03-27-2014 10:28 PM - edited 03-04-2019 10:40 PM
Dear Team,
I am trying to run the configuration for CISCO1905-SEC/K9 Router on the CCW but unable to configure it there. Is this product EoL/EoS? If yes, I am unable to find any documentary evidence on the Cisco Website. If somebody has it, please share.
Alternately, if its a configuration problem in CCW, please let me know.
I have attached a snapshot of the issue.
Farhan.
03-28-2014 01:47 AM
03-28-2014 03:45 AM
I am still having the same issue, unable to configure on CCW.
Is this has something to do with my Cisco ID Priviliges?
Farhan.
03-28-2014 03:47 AM
I don't think so...can you put just 1905 in "Find products..." option and then you will be given everything about cisco 1905. From there you can select your SEC part number.
Give it try - it should work...
BR,
Dragan
03-28-2014 03:53 AM
03-28-2014 04:05 AM
Well i have 12 results from same search...definitelly something with CCO account or your country specific...first time seeing this
Anyway you can go with REMAN (remanufactured) option for 516$...it's the same router and I think you can get support services for that also. That's the only option right now for you...
BR,
Dragan
07-15-2014 08:13 AM
It is available in Latin America and select countries within the Asia Pacific region only.
Source:
http://www.cisco.com/c/en/us/products/routers/1905-serial-integrated-services-router-isr/index.html
John Agustin
