I have two Cisco 857 ADSL routers. I am trying to configure them using the SDM and but everytime i click finish on the sdm web interface it just sits there and does nothing.
First check if "Allow active content to run in files on My Computer" in IE - Tools - Advanced is enabled.If it not working even after it is enabled install VM (msjavx86.exe) plus latest Windows Update for it.Then install SDM2.2a and see if it works.
Learn, share, save
