CISCO GLBP PROTOCOL
I have implemented
Cisco Glbp protocol in a lan where there was HSRP.
Now the situation is that the balancing is only on the LAN side (60%-40%)but the imput side ( WAN- Serial Interface)is still unbalanced.
This is normal or can I have a balancing also in the input zone?
Alberto
Hall of Fame Super Silver
Re: CISCO GLBP PROTOCOL
Alberto
I believe that you are seeing normal behavior. Protocols like GLBP are effective with sending traffic on the LAN side but have little ability to control how traffic is sent to you over the WAN links. Control of how traffic is sent to you over the WAN links is the responsibility of the remote router that is sending the traffic over the WAN.
Rick
ROUTER1#sh int fa0/0
FastEthernet0/0 is up, line protocol is up
Hardware is AmdFE, address is 0007.0e83.6860 (bia 0007.0e83.6860)
Description: LINK verso xxxx fa5/24
Internet address is x.x.x.x/24
MTU 1500 bytes, BW 10000 Kbit, DLY 1000 usec,
reliability 255/255, txload 2/255, rxload 1/255
Keepalive set (10 sec)
Full-duplex, 10Mb/s, 100BaseTX/FX
Last input 00:00:00, output 00:00:00, output hang never
Input queue: 0/75/569/0 (size/max/drops/flushes); Total output drops: 0
Queueing strategy: fifo
Output queue: 0/40 (size/max)
5 minute input rate 17000 bits/sec, 8 packets/sec
5 minute output rate 109000 bits/sec, 9 packets/sec
59133323 packets input, 3063440677 bytes
Received 2210177 broadcasts, 0 runts, 0 giants, 0 throttles
34 input errors, 0 CRC, 0 frame, 34 overrun, 0 ignored
0 watchdog
40328405 packets output, 1685116135 bytes, 0 underruns
0 output errors, 0 collisions, 16 interface resets
ROUTER2#sh int fa0/0
Hardware is AmdFE, address is 0003.6b43.4820 (bia 0003.6b43.4820)
Description: LINK verso fa4/24
reliability 255/255, txload 4/255, rxload 1/255
Input queue: 0/75/1367/0 (size/max/drops/flushes); Total output drops: 0
5 minute input rate 7000 bits/sec, 6 packets/sec
5 minute output rate 176000 bits/sec, 23 packets/sec
38309659 packets input, 3859162388 bytes
Received 2154996 broadcasts, 0 runts, 0 giants, 0 throttles
0 watchdog
30695886 packets output, 3555680397 bytes, 0 underruns
0 output errors, 0 collisions, 9 interface resets
This is the situation: The first is priority 150
The second is priority 100
The question is:
By checking the input and output packet of the both rouetr's FAstethernet interfaces, Can I say that GLBP are working fine?
Thanks for your reply
Silver
Hi there Alberto,
This is normal. The GLBP protocol is a LAN-side protocol meant to enable load-balancing for hosts on a LAN which doesn't have a 'clue' about redundant paths.
To enable load balancing on the input of the wan-side, you'll have to either run a routing-protocol or have the sending side (the other sides) manually set static routes which enable the load balancing.
See this link for more information:
"IP Routing - How Does Load Balancing Work?"
http://www.cisco.com/en/US/tech/tk365/technologies_tech_note09186a0080094820.shtml
Did it help? If so, please rate it.
0 watchdog
0 watchdog
The question is:
Alberto
Based on what you have posted I believe there is not any sign of a problem. You have very close to a 60/40 split of traffic both inbound and outbound on these interfaces. It looks to me like GLBP is working as expected.
Rick
Rick,
last question:
Did you think GLBP has to balance in inbound or in outbound.
That' s becasue in other situation We only the outbound traffic balanced.
Many thanks
307
