01-24-2006 07:40 AM - edited 03-03-2019 11:33 AM
HI!
This series routers have same CPU and different just in slot/memory options?
I need just Ethernet connectivity and 5-6 GRE Tunnels, OSPF,802.1q. May be IPSec.
It's good platform for me?
Solved! Go to Solution.
01-24-2006 11:55 AM
The CPU is not the same for all the 2800 series. Check the following link for their different performances
http://www.cisco.com/warp/public/765/tools/quickreference/
http://www.cisco.com/warp/public/765/tools/quickreference/routerperformance.pdf
01-24-2006 08:01 AM
do refer this link for more info on the feature it supports and also the availability,maximum memory it can support.
http://cisco.com/en/US/products/ps5854/prod_models_comparison.html
You can check up the data sheets for the models available to pick up the best model for your requirement..
regds
01-24-2006 08:33 AM
If you think you will need greater than 45mb of full-duplex throughput I would go with a 38xx.
01-24-2006 09:07 AM
4 remote office with 28xx
1 central office 7204
Trensport - Ethernet VLAN 802.1q
Each of remote offce have 2 GRE tunnels with neighbors (ring topology between remote offices) and 1 uplink GRE tunnel with central office.
Each of tunnel 10MBit.
01-24-2006 08:55 AM
Tnx for this link, but hes don't have information about CPU comparison.
May be it's same for all 28xx?
01-24-2006 11:55 AM
