Community Member
Cisco VPN client and ACL
Hello. I am trying to set up a VPN connection between a Cisco VPN client and a Cisco 3640 using EZ VPN Server. I have a simple ACL on the inbound 3640 interface that reads:
permit udp any host x.x.x.x eq isakmp
permit esp any host x.x.x.x
permit udp any host x.x.x.x eq 4500
permit tcp any host x.x.x.x eq 10000
This is the only ACL on the 3640 interface.
When I configure the client to connect using Enable Transparent Tunneling -IPSec over UDP (NAT/PAT), I can connect the tunnel. When I select Enable Transparent Tunneling -IPSec over TCP - Port 10000, I cannot connect the tunnel.
Is the problem with the ACL or something else?
Thanks.
1 REPLY
Re: Cisco VPN client and ACL
Patrick,
The problem most likely is not your ACL. Since you mentioned 3640, my guess is you are running 12.4T Code and the feature that you are looking for wasnt introduced until 12.4(9)T.
IPSec Over TCP feature on routers was introduced in 12.4(9)T. The command that you should be looking for is "crypto
ctcp port [port-number]".
Please refer the below URL for details:
http://www.cisco.com/en/US/partner/products/sw/iosswrel/ps1839/products_feature_guide09186a008055c37a.html#wp1305478
Let me know if it helps.
Arul
208
