface FastEthernet3
interface Vlan1
description line to Firewall
ip address 82.80.90.201 255.255.255.248
ip nat inside
ip virtual-reassembly in
ip tcp adjust-mss 1412
interface Dialer0
ip address negotiated
ip mtu 1492
ip nat outside
encapsulation ppp
dialer pool 1
dialer-group 1
keepalive 11
ppp authentication pap callin
ppp pap sent-username ****** password 0 ******
ppp ipcp route default
ppp ipcp address accept
no cdp enable
ip forward-protocol nd
no ip http server
no ip http secure-server
ip nat inside source list 1 interface Dialer0 overload
ip route 0.0.0.0 0.0.0.0 Dialer0
logging esm config
access-list 1 permit 82.80.90.0 0.0.0.252
dialer-list 1 protocol ip permit
control-plane
line con 0
login local
no modem enable
line aux 0
line vty 0 4
access-class 23 in
privilege level 15
login local
transport input telnet ssh
ntp server 212.235.102.46 source Dialer0
end
Router#
Here is "show ip int bri"
Router#sh ip int bri
Interface                       IP-Address      OK?      Method           Status                          Protocol
ATM0                            unassigned      YES      NVRAM       administratively down      down
Dialer0                           unassigned      YES      NVRAM            up                              up
Ethernet0                       unassigned      YES      NVRAM            up                              up
Ethernet0.32                   unassigned      YES      unset                up                              up
FastEthernet0                  unassigned      YES      unset               up                              up
FastEthernet1                  unassigned      YES      unset             down                           down
FastEthernet2                  unassigned      YES      unset              down                          down
FastEthernet3                   unassigned      YES      unset             down                           down
NVI0                                unassigned      YES      unset       administratively down          down
Vlan1                               82.80.90.201    YES      NVRAM            up                              up
Router#
Thanks.
VIP Super Bronze
Not sure why you are using NAT since your IPs are public and not private.  If this is the case, remover all NAT parameters and the access list and try again.
Thanks for your reply.
My ISP is using a main IP address that behind it is the public IP that I have, so because of that I'm using NAT. I can't connect to the ISP and get that main IP
Nitzan
1065
