Cisco Switch Port giving Crazy Stats
Hey Guys
This Problem has been giving me sleepless nights from a Month now.
We have a cisco 4006. We run OSPF and BGP. There are two ports on the
switch that are connected to the Core Routers. The Stats on these ports
are crazy.
Here is what I get when I see these Interfaces
FastEthernet2/48 is up, line protocol is up
Hardware is Fast Ethernet Port, address is
Internet address is X.X.X.251/28
MTU 1500 bytes, BW 100000 Kbit, DLY 100 usec,
reliability 255/255, txload 251/255, rxload 3/255
Keepalive set (10 sec)
Full-duplex, 100Mb/s
Last input 00:00:00, output never, output hang never
Last clearing of "show interface" counters 6w2d
Input queue: 31402/75/0/0 (size/max/drops/flushes); Total output
drops: 0
Queueing strategy: fifo
Output queue: 0/40 (size/max)
5 minute input rate 1383000 bits/sec, 920 packets/sec
5 minute output rate 500224000 bits/sec, 33987277 packets/sec
2481037660 packets input, 454955876 bytes, 0 no buffer
Received 3267143 broadcasts, 0 runts, 0 giants, 0 throttles
2047853408 packets output, 1214833509 bytes, 0 underruns
0 lost carrier, 0 no carrier
FastEthernet2/47 is up, line protocol is up
Internet address is X.X.X.232/28
reliability 255/255, txload 246/255, rxload 1/255
5 minute output rate 96648000 bits/sec, 5310567 packets/sec
1046861 packets input, 123914863 bytes, 0 no buffer
Received 934185 broadcasts, 0 runts, 0 giants, 0 throttles
1987 input errors, 0 CRC, 0 frame, 0 overrun, 0 ignored
363290167 packets output, 3566189248 bytes, 0 underruns
These are 100Mb ports. Howcan they do like 500 Mb/sec. Doesnt make
sense to me.
The Ports would be less than 100Mb at one moment and then just shoot up
to 300-400 Mb another moment with millions of packets per second.
Doesnt make sense to me. However, the MRTG never shows more than 9-10
Mb. Any Clues.
Any help will be appreciated.
Thanx
Re: Cisco Switch Port giving Crazy Stats
Hi 2 things to clarify
1) FastEthernet2/48 is up, line protocol is up is this port working fine or not
2) we can try to reduce the polling intervel of MRTG to 30 sec and monitor the same
Well..
The Port is working Fine. However, what I wonder is If the stats are these, there is something wrong .
Secondly, I have even ran a sniffer on the port. The port shows very nominal traffic coming out of the Port to the Core Switch. Makes me think that the packets might be getting dropped.
Any Clues.
Thanx for the Help
Silver
From the looks of the interfaces you are extremely loading it down on the TX load. However you state that you see nominal traffic on the SPAN. Possibly your SPAN port is not configured correctly and you are only capturing traffic from a specific port and not the VLAN itself. Also change your load interval timer to 30secs. That will give you a more true reading of the interface...
160
