Webcast-Catalyst9k
CISCO config pro Express Problem
I'm trying to use a cisco 887VA-SEC-K9. I'm installing cisco-config-pro-exp-k9-2_6-en but it doesen't work.
The browser requests login but then appears a blank page.
Is there anybody can help me?
Thank you very much
Fabrice
My configuration is:
version 15.2
no service pad
hostname xbRouter
boot-start-marker
boot-end-marker
no logging buffered
no aaa new-model
memory-size iomem 10
clock timezone PCTime 1 0
clock summer-time PCTime date Mar 30 2003 2:00 Oct 26 2003 3:00
crypto pki trustpoint TP-self-signed-471455566
enrollment selfsigned
subject-name cn=IOS-Self-Signed-Certificate-471455566
revocation-check none
rsakeypair TP-self-signed-471455566
crypto pki certificate chain TP-self-signed-471455566
certificate self-signed 01
   quit
ip domain name xb81
ip name-server 192.168.186.100
ip ddns update method ccp_ddns1
HTTP
  add http://***@members.dyndns.org/nic/update?system=dyndns&hostname=<h>&myip=<a>
  remove http://***@members.dyndns.org/nic/update?system=dyndns&hostname=<h>&myip=<a>
ip cef
no ipv6 cef
license udi pid CISCO887VA-SEC-K9 sn FCZ160891N2
username ccpuser privilege 15 secret 5 $1$o0Ai$wIXcbWD4CObRNZSt.aTQA0
username fabrice privilege 15 secret 5 $1$NpO1$YvgI6Tl9rtsOV1EmfRM.v/
controller VDSL 0
no ip ftp passive
interface Ethernet0
no ip address
shutdown
interface ATM0
no ip address
no ip route-cache
no atm ilmi-keepalive
pvc 8/35
  encapsulation aal5mux ppp dialer
  dialer pool-member 1
interface FastEthernet0
no ip address
interface FastEthernet1
no ip address
interface FastEthernet2
no ip address
interface FastEthernet3
no ip address
interface Vlan1
ip address 192.168.186.191 255.255.255.0
ip nat inside
ip virtual-reassembly in
ip tcp adjust-mss 1412
interface Dialer1
ip ddns update hostname ***
ip ddns update ccp_ddns1
ip address negotiated
ip nat outside
encapsulation ppp
dialer pool 1
dialer-group 1
ppp authentication pap callin
ppp pap sent-username *** password 0 ***
ip forward-protocol nd
no ip http server
ip http access-class 1
ip http authentication local
ip http secure-server
ip http timeout-policy idle 60 life 86400 requests 10000
ip nat inside source list 1 interface Dialer1 overload
ip route 0.0.0.0 0.0.0.0 Dialer1
access-list 1 remark CCP_ACL Category=2
access-list 1 permit 192.168.186.0 0.0.0.255
access-list 100 remark Auto generated by SDM Management Access feature
access-list 100 remark CCP_ACL Category=1
access-list 100 permit udp host 192.168.186.100 eq domain any
access-list 100 permit tcp host 192.168.186.100 host 192.168.186.191 eq telnet
access-list 100 permit tcp host 192.168.186.204 host 192.168.186.191 eq telnet
access-list 100 permit tcp host 192.168.186.99 host 192.168.186.191 eq telnet
access-list 100 permit tcp host 192.168.186.100 host 192.168.186.191 eq 22
access-list 100 permit tcp host 192.168.186.204 host 192.168.186.191 eq 22
access-list 100 permit tcp host 192.168.186.99 host 192.168.186.191 eq 22
access-list 100 permit tcp host 192.168.186.192 host 192.168.186.191 eq 22
access-list 100 permit tcp host 192.168.186.100 host 192.168.186.191 eq www
access-list 100 permit tcp host 192.168.186.99 host 192.168.186.191 eq www
access-list 100 permit tcp host 192.168.186.100 host 192.168.186.191 eq 443
access-list 100 permit tcp host 192.168.186.204 host 192.168.186.191 eq 443
access-list 100 permit tcp host 192.168.186.99 host 192.168.186.191 eq 443
access-list 100 permit tcp host 192.168.186.192 host 192.168.186.191 eq 443
access-list 100 permit tcp host 192.168.186.100 host 192.168.186.191 eq cmd
access-list 100 permit tcp host 192.168.186.204 host 192.168.186.191 eq cmd
access-list 100 permit tcp host 192.168.186.99 host 192.168.186.191 eq cmd
access-list 100 permit tcp host 192.168.186.192 host 192.168.186.191 eq cmd
access-list 100 deny   tcp any host 192.168.186.191 eq telnet
access-list 100 deny   tcp any host 192.168.186.191 eq 22
access-list 100 deny   tcp any host 192.168.186.191 eq www
access-list 100 deny   tcp any host 192.168.186.191 eq 443
access-list 100 deny   tcp any host 192.168.186.191 eq cmd
access-list 100 deny   udp any host 192.168.186.191 eq snmp
access-list 100 permit ip any any
access-list 101 remark Auto generated by SDM Management Access feature
access-list 101 remark CCP_ACL Category=1
access-list 101 permit ip host 192.168.186.100 any
access-list 101 permit ip host 192.168.186.204 any
access-list 101 permit ip host 192.168.186.99 any
access-list 101 permit ip host 192.168.186.192 any
dialer-list 1 protocol ip permit
control-plane
line con 0
line aux 0
line vty 0 4
access-class 101 in
privilege level 15
login local
transport input telnet ssh
end
Everyone's tags (3)
442
