Community Member
cisco router and switch compatability
Hiyall..
I would like to know from where i can get the information regarding cisco routers n switches modules and interfaces.I w'd also like to know about the compatability between different hardwares as well as the ios compatibility. Refering me about a good book or documentation cd is what i really expect.
thank ya in advance
Community Member
Re: cisco router and switch compatability
If you have access to CCO which you do, you already have access to excellent technical documentation. Look on Cisco Press as well.
Silver
Doc. home provides lots of s/w & h/w, config. info.
http://www.cisco.com/univercd/home/home.htm
And feature navigator provides the function to search IOS that depends on the feature :
http://tools.cisco.com/ITDIT/CFN/jsp/index.jsp
Hope this helps.
Community Member
thanx jackyoung :),
Your information was really helpfull.Any suggested books or cd's?
thanks n regards
96
