Cisco Lab setup
alamt0007
I am trying to setup 2 routers Lab.
Routers: 2501 and 2524.
Q. How do I connect these two routers by
cables. I have one transcevier only.
one rollover R45 cable. I have
configure both the routers. But don't
know how to connect these and make CNA lab.
m-haddad
Level 5
Level 5
You have two options:
1- The easiest is to get serial Cables and connect the routers back to back. You will need to set the clock on the DCE side of the cable. You will need one V.35 Serial Male Cable and another V.35 Female cable.
2- Terminate the two routers serially to two NTUs and connect the NTUs using RJ-45 cable to each others thus simulating a leased line betyween the router. Therefore, you need to NTUs with two serial cables.
Hope this helps and appreciate your rating,
t814687
hi, do not waste your time with that.
use this: http://www.dynagen.org/tutorial.htm
or even better GNS3
serg
Yes I am doing Dynamips also. Thanks
