Cisco 891 Fail over Configuration
andyspranata
Cisco 891 configuration Details:
version 15.0
no service pad
service tcp-keepalives-in
service tcp-keepalives-out
service timestamps debug datetime msec localtime show-timezone
service timestamps log datetime msec localtime show-timezone
service password-encryption
service sequence-numbers
hostname XXXXX
boot-start-marker
boot-end-marker
security authentication failure rate 3 log
security passwords min-length 6
logging buffered 51200
logging console critical
enable secret 5 YYYYYYYYYYYYYYYYYYYYYYYYYY
aaa new-model
aaa authentication login default local
aaa authorization exec default local
aaa session-id common
no ip source-route
ip dhcp pool ccp-pool1
   import all
   network 10.153.64.0 255.255.255.128
   default-router 10.153.64.1
   dns-server 8.8.8.8
   lease infinite
ip cef
no ip bootp server
ip domain name VVVVVVVVVVVV
ip name-server 8.8.8.8
ip name-server 8.8.4.4
ip name-server 10.153.65.1
ip name-server 10.153.66.1
ip inspect tcp reassembly queue length 128
no ipv6 cef
track 1 ip sla 1 reachability
delay down 9 up 10
track 2 ip sla 2 reachability
delay down 9 up 10
interface FastEthernet8
description $ETH-WAN$$FW_OUTSIDE$
ip address 10.153.66.5 255.255.255.128
no ip redirects
no ip unreachables
no ip proxy-arp
ip flow ingress
ip flow egress
ip nat outside
ip virtual-reassembly
duplex auto
speed auto
interface GigabitEthernet0
description $ES_WAN$$ETH-WAN$$FW_OUTSIDE$
ip address 10.153.65.5 255.255.255.128
no ip redirects
no ip unreachables
no ip proxy-arp
ip flow ingress
ip flow egress
ip nat outside
duplex auto
speed auto
interface Vlan1
description LAN Connection$ES_LAN$$ETH-SW-LAUNCH$$INTF-INFO-FE 1$$FW_INSIDE$
ip address 10.153.64.1 255.255.255.128
no ip redirects
no ip unreachables
no ip proxy-arp
ip flow ingress
ip flow egress
ip nat inside
ip tcp adjust-mss 1452
interface Async1
no ip address
no ip redirects
no ip unreachables
no ip proxy-arp
encapsulation slip
ip forward-protocol nd
ip http server
ip http authentication local
ip http secure-server
ip http timeout-policy idle 60 life 86400 requests 10000
ip nat inside source route-map A interface FastEthernet8 overload
ip nat inside source route-map B interface GigabitEthernet0 overload
ip route 0.0.0.0 0.0.0.0 10.153.65.1 track 1
ip route 0.0.0.0 0.0.0.0 10.153.66.1 100 track 2
ip sla 1
icmp-echo 10.153.65.1 source-interface GigabitEthernet0
threshold 2
frequency 5
ip sla schedule 1 life forever start-time now
ip sla 2
icmp-echo 10.153.66.1 source-interface FastEthernet8
frequency 5
ip sla schedule 2 life forever start-time now
logging trap debugging
access-list 1 remark INSIDE_IF=Vlan1
access-list 1 remark CCP_ACL Category=2
access-list 1 permit 10.153.64.0 0.0.0.127
access-list 10 permit 10.153.64.0
access-list 110 permit ip 10.153.64.0 0.0.0.127 any
no cdp run
route-map A permit 10
match ip address 110
match interface GigabitEthernet0
route-map B permit 10
match interface FastEthernet8
I could connect to the Gigabitethernet wan, based on above configuration.
When I test on FastEthernet8 for the secondary ISP connection it will not go through the internet.
The Ping details
ping from (10.153.65.5) to 8.8.8.8 = OK
ping from (10.153.66.5) to 10.153.66.1 = OK
ping from (10.153.66.5) to 8.8.8.8 = not OK
PLease advice?
3 Accepted Solutions
     Well, you're trying to "ping" from WAN (10.153.66.5). You need to enable another default route for that . Just shut down "Gigabit 0" for testing.
     Don't forget you're using "Track" to install a default route once at a time
HTH,
Toshi
    Frist off, you need to make sure that which WAN interface you're using to get the outside. "Show ip route" will reveal you that. You can shut down Gigabit0 for testing.
HTH,
Toshi
Hi Andy,
        Yes you can.
Edit: Your configuration looks fine to me. It's Active/Standby.
You can use PBR to redirect a host to WAN(FastEthernet)
ip access-list ext Redirect-Host
permit ip host 10.153.64.61 any
route-map GoToFastEthernet permit 10
match ip address Redirect-Host
set ip next-hop 10.153.66.1
int vlan 1
ip policy route-map GoToFastEthernet
HTH,
Toshi
17 Replies 17
ebarticel
Level 4
Level 4
You have missmatched route map to FastEhternet8 interface
Hope this helps
Eugen
sorry, that was a mistake when I copy paste the configuration
Did you try to change FastEthernet8 with the IP address for the interface in the nat statement?
Also both map statement are using the same acl 110. I see that you have and acl 1 configured.
Did you try to change one of map to use acl 1?
to
ip nat inside source route-map A interface 10.153.66.5 overload
is that correct?
Changed the route-map configuration to:
match ip address 1
Don't need the "interface", just ip address
ip nat  inside source route-map A  10.153.66.5 overload
I tried it  and it give me a wrong syntax warning
    % invalid input detected
You need a space between "route-map" and "A".
Also you have two default routes, but the one out Fa8 has a 100 AD. maybe if you remove that value it will use it
ip route 0.0.0.0 0.0.0.0 10.x.x.x 100 track 2
change to
ip route 0.0.0.0 0.0.0.0 10.x.x.x track 2
Helllo,
    Try this out.
ip nat inside source route-map B interface FastEthernet8 overload
ip nat inside source route-map A interface GigabitEthernet0 overload
Edit:  Well, you're trying to "ping" from WAN(10.153.66.5). You need to enable another default route for that . Just shut down "Gigabit 0" for testing.
HTH,
Toshi
HI ,
It was a wrong copy-paste configuration: the right one is:
HTH,
Toshi
Thanks Man,
You are correct - I just tried it and it is working
The failover configuration
Thanks to you.
Best regards,
Andy
Please find below the ping details
#ping
Protocol [ip]:
Target IP address: 8.8.8.8
Repeat count [5]:
Datagram size [100]:
Timeout in seconds [2]:
Extended commands [n]: y
Source address or interface: FastEthernet8
Type of service [0]:
Set DF bit in IP header? [no]:
Validate reply data? [no]:
Data pattern [0xABCD]:
Loose, Strict, Record, Timestamp, Verbose[none]:
Sweep range of sizes [n]:
Sending 5, 100-byte ICMP Echos to 8.8.8.8, timeout is 2 seconds:
Packet sent with a source address of 10.153.66.5
Success rate is 0 percent (0/5)
Please give the details to enable default route?
is this what you mean:
HTH,
Toshi
I have test it - and it is working.
So the FastEthernet8 will not active  when GigabitEthernert0 is active.
is there a way to make sure that both of them active but
GigabitEthernert0 as the primary.
because I would like to configure 1 ip - 10.153.64.61 to route directly to 10.153.66.5
Best regards
Andy
