CISCO3945-CHASSIS doesn't recognize HWIC-1GE-SFP
Hi experts, I just installed two of the HWIC-1GE-SFP cards in the CISCO3945 router but they are not recognized... I don't see any messages on the console output. I don't see them in the "show diag" command. I don't see new ports in the "show run" either... Is there some command I need to put in to activate them? Here is show version of my router:
Thanks!
Cisco IOS Software, C3900 Software (C3900-UNIVERSALK9-M), Version 15.0(1)M4, RELEASE SOFTWARE (fc1)
Copyright (c) 1986-2010 by Cisco Systems, Inc.
Compiled Thu 28-Oct-10 21:48 by prod_rel_team
ROM: System Bootstrap, Version 15.0(1r)M8, RELEASE SOFTWARE (fc1)
fmc-eg18-a3-cain-r1 uptime is 4 weeks, 5 days, 23 hours, 40 minutes
System returned to ROM by reload at 18:39:49 UTC Tue Feb 28 2012
System restarted at 11:40:43 MST Tue Feb 28 2012
System image file is "flash0:c3900-universalk9-mz.SPA.150-1.M4.bin"
Last reload type: Normal Reload
Last reload reason: Reload Command
A summary of U.S. laws governing Cisco cryptographic products may be found at:
export@cisco.com.
Cisco CISCO3945-CHASSIS (revision 1.1) with C3900-SPE150/K9 with 987136K/61440K bytes of memory.
Processor board ID FGL151313Q9
3 Gigabit Ethernet interfaces
1 Virtual Private Network (VPN) Module
DRAM configuration is 72 bits wide with parity enabled.
255K bytes of non-volatile configuration memory.
254464K bytes of ATA System CompactFlash 0 (Read/Write)
License Info:
License UDI:
Device#   PID                   SN
*0        C3900-SPE150/K9       FOC15104VL8
Technology Package License Information for Module:'c3900'
Technology    Technology-package          Technology-package
              Current       Type          Next reboot
ipbase        ipbasek9      Permanent     ipbasek9
security      securityk9    Permanent     securityk9
uc            None          None          None
data          None          None          None
1 REPLY
Hall of Fame Super Gold
Re: CISCO3945-CHASSIS doesn't recognize HWIC-1GE-SFP
HWIC cards must be installed with router turned off.
Reload router.
799
