Cisco PIX 525 and Multiple Outside Interfaces
chrismstafford
Hello, I was wondering if someone can help, I am fairly new to PIX's but have been using firewalls for a long time so please bear with me.
We are in the process of integrating a new ISP into out infrastructure, During this there will be a period of time where the both WAN links are active to allow a cross over for our external services. I would like to know how to have two active outside interfaces to allow us to migrate our customers from one service to another without taking the Old Link down.
10 Replies 10
paolo bevilacqua
I have found that the ASA, sw 8.2.3 is unable to use two default routes (with NAT), as opposed to a router that is able to.
Perhaps by manipulating the nat statements carefully, but certainly is not a strightforward process.
chrismstafford
I am happy to keep the defualt route on the old link until it is turned off, then change the defualt route. I just want to allow people in via the new link so we can get customers to test the service before we cease the old lines
Yes, once you switch the default route and everything will be switched, not a problem.
Does this mean I can have to interfaces named outside1 and outside2 set to a security level of 0
Yes.
Please remember to rate useful posts clicking on the stars below.
If you have two ISP connections and you would like to use both of them until
they are active, you can certainly do that. Normally, the firewall allows
only one default route and the other one need to be used as a backup route.
However, through a workaround, you could send a specific traffic type
through the other link. Also, if you just want to test, you can add specific
route statements on the pix sending traffic destined to specific
hosts/network through the second link. Check the following examples:
If you would like to send traffic destined to specific host/network via second link:
global (outside2) 1 interface
global (outside) 1 interface
nat (inside) 1 0.0.0.0 0.0.0.0
route outside 0.0.0.0 0.0.0.0
route outside2 64.1.1.0 255.255.255.0 route outside2 100.1.1.1 255.255.255.255
If you would like to use the second ISP as a backup link:
route outside 0.0.0.0 0.0.0.0 1 track 1 route outside2 0.0.0.0 0.0.0.0 254
sla monitor 123
type echo protocol ipIcmpEcho interface outside  num-packets 3  frequency 10
sla monitor schedule 123 life forever start-time now
track 1 rtr 123 reachability
http://www.cisco.com/en/US/products/hw/vpndevc/ps2030/products_configuration_example09186a00806e880b.shtml
If you would like to send specific traffic type via second link:
route outside 0.0.0.0 0.0.0.0 1 route outside2 0.0.0.0 0.0.0.0 254
static (outside2,inside) tcp 0.0.0.0 80 0.0.0.0 80 netmask 0.0.0.0
Hope this helps.
NT
Nagaraja Thanthry your post were informative
You can definitely to do this in 8.0 (btw, the latest code I can find for the PIX is 8.0(4)).
Here is a link which explain how to do it
jerry
From the document linked above:
Note: Load balancing does not occur in this example.
That is the limitation I was referring to before. Primary/secondary links is easy, load balancing, not sure. A router does that without any problem.
I don't see any where in the thread about a requirement for load sharing. Also, I am 100% with you on load sharing in the PIX/ASA.
jerry
