Bronze
Cisco2811 with ADSL
I have Cisco 2811 router with WIC-1ADSL card, when i issue show diag, i can't see the card at the installed slot. So, i upgraded the IOS to one that supports ADSL, after that when i issue the show diag i see the following:
WIC Slot 1:
E1 Drop&Insert & G.703 (2 port) WAN daughter card
Unknown EEPROM ver 67
EEPROM format version 67
EEPROM contents (hex):
0x20: 43 30 00 00 05 C1 4F 43 33 39 53 50 81 00 00 04
0x30: FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
Is it hardware failure at the card? or what?
Thanks in advance
Abd Alqader
1 ACCEPTED SOLUTION
Hall of Fame Super Gold
Re: Cisco2811 with ADSL
Yes, it seems at minimum the eeprom got corrupted. The card should be replaced.
1 REPLY
225
