Cisco 892 Router no internet connection.
Marcin Jedrol
I am quite new to Cisco equipment but found this one cheap and got it and now struggling to set it up to work with internet. I am using cable internet modem which is connected to a cheap wifi router and assigning ip addresses to rest of the network. I wanted to replace it with the Cisco one. I would appreciate a lot just basic router setup using WAN port. Here is the setup:
version 15.6
hostname SimpleActsRouter
boot-start-marker
boot-end-marker
no logging buffered
no aaa new-model
ip dhcp excluded-address 192.168.10.1 192.168.10.99
ip dhcp excluded-address 192.168.10.201 192.168.10.254
ip dhcp pool SA_Clients
network 192.168.10.0 255.255.255.0
default-router 192.168.10.1
dns-server 192.168.10.100
ip dhcp pool vlan2
ip name-server 210.158.149.33
ip name-server 210.158.150.33
ip ddns update method ccp_ddns1
DDNS both
ip cef
no ipv6 cef
license udi pid CISCO892-K9 sn FGL153928B8
username ccpuser privilege 15 secret 5 $1$Zklk$gYdJlJmZmtKA7VK9UqZx8.
redundancy
interface BRI0
no ip address
encapsulation hdlc
isdn termination multidrop
interface FastEthernet0
switchport access vlan 2
no ip address
speed 100
interface FastEthernet1
no ip address
speed 100
interface FastEthernet2
no ip address
speed 100
interface FastEthernet3
no ip address
speed 100
interface FastEthernet4
no ip address
speed 100
interface FastEthernet5
no ip address
speed 100
interface FastEthernet6
no ip address
speed 100
interface FastEthernet7
no ip address
speed 100
interface FastEthernet8
description Service Connection$ETH-WAN$
ip address 192.168.30.1 255.255.255.0
duplex auto
speed auto
interface GigabitEthernet0
description WAN$ETH-WAN$
ip address dhcp client-id GigabitEthernet0 hostname ai202-45-170-198.ccnet-ai.ne.jp
ip nat outside
ip virtual-reassembly in
duplex auto
speed auto
interface Vlan1
no ip address
shutdown
interface Vlan2
ip address 192.168.10.1 255.255.255.0
router rip
version 2
passive-interface GigabitEthernet0
network 192.168.1.0
no auto-summary
ip forward-protocol nd
ip http server
ip http authentication local
no ip http secure-server
ip http timeout-policy idle 60 life 86400 requests 10000
ip dns server
ip dns spoofing 192.168.10.1
ip route 0.0.0.0 0.0.0.0 GigabitEthernet0 dhcp
ip ssh server algorithm encryption aes128-ctr aes192-ctr aes256-ctr
ip ssh client algorithm encryption aes128-ctr aes192-ctr aes256-ctr
ipv6 ioam timestamp
access-list 191 remark permit DNS traffic
access-list 191 remark CCP_ACL Category=1
access-list 191 permit tcp any any eq domain
access-list 191 permit udp any any eq domain
control-plane
mgcp behavior rsip-range tgcp-only
mgcp behavior comedia-role none
mgcp behavior comedia-check-media-src disable
mgcp behavior comedia-sdp-force disable
mgcp profile default
line con 0
line aux 0
line vty 0 4
login local
transport input telnet
scheduler max-task-time 5000
end
thank you so much!
Please next time, just put the config in a text file and attach it to the post otherwise this post will be unreadble with lot of scrolling.
Unless your isp requires a specific client-id and/or hostname, you can put only ip address dhcp under your gig0 interface.
Can you check that you received an ip on your gig0 interface by issuing the following command:
sh ip int brief | i Gigabit
If yes, can you paste the output of:
Sh ip route 0.0.0.0
PS: Please don't forget to rate and mark as correct answer if this answered your question
Francesco
PS: Please don't forget to rate and select as validated answer if this answered your question
26 Replies 26
Francesco Molino
First of all, does your gig0 get an IP from your isp?
If yes, does your router can ping Google dns (8.8.8.8)?
Then to give internet access to Internet hosts in vlan 2, you need to do the following commands:
interface vlan 2
  ip nat inside
ip nat inside source list NAT interface gig0 overload
ip access-list extended NAT
  deny ip 192.168.10.0 0.0.0.255 192.168.0.0 0.0.255.255
   permit 192.168.10.0 0.0.0.255 any
The first line in the ACL is to not nat traffic from your vlan 2 reaching any host within 192.168.0.0/16. I put that line as example top show you how to filter communications to not be natted.
The last ACL line is to nat every remaining traffic sourced from 192.168.10.0/24.
Francesco
I have set my gb0 to dhcp and got hostname set from my ISP (ai202-45-170-198.ccnet-ai.ne.jp). I could not ping google and I have put your configuration, so the setup looks now like this:
version 15.6
boot-start-marker
boot-end-marker
no logging buffered
no aaa new-model
ip dhcp pool vlan2
DDNS both
ip cef
no ipv6 cef
redundancy
interface BRI0
no ip address
encapsulation hdlc
no ip address
speed 100
no ip address
speed 100
no ip address
speed 100
no ip address
speed 100
no ip address
speed 100
no ip address
speed 100
no ip address
speed 100
no ip address
speed 100
duplex auto
speed auto
ip nat outside
duplex auto
speed auto
interface Vlan1
no ip address
shutdown
interface Vlan2
ip nat inside
router rip
version 2
network 192.168.1.0
no auto-summary
ip http server
ip dns server
ip nat inside source list NAT interface GigabitEthernet0 overload
permit ip 192.168.10.0 0.0.0.255 any
ipv6 ioam timestamp
control-plane
line con 0
line aux 0
line vty 0 4
login local
end
Sh ip route 0.0.0.0
Francesco
sh ip int brief | i Gigabit  shows the gb0 port unassigned. If this helps, this is the information I got from currently running router:
Old router config
Could you confirm that you connected g0 interface to your wan modem?
Is your modem in bridge?
Is it an adsl that needs a user and password?
Francesco
So the device is a simple cable modem:
Modem
Then I connect it to my gb0 port. As far as I know it did not need any password nor username. I will attach a configuration again here. (I tried to assign the old router's addresses too).
what type/brand is the cable modem ? What type/brand was the original WiFi router you had attached to the cable modem ?
Is this output from the WiFi router ?
Old router config
Yes, this is the output from 192.168.10.1 wifi router (Aterm WR8165N). Cable modem is Synclayer CBC200J3.
I have somewhat simplified the configuration. When you do a 'sh ip int brief', make sure your interface GigabitEthernet0 has a public IP address assigned.
Either way, try the config below (important parts are marked in bold):
version 15.6
boot-start-marker
boot-end-marker
no logging buffered
no aaa new-model
dns-server 8.8.8.8 8.8.4.4
DDNS both
ip cef
no ipv6 cef
redundancy
interface BRI0
no ip address
encapsulation hdlc
no ip address
speed 100
no ip address
speed 100
no ip address
speed 100
no ip address
speed 100
no ip address
speed 100
no ip address
speed 100
no ip address
speed 100
no ip address
speed 100
duplex auto
speed auto
ip nat outside
duplex auto
speed auto
interface Vlan2
ip nat inside
ip http server
ip dns server
ip nat inside source list 10 interface GigabitEthernet0 overload
access-list 10 permit 192.168.10.0 0.0.0.255
ipv6 ioam timestamp
control-plane
line con 0
line aux 0
line vty 0 4
login local
end
So I have tried and the router still shows "no internet connection"
Here is the updated config again:
What is the output of:
show ip int brief
Here it is:
your interface GigabitEthernet0, the one connected to the modem, is down/down, which means there is likely a physical problem with the cable. Check if you need a crossover cable.
Can you post the output of:
sh interfaces GigabitEthernet0
and
sh vlan (database)
Hold on, I did "show ip int brief" while the router was disconnected from the modem, since all network devices are under the desk, it is easier for me to work somewhere else. I will do that again with a modem connected to the router
