Cisco ADSL WIC
Dear All,
I have installed a Cisco ADSL WIC in my Cisco 1841 Router.
I Have the following data from my ISP:
- Username : user
- Password : pass
- Protocol : PPoE LLC
- VPI : 50
- VCI : 0
How Can I Configure My Router to replace the ADSL Modem I recieved from my ISP using the above configuration?
Thanks alot
1 ACCEPTED SOLUTION
Re: Cisco ADSL WIC
The only difference is I'm running PPPOE and you're running PPPOA and I'm not natting the f0/0 interface. I also have a static ip address from the provider.
Plugged the adsl wic directly into the dsl wall jack. My line doesn't use a dsl filter so if you have one you may want to try it with and with out it.
I would set this up for pppoe, just my 2 cents. Oh, the config I posted works like a charm.
sh int dsl atm0/1/0 (look for "showtime" next to modem status) this mean that you're trained with the provider.
sh atm pvc (shows the status of the pvc which should be up)
Hall of Fame Super Blue
Re: Cisco ADSL WIC
Start with this document as a guide and if you have problems please come back. Don't worry about the config of the 6400 device in the doc, you are concerned with the ADSL WIC section -
http://www.cisco.com/en/US/tech/tk175/tk15/technologies_configuration_example09186a0080093e67.shtml
Jon
Re: Cisco ADSL WIC
Let me know if you need a config for this. I have one setup using only the ADSL wic in a 1841 router. I also have the VPN setup also.
Re: Cisco ADSL WIC
Yes,
Actually I set my router with following config.
BusinessOne#sh run
Building configuration...
Current configuration : 1590 bytes
version 12.4
service password-encryption
hostname BusinessOne
boot-start-marker
boot-end-marker
enable secret 5 $1$0cys$d5c9ungrrlTMwiV11JoMO.
enable password 7 141614030F557878
no aaa new-model
resource policy
mmi polling-interval 60
no mmi auto-configure
no mmi pvc
mmi snmp-timeout 180
ip subnet-zero
ip cef
no ip dhcp use vrf connected
interface FastEthernet0/0
ip address 172.19.134.7 255.255.255.0
ip nat inside
duplex auto
speed auto
interface FastEthernet0/1
no ip address
shutdown
duplex auto
speed auto
interface Serial0/0/0
no ip address
shutdown
no fair-queue
clockrate 2000000
interface ATM0/1/0
no ip address
ip mtu 1452
ip tcp adjust-mss 1300
no atm ilmi-keepalive
dsl operating-mode auto
interface ATM0/1/0.1 point-to-point
ip mtu 1452
pvc 0/50
encapsulation aal5snap
protocol ppp dialer
dialer pool-member 1
interface Dialer0
ip address negotiated
no ip redirects
no ip unreachables
ip mtu 1452
ip nat outside
encapsulation ppp
no ip mroute-cache
dialer pool 1
dialer-group 1
no cdp enable
ppp authentication chap callin
ppp chap hostname afhc
ppp chap password 7 000F1A51025F59555B
ip classless
ip route 0.0.0.0 0.0.0.0 Dialer0
no ip http server
ip nat inside source list 1 interface Dialer0 overload
access-list 1 permit 172.19.134.0 0.0.0.255
control-plane
line con 0
password 7 0207025308545F711A
login
line aux 0
line vty 0 4
login
end
All what I need is to replace my ADSL modem I have from my ISP with this 1841 Router-with-adsl-wic
I do not think that I need VPN
Thanks So Much for both of you
Re: Cisco ADSL WIC
Re: Cisco ADSL WIC
Dear DialerString,
I'm also like to use the PPPoE LLC as you can see in my initial configuration I posted in the top of this page, and I can get only Dynamic IP from my ISP, also, I plugged my ASL WIC directly to the ADSL Wall Jack,
As a newbie in the issue, I do not know how to remove the filter setting from the posted configuration above.
I have positive output from both "sh int dsl atm" and "sh atm pvc" and from debugging also.
The only problem I have now is that I do not know how to configure the inteface to get real IP from my ISP !!!
Below is the output I get from "sh ip int brief"
BusinessOne#sh ip int brief
FastEthernet0/0 172.19.134.7 YES NVRAM up up
FastEthernet0/1 unassigned YES NVRAM administratively down down
Serial0/0/0 unassigned YES NVRAM administratively down down
ATM0/1/0 unassigned YES NVRAM up up
ATM0/1/0.1 unassigned YES unset up up
NVI0 unassigned YES unset up up
Virtual-Access1 unassigned YES unset up up
Virtual-Access2 unassigned YES unset down down
Dialer0 unassigned YES manual up up
- by thw way, whay NVRAM means in this .
Thanx alot
Re: Cisco ADSL WIC
Configure your atm to use a dialer pool because you should see a ip address in your sh ip int brief for di0.
ATM0/1/0.1
pvc 0/50
pppoe-client dial-pool-number 1
Dialer0
dialer pool 1
544
