Cisco AS 5850 RAS problem
have a problem with Cisco As 5850 RAS. It got hang after every 2-3 days and at that time customers found unable to connect with the server. We have to power-reset the RAS to make it working again. In SHOW-LOGGING command it shows the following Errors:
> 00:01:22: %DSC_ENV-1-WARNING: Slot 24, AC Shelf warning, Flags = 0 ; Check shelf
> status
> 00:01:22: %DSC_ENV-1-WARNING: Slot 25, AC Shelf warning, Flags = 0 ; Check shelf
> status
> 00:01:55: %DSIPPF-5-DS_HELLO: DSIP Hello from shelf 0 slot 5 Succeeded
> 00:01:58: %DSIPPF-5-DS_HELLO: DSIP Hello from shelf 0 slot 0 Succeeded
> 00:01:59: %CONTROLLER-5-UPDOWN: Controller E1 0/0, changed state to up
> 00:01:59: %DSCCLOCK-5-SWITCH1: Clock moving to NORMAL from FREERUN, selected clo
> ck is on slot 0 port 0 line 0
> 00:01:59: %DIAL0-3-MSG:
> 00:00:20: %TRUNK-3-BADCLOCK: Selected clock on slot 0 port 0 is bad. Accepting t
> he config.
> 00:02:00: %ISDN-6-LAYER2UP: Layer 2 for Interface Se0/0:15, TEI 0 changed to up
> 00:02:15: %SPE-3-SM_POST_FAILED: SPE 5/01 is BAD.
> 00:02:23: %NP_EST-6-DIAG_POST_NTF: (NP address 5/0/0/1), Test ID=SPE_POWER_ON_SE
> LF_TEST, Result=SPE_POST_TEST_FAILED, Diag code=0xFD000003, Data format=Binary,
> Data len=28, Data=00 01 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
> Please help me to find out the specific problem(is it problem with RSC card or supply or Trunk card). Because the same card was working well from last 3 years on the same configuration.
Bronze
Re: Cisco AS 5850 RAS problem
The Error message %DSC_ENV-1-WARNING: Slot 25, AC Shelf warning, Flags = 0 ; Check shelf status states The card enviromental parameters specified are outside the normal range of operation.
Recommended Action: Check blowers and ambient room temperature.
DSCEXTCLK Messages
The following are Controller Card Clock notification messages.
This error message %SPE-3-SM_POST_FAILED: SPE 5/01 is BAD a state The SPE has failed the POST, and it will be marked as bad.
%NP_EST-6-DIAG_POST_NTF is EST Diagnostic and POST Notification has been sent to the Cisco IOS software to convey additional information about the power-on self-test or a diagnostic test result.
Sir, Thanx for ur coordination...
I hav checked the fan assembly and the room temp. But both are ok & the temp is below 20'c.
What is SPE(%SPE-3-SM_POST_FAILED: SPE 5/01). Is it on Trunk/PRI card???? My PRI CARD IS inserted in 0th slot and universal card is inserted in 5th slot.
According to you what can be the final result. Or what should I do to solve the problem???
372
