Cisco 892 Router no internet connection.
Marcin Jedrol
I am quite new to Cisco equipment but found this one cheap and got it and now struggling to set it up to work with internet. I am using cable internet modem which is connected to a cheap wifi router and assigning ip addresses to rest of the network. I wanted to replace it with the Cisco one. I would appreciate a lot just basic router setup using WAN port. Here is the setup:
version 15.6
hostname SimpleActsRouter
boot-start-marker
boot-end-marker
no logging buffered
no aaa new-model
ip dhcp excluded-address 192.168.10.1 192.168.10.99
ip dhcp excluded-address 192.168.10.201 192.168.10.254
ip dhcp pool SA_Clients
network 192.168.10.0 255.255.255.0
default-router 192.168.10.1
dns-server 192.168.10.100
ip dhcp pool vlan2
ip name-server 210.158.149.33
ip name-server 210.158.150.33
ip ddns update method ccp_ddns1
DDNS both
ip cef
no ipv6 cef
license udi pid CISCO892-K9 sn FGL153928B8
username ccpuser privilege 15 secret 5 $1$Zklk$gYdJlJmZmtKA7VK9UqZx8.
redundancy
interface BRI0
no ip address
encapsulation hdlc
isdn termination multidrop
interface FastEthernet0
switchport access vlan 2
no ip address
speed 100
interface FastEthernet1
no ip address
speed 100
interface FastEthernet2
no ip address
speed 100
interface FastEthernet3
no ip address
speed 100
interface FastEthernet4
no ip address
speed 100
interface FastEthernet5
no ip address
speed 100
interface FastEthernet6
no ip address
speed 100
interface FastEthernet7
no ip address
speed 100
interface FastEthernet8
description Service Connection$ETH-WAN$
ip address 192.168.30.1 255.255.255.0
duplex auto
speed auto
interface GigabitEthernet0
description WAN$ETH-WAN$
ip address dhcp client-id GigabitEthernet0 hostname ai202-45-170-198.ccnet-ai.ne.jp
ip nat outside
ip virtual-reassembly in
duplex auto
speed auto
interface Vlan1
no ip address
shutdown
interface Vlan2
ip address 192.168.10.1 255.255.255.0
router rip
version 2
passive-interface GigabitEthernet0
network 192.168.1.0
no auto-summary
ip forward-protocol nd
ip http server
ip http authentication local
no ip http secure-server
ip http timeout-policy idle 60 life 86400 requests 10000
ip dns server
ip dns spoofing 192.168.10.1
ip route 0.0.0.0 0.0.0.0 GigabitEthernet0 dhcp
ip ssh server algorithm encryption aes128-ctr aes192-ctr aes256-ctr
ip ssh client algorithm encryption aes128-ctr aes192-ctr aes256-ctr
ipv6 ioam timestamp
access-list 191 remark permit DNS traffic
access-list 191 remark CCP_ACL Category=1
access-list 191 permit tcp any any eq domain
access-list 191 permit udp any any eq domain
control-plane
mgcp behavior rsip-range tgcp-only
mgcp behavior comedia-role none
mgcp behavior comedia-check-media-src disable
mgcp behavior comedia-sdp-force disable
mgcp profile default
line con 0
line aux 0
line vty 0 4
login local
transport input telnet
scheduler max-task-time 5000
end
thank you so much!
26 Replies 26
your interface GigabitEthernet0 has a WAN IP address, which means you are connected to the Internet. I have posted a simplified configuration earlier, try and implement that:
Here it is again:
version 15.6
boot-start-marker
boot-end-marker
no logging buffered
no aaa new-model
dns-server 8.8.8.8 8.8.4.4
DDNS both
ip cef
no ipv6 cef
redundancy
interface BRI0
no ip address
encapsulation hdlc
no ip address
speed 100
no ip address
speed 100
no ip address
speed 100
no ip address
speed 100
no ip address
speed 100
no ip address
speed 100
no ip address
speed 100
no ip address
speed 100
duplex auto
speed auto
ip nat outside
duplex auto
speed auto
interface Vlan2
ip nat inside
ip http server
ip dns server
ip nat inside source list 10 interface GigabitEthernet0 overload
access-list 10 permit 192.168.10.0 0.0.0.255
ipv6 ioam timestamp
control-plane
line con 0
line aux 0
line vty 0 4
login local
end
Okay. I don't get it now. Done the configuration as requested and this bad boy is still having a bad day. Tried to ping Google's  8.8.8.8 and requests timed out.
Doing 'show ip int brief' shows the ip address correctly:
Also I did the configuration. Please review. I am confused now.
where are you pinging from ? The router or the client ? Do the clients get the proper IP address and default gateway ?
Try:
ping 8.8.8.8 source GigabitEthernet0
What is the result ?
This is the result of ping. I am pinging from a client connected via lan cable to FastEthernet8 with a static IP address
Can you post the output of show ip route?
Francesco
PS: Please don't forget to rate and select as validated answer if this answered your question
I lost track of your physical setup. The Cisco is now directly connected...to what ? The cable modem ? Or the ISP through GigabitEthernet0, without the cable modem ?
On Cisco's 892 router Fa8 and Gi0 are WAN interfaces.
Interfaces Fa0-7 are switched interfaces. Fa0-7 are in down down state and that is the reason why VLAN 2 is also in down down state. You should connect your hosts to ports Fa0-7.
But, anyway, if you obtained IP address on WAN port you should be able to ping 8.8.8.8 from router (try also some other WAN IP address e.g 4.2.2.2 , 8.8.4.4). Try to issue
traceroute 8.8.8.8
traceroute 4.2.2.2
and paste output.
NVI0 typically should have IP address from WAN interfaces, try for testing, to remove IP address from Fa8 and reload router.
Hi guys. Sorry for the delay. I have drawn a simple diagram showing the situation. Will do the commands later on and show outputs
Diagram
What crni00000 says it's right for the LAN side.
However this doesn't explain why you can't ping 8.8.8.8 from your router even by sourcing the ping with gig0.
Have you tried
ip route 0.0.0.0 0.0.0.0 dhcp
Instead of
ip route 0.0.0.0 0.0.0.0 gig0
Can you modify this default route and send back the output of show ip route?
Francesco
I ask again for the show ip route as i asked at the beginning. Can you paste the output of this command please?
I think the public IP was already there since the beginning.
Also try the ping Georg asked to validate that you're router can access internet.
Francesco
