Community Member
cisco router 3845 CPU reach to 100%
   Hi there,    recently one of our 3845 router start to play around. every day between 1PM to 3PM, the CPU reach the 100% and cause all the link down for  a few minutes.  I have checked the data throught put in interface is normal (40% bandwidth utilzation) and temperature is also normal.  I can not worked out why this happens,  Has anyone experienced similiar issue?  any suggestion on where should I start to look into it?   thanks in advance. Roy
1 ACCEPTED SOLUTION
Bronze
Hi Roy,
Whic is the IOS on the device. Also can you tell more regarding the setup of your networ(frame-realy,point-to-point) and the number of eigrp neighbors. Are the neighbors configured as  stub?
Please refer the below mentioned links which will give you information regarding IP-EIGRP: PDM.
https://supportforums.cisco.com/docs/DOC-4877
https://supportforums.cisco.com/thread/25562
Sathvik
Bronze
Hi Roy,
Can you share the show process cpu sorted and show version output.
Sathvik
Community Member
Hi Sathvik...sorry for the delay, just try to capture the information, most time the system frozens, but today I manage to get some details while it happens. details as following, please let me know what is your thought on what is the possible cuase.  Byt the way, we switch router alst night and this happens to the new router, so we can eliminate the possiblilty of the hardware issue. . Thanks in advance.
ausyd01-rt03#sh processes cpu so 5s
CPU utilization for five seconds: 99%/4%; one minute: 83%; five minutes: 42% >>>> percen time is less 5,internal issue?
PID Runtime(ms)   Invoked      uSecs   5Sec   1Min   5Min TTY Process
248       71652    106295        674 61.08% 48.01% 16.94%   0 IP-EIGRP: PDM
102       31000      1639      18913 32.81% 24.95%  8.41%   0 IP RIB Update
  82     2325388  24240749         95  1.18%  2.80%  6.78%   0 IP Input
232          32    193907          0  0.07%  0.01%  0.00%   0 e1t1 Framer back
  40        1188     48863         24  0.07%  0.09%  0.08%   0 Per-Second Jobs
135          52    488052          0  0.07%  0.01%  0.01%   0 RBSCP Background
  37          20      6352          3  0.07%  0.01%  0.00%   0 Net Background
  17        5364     32344        165  0.07%  0.01%  0.00%   0 ARP Input
   9           0         1          0  0.00%  0.00%  0.00%   0 Crash writer
  10          52      1631         31  0.00%  0.00%  0.00%   0 Environmental mo
  11           0       816          0  0.00%  0.00%  0.00%   0 IPC Dynamic Cach
  13          20     48864          0  0.00%  0.00%  0.00%   0 IPC Periodic Tim
  12           0         1          0  0.00%  0.00%  0.00%   0 IPC Zone Manager
  15           0         1          0  0.00%  0.00%  0.00%   0 IPC Seat Manager
  16           0         1          0  0.00%  0.00%  0.00%   0 IPC BackPressure
   8           0         1          0  0.00%  0.00%  0.00%   0 OIR Handler
  18           0         2          0  0.00%  0.00%  0.00%   0 ATM Idle Timer
  19           0        15          0  0.00%  0.00%  0.00%   0 AAA high-capacit
   7           0         2          0  0.00%  0.00%  0.00%   0 Timers
  14           0     48864          0  0.00%  0.00%  0.00%   0 IPC Deferred Por
  22           0         3          0  0.00%  0.00%  0.00%   0 DDR Timers
  20           0         1          0  0.00%  0.00%  0.00%   0 AAA_SERVER_DEADT
  24           0        52          0  0.00%  0.00%  0.00%   0 EEM ED Syslog
  25          24     11952          2  0.00%  0.00%  0.00%   0 HC Counter Timer
   4           0         1          0  0.00%  0.00%  0.00%   0 EDDRI_MAIN
  27           0         1          0  0.00%  0.00%  0.00%   0 MPLS HC Counter
  28           0         1          0  0.00%  0.00%  0.00%   0 RO Notify Timers
  29           0         2          0  0.00%  0.00%  0.00%   0 SMART
   2          44      9779          4  0.00%  0.03%  0.02%   0 Load Meter
  31           0         2          0  0.00%  0.00%  0.00%   0 Dialer event
  21           0         1          0  0.00%  0.00%  0.00%   0 Policy Manager
  33           0         2          0  0.00%  0.00%  0.00%   0 XML Proxy Client
   5       32432      5420       5983  0.00%  0.07%  0.06%   0 Check heaps
  35           0         1          0  0.00%  0.00%  0.00%   0 Inode Table Dest
  36           0         1          0  0.00%  0.00%  0.00%   0 Critical Bkgnd
   6          36        97        371  0.00%  0.00%  0.00%   0 Pool Manager
  38           0        59          0  0.00%  0.00%  0.00%   0 Logger
  39          32     48857          0  0.00%  0.00%  0.00%   0 TTY Background
  23           4         4       1000  0.00%  0.00%  0.00%   0 Entity MIB API
  26           0         2          0  0.00%  0.00%  0.00%   0 Serial Backgroun
  42           0         1          0  0.00%  0.00%  0.00%   0 AggMgr Process
  43           0         1          0  0.00%  0.00%  0.00%   0 Token Daemon
  44           0         1          0  0.00%  0.00%  0.00%   0 dev_device_inser
  45           0         1          0  0.00%  0.00%  0.00%   0 dev_device_remov
  46           0         1          0  0.00%  0.00%  0.00%   0 sal_dpc_process
  47           0         1          0  0.00%  0.00%  0.00%   0 ARL Table Manage
  48           0         2          0  0.00%  0.00%  0.00%   0 ESWPPM
  49           0         2          0  0.00%  0.00%  0.00%   0 Eswilp Storm Con
  50           0         2          0  0.00%  0.00%  0.00%   0 ESWILPPM
  30          12     48861          0  0.00%  0.00%  0.00%   0 GraphIt
  52          24    193907          0  0.00%  0.00%  0.00%   0 Netclock Backgro
  53           0         2          0  0.00%  0.00%  0.00%   0 SM Monitor
  54           0         2          0  0.00%  0.00%  0.00%   0 NM-1VSAT-GILAT M
  56           4      8149          0  0.00%  0.00%  0.00%   0 mxt5100
  57           0         2          0  0.00%  0.00%  0.00%   0 VNM DSPRM MAIN
  58           0         1          0  0.00%  0.00%  0.00%   0 DSPFARM DSP READ
  32           0         1          0  0.00%  0.00%  0.00%   0 SERIAL A'detect
  60           0         1          0  0.00%  0.00%  0.00%   0 HDV background
  61           0         2          0  0.00%  0.00%  0.00%   0 Multi-ISA Event
  62           0         1          0  0.00%  0.00%  0.00%   0 Multi-ISA Cleanu
  34         332       592        560  0.00%  0.01%  0.00% 322 Virtual Exec
  64           0         1          0  0.00%  0.00%  0.00%   0 IGMP Snooping Pr
  65           0         1          0  0.00%  0.00%  0.00%   0 IGMP Snooping Re
  66           0         2          0  0.00%  0.00%  0.00%   0 Call Management
  67           0         1          0  0.00%  0.00%  0.00%   0 AAL2CPS TIMER_CU
  41           0      3261          0  0.00%  0.00%  0.00%   0 c2800 Periodic
  69           0         2          0  0.00%  0.00%  0.00%   0 dot1x
  70           0         2          0  0.00%  0.00%  0.00%   0 DTP Protocol
  71          12     48861          0  0.00%  0.00%  0.00%   0 PI MATM Aging Pr
  72           0      4890          0  0.00%  0.00%  0.00%   0 EtherChnl
  73           0         1          0  0.00%  0.00%  0.00%   0 L2X Data Daemon
  74           0         2          0  0.00%  0.00%  0.00%   0 Dot11 auth Dot1x
  75           0         1          0  0.00%  0.00%  0.00%   0 Dot11 Mac Auth
  76           4        85         47  0.00%  0.00%  0.00%   0 AAA Server
  77           0         1          0  0.00%  0.00%  0.00%   0 AAA ACCT Proc
  78           0         1          0  0.00%  0.00%  0.00%   0 ACCT Periodic Pr
  79           0         2          0  0.00%  0.00%  0.00%   0 AAA Dictionary R
  80           0         1          0  0.00%  0.00%  0.00%   0 AC Mgr
  81         152      5745         26  0.00%  0.00%  0.00%   0 CDP Protocol
  51           0         2          0  0.00%  0.00%  0.00%   0 Eswilp Storm Con
  83           0         1          0  0.00%  0.00%  0.00%   0 ICMP event handl
  84           0         4          0  0.00%  0.00%  0.00%   0 TurboACL
  85           0         2          0  0.00%  0.00%  0.00%   0 TurboACL chunk
  86           0        84          0  0.00%  0.00%  0.00%   0 MOP Protocols
  87           0         5          0  0.00%  0.00%  0.00%   0 PPP Hooks
  89           0         1          0  0.00%  0.00%  0.00%   0 SSS Manager
  90           4      6519          0  0.00%  0.00%  0.00%   0 SSS Test Client
  91           0         1          0  0.00%  0.00%  0.00%   0 SSS Feature Mana
  92          20    190923          0  0.00%  0.00%  0.00%   0 SSS Feature Time
  93           0         1          0  0.00%  0.00%  0.00%   0 VPDN call manage
  94           0         1          0  0.00%  0.00%  0.00%   0 L2X Socket proce
  95           0         1          0  0.00%  0.00%  0.00%   0 L2X SSS manager
  96           0         2          0  0.00%  0.00%  0.00%   0 L2TP mgmt daemon
  97           0         1          0  0.00%  0.00%  0.00%   0 X.25 Encaps Mana
  98           0         2          0  0.00%  0.00%  0.00%   0 EAPoUDP Process
  99           0         1          0  0.00%  0.00%  0.00%   0 IPv6 RIB Redistr
100           0         2          0  0.00%  0.00%  0.00%   0 KRB5 AAA
101         172       855        201  0.00%  0.00%  0.00%   0 IP Background
  59           0         2          0  0.00%  0.00%  0.00%   0 FLEX DNLD MAIN
103           0         3          0  0.00%  0.00%  0.00%   0 PPP IP Route
104           0         4          0  0.00%  0.00%  0.00%   0 PPP IPCP
105          28     48856          0  0.00%  0.00%  0.00%   0 Socket Timers
106          52      2710         19  0.00%  0.00%  0.00%   0 TCP Timer
107          52        63        825  0.00%  0.00%  0.00%   0 TCP Protocols
108           0         1          0  0.00%  0.00%  0.00%   0 COPS
109         220     56493          3  0.00%  0.00%  0.00%   0 CEF process
110           0         2          0  0.00%  0.00%  0.00%   0 L2MM
111           0         1          0  0.00%  0.00%  0.00%   0 MRD
112           0         1          0  0.00%  0.00%  0.00%   0 IGMPSN
113           0         1          0  0.00%  0.00%  0.00%   0 IP Traceroute
114           0         2          0  0.00%  0.00%  0.00%   0 SNMP Timers
115           0         2          0  0.00%  0.00%  0.00%   0 RLM groups Proce
116           0         2          0  0.00%  0.00%  0.00%   0 DDP
   1           0         8          0  0.00%  0.00%  0.00%   0 Chunk Manager
118           0         1          0  0.00%  0.00%  0.00%   0 IUA Main Process
119          60     48861          1  0.00%  0.00%  0.00%   0 RUDPV1 Main Proc
120           0         1          0  0.00%  0.00%  0.00%   0 bsm_timers
121          20     48863          0  0.00%  0.00%  0.00%   0 bsm_xmt_proc
122           0         1          0  0.00%  0.00%  0.00%   0 CES Client SVC R
123         300     97712          3  0.00%  0.01%  0.00%   0 DHCPD Receive
  63           4     48860          0  0.00%  0.00%  0.00%   0 Ether-Switch RBC
  68           0         1          0  0.00%  0.00%  0.00%   0 CES Line Conditi
126          52       816         63  0.00%  0.00%  0.00%   0 Adj Manager
127           0         2          0  0.00%  0.00%  0.00%   0 ATM OAM Input
128           0         2          0  0.00%  0.00%  0.00%   0 ATM OAM TIMER
129           0       165          0  0.00%  0.00%  0.00%   0 HTTP CORE
130           0         1          0  0.00%  0.00%  0.00%   0 RARP Input
131           0         1          0  0.00%  0.00%  0.00%   0 PAD InCall
132           0         2          0  0.00%  0.00%  0.00%   0 X.25 Background
133           0         2          0  0.00%  0.00%  0.00%   0 PPP Bind
134           0         2          0  0.00%  0.00%  0.00%   0 PPP SSS
117           4         2       2000  0.00%  0.00%  0.00%   0 SCTP Main Proces
136           0         2          0  0.00%  0.00%  0.00%   0 Tag Input
137           8      9778          0  0.00%  0.00%  0.00%   0 L2F management d
138           4         1       4000  0.00%  0.00%  0.00%   0 PPTP Mgmt
139           0         2          0  0.00%  0.00%  0.00%   0 PPTP Data
140           0         1          0  0.00%  0.00%  0.00%   0 Inspect Timer
141           0       408          0  0.00%  0.00%  0.00%   0 DHCPD Timer
142           0       163          0  0.00%  0.00%  0.00%   0 Authentication P
143           0         1          0  0.00%  0.00%  0.00%   0 Auth-proxy AAA B
144           0         1          0  0.00%  0.00%  0.00%   0 IPS Timer
145           0         2          0  0.00%  0.00%  0.00%   0 SDEE Management
146           0         1          0  0.00%  0.00%  0.00%   0 IPv6 Inspect Tim
147           8     95449          0  0.00%  0.00%  0.00%   0 SSLVPN_PROCESS
148           0         2          0  0.00%  0.00%  0.00%   0 URL filter proc
149           0         3          0  0.00%  0.00%  0.00%   0 Crypto HW Proc
150           0      1957          0  0.00%  0.00%  0.00%   0 CRM_CALL_UPDATE_
151         112         2      56000  0.00%  0.00%  0.00%   0 CCVPM_HDSPRM
152           4     18098          0  0.00%  0.00%  0.00%   0 FLEX DSPRM MAIN
153           0     18096          0  0.00%  0.00%  0.00%   0 FLEX DSP KEEPALI
154           0         4          0  0.00%  0.00%  0.00%   0 HDA DSPRM MAIN
155           0         2          0  0.00%  0.00%  0.00%   0 ENABLE AAA
156           0         1          0  0.00%  0.00%  0.00%   0 EM Background Pr
157           0         1          0  0.00%  0.00%  0.00%   0 Key chain liveke
158           0         2          0  0.00%  0.00%  0.00%   0 LINE AAA
159          12       210         57  0.00%  0.00%  0.00%   0 LOCAL AAA
160           0         2          0  0.00%  0.00%  0.00%   0 TPLUS
161           0         2          0  0.00%  0.00%  0.00%   0 VSP_MGR
162           0         1          0  0.00%  0.00%  0.00%   0 encrypt proc
163           0         3          0  0.00%  0.00%  0.00%   0 Crypto WUI
164           0         2          0  0.00%  0.00%  0.00%   0 Crypto Support
165           0         1          0  0.00%  0.00%  0.00%   0 CCVPM_HTSP
166           0         2          0  0.00%  0.00%  0.00%   0 VPM_MWI_BACKGROU
167           0         1          0  0.00%  0.00%  0.00%   0 CCVPM_R2
168           0        55          0  0.00%  0.00%  0.00%   0 FB/KS Log HouseK
169           0         1          0  0.00%  0.00%  0.00%   0 CCSWVOICE
171           0         1          0  0.00%  0.00%  0.00%   0 http client proc
172          12         2       6000  0.00%  0.00%  0.00%   0 CCAAL2_CT
173          12         2       6000  0.00%  0.00%  0.00%   0 CCH323_CT
174           0         1          0  0.00%  0.00%  0.00%   0 CCH323_DNS
175           0         2          0  0.00%  0.00%  0.00%   0 CCFRF11_CT
176          12         2       6000  0.00%  0.00%  0.00%   0 CCSIP_SPI_CONTRO
177           0         1          0  0.00%  0.00%  0.00%   0 CCSIP_DNS
178           4         1       4000  0.00%  0.00%  0.00%   0 CCSIP_UDP_SOCKET
179           0         1          0  0.00%  0.00%  0.00%   0 CCSIP_TCP_SOCKET
181           4         1       4000  0.00%  0.00%  0.00%   0 QOS_MODULE_MAIN
182           0         1          0  0.00%  0.00%  0.00%   0 RPMS_PROC_MAIN
183           0         1          0  0.00%  0.00%  0.00%   0 VoIP AAA
184           0         1          0  0.00%  0.00%  0.00%   0 crypto engine pr
185          36         4       9000  0.00%  0.00%  0.00%   0 Crypto CA
186           0         1          0  0.00%  0.00%  0.00%   0 Crypto PKI-CRL
187           0         1          0  0.00%  0.00%  0.00%   0 Crypto SSL
188           0         7          0  0.00%  0.00%  0.00%   0 Crypto ACL
189           0         2          0  0.00%  0.00%  0.00%   0 CRYPTO QoS proce
190           0         1          0  0.00%  0.00%  0.00%   0 Crypto INT
191           4         4       1000  0.00%  0.00%  0.00%   0 Crypto IKMP
192         124      2447         50  0.00%  0.00%  0.00%   0 IPSEC key engine
193           0         1          0  0.00%  0.00%  0.00%   0 IPSEC manual key
194           0         1          0  0.00%  0.00%  0.00%   0 Crypto PAS Proc
195           0         1          0  0.00%  0.00%  0.00%   0 Crypto Delete Ma
196           0         2          0  0.00%  0.00%  0.00%   0 Key Proc
197           8     48865          0  0.00%  0.00%  0.00%   0 Crypto Device Up
198           0         1          0  0.00%  0.00%  0.00%   0 PM Callback
199           0       821          0  0.00%  0.00%  0.00%   0 DHCPD Database
200           0         1          0  0.00%  0.00%  0.00%   0 DATA Transfer Pr
201           0         1          0  0.00%  0.00%  0.00%   0 DATA Collector
202           0        74          0  0.00%  0.00%  0.00%   0 AAA SEND STOP EV
203           0         3          0  0.00%  0.00%  0.00%   0 EEM ED CLI
204           0         2          0  0.00%  0.00%  0.00%   0 EEM ED Counter
205           0         2          0  0.00%  0.00%  0.00%   0 EEM ED Interface
206           0         3          0  0.00%  0.00%  0.00%   0 EEM ED IOSWD
207           0         2          0  0.00%  0.00%  0.00%   0 EEM ED Memory-th
208           0         2          0  0.00%  0.00%  0.00%   0 EEM ED None
209           0         2          0  0.00%  0.00%  0.00%   0 EM ED OIR
210           0         2          0  0.00%  0.00%  0.00%   0 EEM ED SNMP
211           0       818          0  0.00%  0.00%  0.00%   0 EEM ED Timer
212           8      9793          0  0.00%  0.00%  0.00%   0 EEM Server
213           0      4890          0  0.00%  0.00%  0.00%   0 RMON Recycle Pro
214           0         2          0  0.00%  0.00%  0.00%   0 RMON Deferred Se
215           0         1          0  0.00%  0.00%  0.00%   0 Syslog Traps
216           0         2          0  0.00%  0.00%  0.00%   0 IpSecMibTopN
217           4         2       2000  0.00%  0.00%  0.00%   0 VLAN Manager
218          24     48786          0  0.00%  0.00%  0.00%   0 trunk conditioni
219           0         1          0  0.00%  0.00%  0.00%   0 trunk conditioni
220           0         2          0  0.00%  0.00%  0.00%   0 EEM Policy Direc
221           0        29          0  0.00%  0.00%  0.00%   0 Syslog
222           0         1          0  0.00%  0.00%  0.00%   0 VPDN Scal
223          60      1691         35  0.00%  0.00%  0.00%   0 Net Input
224          80      9779          8  0.00%  0.00%  0.00%   0 Compute load avg
225       14620       825      17721  0.00%  0.01%  0.00%   0 Per-minute Jobs
226           0         1          0  0.00%  0.00%  0.00%   0 TCP Driver
227           0         1          0  0.00%  0.00%  0.00%   0 TCP Listener
228          44      1694         25  0.00%  0.00%  0.00%   0 CEF Scanner
229           0         1          0  0.00%  0.00%  0.00%   0 tHUB
230           0         2          0  0.00%  0.00%  0.00%   0 tENM
231           4        29        137  0.00%  0.00%  0.00%   0 SSH Event handle
124           0         2          0  0.00%  0.00%  0.00%   0 Dialer Forwarder
233           0         2          0  0.00%  0.00%  0.00%   0 IP Flow Backgrou
234           0       815          0  0.00%  0.00%  0.00%   0 Snapshot
235         136   1524928          0  0.00%  0.04%  0.07%   0 PPP manager
236         132   1524968          0  0.00%  0.03%  0.06%   0 PPP Events
237           4     48881          0  0.00%  0.00%  0.00%   0 Multilink PPP
239        1752      9336        187  0.00%  0.00%  0.00%   0 IP SNMP
240         556      4667        119  0.00%  0.00%  0.00%   0 PDU DISPATCHER
241        4128      4666        884  0.00%  0.00%  0.00%   0 SNMP ENGINE
242           0         1          0  0.00%  0.00%  0.00%   0 SNMP ConfCopyPro
243           4        23        173  0.00%  0.00%  0.00%   0 SNMP Traps
244          12     49641          0  0.00%  0.00%  0.00%   0 NTP
245          12       815         14  0.00%  0.00%  0.00%   0 Time Range Proce
246        7480        45     166222  0.00%  0.00%  0.00%   0 crypto sw pk pro
247           8       836          9  0.00%  0.00%  0.00%   0 IP-EIGRP Router
125         492       815        603  0.00%  0.00%  0.00%   0 IP Cache Ager
249        5108    130881         39  0.00%  0.04%  0.02%   0 IP-EIGRP: HELLO
auXXX01-rt03#sh int gi0/0          >>>>>>>>>  the inerface show not much traffic from internal link,
GigabitEthernet0/0 is up, line protocol is up
  Hardware is MV96340 Ethernet, address is 0012.d974.81f8 (bia 0012.d974.81f8)
  Internet address is X.X.X.X/24
  MTU 1500 bytes, BW 1000000 Kbit, DLY 10 usec,
  Keepalive set (10 sec)
  Full-duplex, 1000Mb/s, media type is T
  output flow-control is XON, input flow-control is XON
  Last input 00:00:00, output 00:00:00, output hang never
  Input queue: 53/75/83/0 (size/max/drops/flushes); Total output drops: 0
  Queueing strategy: fifo
  Output queue: 0/40 (size/max)
  30 second input rate 296000 bits/sec, 116 packets/sec
  30 second output rate 136000 bits/sec, 75 packets/sec
     11854182 packets input, 1842563369 bytes, 0 no buffer
     Received 82833 broadcasts, 0 runts, 0 giants, 76 throttles
     5 input errors, 0 CRC, 0 frame, 5 overrun, 0 ignored
     0 watchdog, 0 multicast, 0 pause input
     14461237 packets output, 4166928260 bytes, 0 underruns
     0 lost carrier, 0 no carrier, 0 pause output
Bronze
Hi Roy,
Sathvik
Community Member
Hi Sathvik,
the IOS  version  is 12.3(14)T6, RELEASE SOFTWARE (fc2)
this router has been setup as hub and has 4 mb link to TPG network, there are around 7 sites connected it via GRE tunnel. same rouer also connect to other router which might connect to AT&T and other Carrier. we have this router for years never had issue. as I mension, we also change the router, but problem persist.   based on the sh process finding, we belive it is to do with EIGRP update. what is your suggestion? cheers Roy
Bronze
Hi Roy,
Can you check the load on the outbound interface and also interface connecting to the other router which has AT&T link terminated. Also see if any of the GRE tunnels or interfaces are flapping frequently and eigrp neighborship is rebuiling.
Check if you can find any BUGS for 12.3(14)T6.
Sathvik
506
