11-25-2009 06:41 PM - edited 03-04-2019 06:48 AM
So we have a Cisco infrastructure. We have Cisco 2800 Series at our main building - "call it main building" - and Cicso 3560 PoE switch. Another site - call it "site B" - is the same with 2800 router and 3560 switch. At site B, users would report losing VoIP phone as well as computer connectivity intermittently. I could look at the statistics at each port on each switch/router and tell how many packets are being dropped. What method have you guys used to discover connectivity issues with VoIP phone as well PC connectivity? Thanks! -J
11-25-2009 07:10 PM
How is the phone powered up? PoE or power bricks?
What does the switch's log show when the VoIP phones loose connectivity?
Problem is only affecting Site "B"?
Are the switch port configs of "Main" the same as "B"?
Are the users complaining the same ones or all over the place?
Have you tried using the 3560's TDR to check the cabling?
11-25-2009 07:17 PM
->PoE
->Packet drop
->there is another site, but I want to focus on B right now.
->B is being routed to "main"
->Kind of all over the place. We thought that the WIC cards on the router on main was the problem. According to our PRTG, there are still network drops.
11-25-2009 07:25 PM
Thanks for the quick response.
So the logs only show packet drops and nothing about Layer 1 issues, am I correct?
Can you post the configs of your switch?
11-25-2009 07:30 PM
I could do that, but I want to do that fun stuff...hahaha. I'll go back to the OSI as this article suggest...http://www.petri.co.il/layer-by-layer-troubleshooting-cisco.htm
-Thanks
11-25-2009 07:14 PM
Hi J,
Do all the users at site-B loose connectivity at the same time?
Has this worked before or it is a new implantation?
Are you using Cisco Phones or other venders phones?
Reza
11-25-2009 07:19 PM
->Not all the same time.
->It looks new.
Cisco. Mostly Cisco 7940.
-Thanks.
