Webcast-Catalyst9k
Cisco WIC-1ENET
Just a quick question if anyone knows here. We are looking for a WIC Ethernet card for a 2620 router. Some websites I have visited have said the WIC-1ENET will work on the 2600 series while other say it only works specifically on the 1700 series. Not sure if tis is the right place to post this question or not.
Tim
1 REPLY
Hall of Fame Super Gold
Re: Cisco WIC-1ENET
WIC-1ENET is not compatible with the 2600. Please see:
http://cisco.com/en/US/products/hw/routers/ps214/products_tech_note09186a00800ae37f.shtml
If you need an additional port try getting an nm-2fe, or an external L2 switch on which you can fan-out as many ports you want using the VLAN subinterfaces on fasternet.
300
