Cisco Router 28xx
HI!
This series routers have same CPU and different just in slot/memory options?
I need just Ethernet connectivity and 5-6 GRE Tunnels, OSPF,802.1q. May be IPSec.
It's good platform for me?
1 ACCEPTED SOLUTION
Silver
Re: Cisco Router 28xx
The CPU is not the same for all the 2800 series. Check the following link for their different performances
http://www.cisco.com/warp/public/765/tools/quickreference/
http://www.cisco.com/warp/public/765/tools/quickreference/routerperformance.pdf
do refer this link for more info on the feature it supports and also the availability,maximum memory it can support.
http://cisco.com/en/US/products/ps5854/prod_models_comparison.html
You can check up the data sheets for the models available to pick up the best model for your requirement..
regds
Silver
If you think you will need greater than 45mb of full-duplex throughput I would go with a 38xx.
4 remote office with 28xx
1 central office 7204
Trensport - Ethernet VLAN 802.1q
Each of remote offce have 2 GRE tunnels with neighbors (ring topology between remote offices) and 1 uplink GRE tunnel with central office.
Each of tunnel 10MBit.
Tnx for this link, but hes don't have information about CPU comparison.
May be it's same for all 28xx?
Silver
104
