cisco RPM-B (NPE150) problem
Hi all,
i've a problem with my RPM:
It keeps on giving this message:
00:01:16: %RPM_VIRTUAL_PORT-3-VRTLINFO: Starting bulk updates ...
00:01:16: %RPM_VIRTUAL_PORT-3-VRTLINFO: ... Completed Bulk updates
00:01:45: %RPM_VIRTUAL_PORT-3-VRTLINFO: RSCPRTN_RESYNCH_TASK: Synch Check Started...
00:01:45: %RPM_VIRTUAL_PORT-3-VRTLINFO: RSCPRTN_RESYNCH_TASK: Synch Check Complete.
Plus it adds automatically this line in its running config:
boot system tftp rpm-js-mz.122-15.T5.bin 255.255.255.255
I need to use it in production, but i am afraid it would be faulty !?
Thanks.
Bronze
Re: cisco RPM-B (NPE150) problem
The response may be due to following reasons.
1. The interface state may be changed from up to down
2.There may occured a router crash
3.The connection resyncronisation may be happened.
Hi William,
Thanks alot for the reply, but what about adding automatically this line in its running config when reloaded:
Thanks in advance.
182
