Cisco Telepresence
Can a Cisco Catalyst 6506 Switch support Telepresence?
Appreciate your response
Navneet
  • WAN Routing and Switching
1 ACCEPTED SOLUTION
Re: Cisco Telepresence
Hello Navneet,
what do you mean by "support"? Telepresence to my knowledge is an advanced communication (video/voip) solution. The 6506 is supporting voip and video. In this sense: Yes.
Q: Will you have a "three-panel, 65-inch plasma screen system complete with a specially designed table that seats six participants" module for the 6506, i.e. an integrated Cisco TelePresence 3000?
A: Unlikely ;-)
For more details on TelePresence have a look at
http://www.cisco.com/en/US/products/ps7060/index.html
Cheers, Martin
Hello Navneet,
A: Unlikely ;-)
Cheers, Martin
Hi Martin,
Thanx for the Reply. Was jus looking for a compatibility of 6506s with Telepresence. I got the answer..:)
Cheers
Navneet
Cisco telepresence is different hardware.for more info look at this
http://cisco.com/en/US/products/ps7073/prod_models_home.html
to know abt the technology and related qa
http://cisco.com/en/US/products/ps7073/products_qanda_item0900aecd80544106.shtml
rgrds,
The Telpresence traffic will cause some large bursts of traffic. So not all 6506 modules will support these traffic.
There is a list of latest Cat6k/Cat4500 modules and switches which can support these large bursts and are recommended for Telepresence.
Manu
Hall of Fame Super Gold
Can you point us to the list of such modules and a cisco document supporting the "burst limitations" that you mentioned ?
Silver
Hi Navneet,
TelePresence, makes high demands on the network for quality of service, availability, and security. Specifically, your network must exhibit the following four critical attributes from end to end: QOS, Nonstop communications,Integrated security,Operational manageability.
There is a document which explains how 6500 switches supports these requirements. It may be helpful to you......
http://www.cisco.com/en/US/products/hw/switches/ps708/products_white_paper0900aecd80655fb2.shtml
Rate if it does,
Rgs.
I've read the document and fund that is quite marketing oriented, and this does not contain any indication of modules unable to support "telepresence".
Honestly I would be surprised if there were, because since the start the 6500 linecards were designed for linerate performance, that is some steps above "burst tolerance".
Hi All,
We are using a 3750 Switch at the users end and it is connected to a 3845 ISR at the ISP end. QoS is enabled at 3750.
I repeat myself, no matter the application, and no matter if QoS is configured or not, your 3750 switch will work fine.
QoS on LAN environments in essentially unnecessary, as you can add links as you want.
The only place where you need to configure QoS properly is on the WAN, where congestion occurs.
249
