Cisco WS-C6504-e / how to increase maximum of CEF BGP-Routes
Hello to the Community,
i've got a Cisco WS-C6504-e Router, with a  which will be configured as BGP-Router.
The Problem:
If the Router has more than 524000 BGP Routes i got this message,
even after a Reset to Factory Defaults.
"00:12:49: %CFIB-SP-7-CFIB_EXCEPTION: FIB TCAM exception, Some entries will be software switched"
  Output features: HW Shortcut Installation
I tested and had the same Effects with:
Software Version 12.2(33)SRA2
Software Version 12.2(33)SRA3
Software Version 15.1(1)SY (the newest Firmware Version)
The builtin and used Supervisor Modul is a
Cisco Catalyst 6500 Series Supervisor Engine 720 / MSFC3 with 1GB Memory.
What have i to do for getting more (ca 1000000) BGP Routes via CEF handled and not software switched?
Here the Configuration:
Router#show ip cef summary
IPv4 CEF is enabled for distributed and running
VRF Default:
524549 prefixes (524549/0 fwd/non-fwd)
Default network 0.0.0.0/0
Table id 0
Database epoch:        4 (524549 entries at this epoch)
Router#show cef interface GigabitEthernet1/2
GigabitEthernet1/2 is up (if_number 5)
  Corresponding hwidb fast_if_number 5
  Corresponding hwidb firstsw->if_number 5
  Internet address is 10.0.1.2/24
  ICMP redirects are always sent
     IP unicast RPF check is disabled
  Inbound access list is not set
  Outbound access list is not set
  IP policy routing is disabled
  BGP based policy accounting on input is disabled
  BGP based policy accounting on output is disabled
  Hardware idb is GigabitEthernet1/2
  Fast switching type 22, interface type 143
  IP CEF switching enabled
  IP CEF switching turbo vector
  IP Null turbo vector
  IP prefix lookup IPv4 mtrie generic
  Input fast flags 0x0, Output fast flags 0x0
  ifindex 3(3)
  Slot 1 Slot unit 2 VC -1
  Transmit limit accumulator 0x0 (0x0)
  IP MTU 1500
Router# show configuration
Using 2547 out of 1964024 bytes
upgrade fpd auto
version 12.2
service timestamps debug uptime
service timestamps log uptime
service counters max age 10
hostname Router
boot-start-marker
boot-end-marker
no aaa new-model
ip subnet-zero
mls ip multicast flow-stat-timer 9
no mls flow ip
no mls flow ipv6
no mls acl tcam share-global
mls cef error action freeze
redundancy
keepalive-enable
mode sso
main-cpu
  auto-sync running-config
spanning-tree mode pvst
diagnostic cns publish cisco.cns.device.diag_results
diagnostic cns subscribe cisco.cns.device.diag_commands
fabric buffer-reserve queue
vlan internal allocation policy ascending
vlan access-log ratelimit 2000
interface GigabitEthernet1/1
no ip address
shutdown
ip address 10.0.1.2 255.255.255.0
media-type rj45
interface GigabitEthernet3/1
no ip address
shutdown
interface GigabitEthernet3/2
no ip address
shutdown
interface GigabitEthernet3/3
no ip address
shutdown
interface GigabitEthernet3/4
no ip address
shutdown
interface GigabitEthernet3/5
no ip address
shutdown
interface GigabitEthernet3/6
no ip address
shutdown
interface GigabitEthernet3/7
no ip address
shutdown
interface GigabitEthernet3/8
no ip address
shutdown
interface GigabitEthernet3/9
no ip address
shutdown
interface GigabitEthernet3/10
no ip address
shutdown
interface GigabitEthernet3/11
no ip address
shutdown
interface GigabitEthernet3/12
no ip address
shutdown
interface GigabitEthernet3/13
no ip address
shutdown
interface GigabitEthernet3/14
no ip address
shutdown
interface GigabitEthernet3/15
no ip address
shutdown
interface GigabitEthernet3/16
no ip address
shutdown
interface GigabitEthernet3/17
no ip address
shutdown
interface GigabitEthernet3/18
no ip address
shutdown
interface GigabitEthernet3/19
no ip address
shutdown
interface GigabitEthernet3/20
no ip address
shutdown
interface GigabitEthernet3/21
no ip address
shutdown
interface GigabitEthernet3/22
no ip address
shutdown
interface GigabitEthernet3/23
no ip address
shutdown
interface GigabitEthernet3/24
no ip address
shutdown
interface Vlan1
no ip address
shutdown
router bgp 12345
no synchronization
bgp log-neighbor-changes
neighbor 10.0.1.1 remote-as 64496
no auto-summary
ip classless
no ip http server
no ip http secure-server
control-plane
dial-peer cor custom
line con 0
line vty 0 4
end
thanks for Help
   with regards
          Thomas Berberich
Hi THomas,
Per my understanding, it varies depending on the Supervisor. Can you try "mls cef maximum-route ip" command and see if you can more than 512?.
You may need a router reload to have this command take effect.
-Nagendra
Thank you very much
that was the Solution for my Problem
394
