Cisco T Series IOS
arun.sasidharan
How can I replace Cisco T Series IOS to a diff series?What are feature set of Cisco T Series IOS?
John Blakley
The "T" series introduces new features into the IOS. Here's the Feature Navigator. You can search by what features you currently use, and then find a suitable replacement.
http://tools.cisco.com/ITDIT/CFN/jsp/index.jsp
HTH,
John
HTH, John *** Please rate all useful posts ***
Joseph W. Doherty
"How can I replace Cisco T Series IOS to a diff series?"
The T train becomes the next mainline train. So if you were running 12.3T, 12.4 would be the upgrade path for all the features that the 12.3T concluded with.
"What are feature set of Cisco T Series IOS?"
That varies. T trains are works-in-progress. Newer versions within the same T train support new hardware and/or new IOS features. New features are documented as released. They are also sometimes described before released, and what release they are expected in.
thnak you for the reply
